Reading: What is Flapper Nozzle System ?
Inst Tools > Blog > Control Valves > What is Flapper Nozzle System ?
Last updated: August 29, 2019 9:09 pm
Control Valves
2 Min Read
A very important signal conversion is from pressure to mechanical motion and vice versa. This conversion can be provided by a flapper nozzle system (sometimes called as baffle/nozzle system).
A diagram of this device is shown in Fig.I below.
Flapper nozzle system
A regulated supply of pressure, usually 20 psig, provides a source of air through the restriction. The nozzle is open at the end where the gap exists between the nozzle and flapper, and air escapes in this region.
If the flapper moves down and closes off the nozzle opening so that no air leaks, the signal pressure will rise to the supply pressure.
As the flapper moves away, the signal pressure will drop because of leaking of the leaking air. Finally, when the flapper is far away, the pressure will stabilize at some value determined by the maximum leak through the nozzle.
Flapper nozzle graph
Fig II shows the relationship between signal pressure and gap distance. Note the great sensitivity in the central region. A nozzle/flapper is designed to operate in the central region where the slope of the line is greatest.
In this region, the response will be such that a very small motion of the flapper can change the pressure by an order of magnitude.
Note :
  • By adding a Electro-Magnet & supportive springs, we use this system as Current to Pressure Converter (I/P Converter).
  • By adding an LVDT assembly & supportive springs, we use this system as Pressure to Current Converter. (P/I Converter).
We will discuss in detail about I/P Converter and P/I Converter in separate topics, check below.
Also Read :
  1. Current to Pressure (I/P) Converter
  2. Pressure to Current (P/I) Converter
Reference : apexinnovations
Basic Steps and Procedure for the Repair of Control Valve
What is Ball Valve ?
Locked Open (LO) and Locked Closed (LC) Valves
Control Valve End Connection
How Valve Positioners act as Cascade Control Systems in a Loop?
Classification of Control Valves
Control Valve Passing Problem after Overhauling Job
Types of Valve Leakage Tests
Self Actuated Pressure Control Valve Principle
Interactive Control Valve Parts Quiz: Drag & Drop Challenge
ESDV : How it Works ?
Valve Handwheel Types : Fixed, Hammer, Gear
What is a Servo Valve? – Principle and Advantages
Valves MCQ
Classification of valves
Introduction to Types of Valves
Latest Control Valves Interview Questions
Control Valve Interview Questions and Answers
Valve Standards
List of Valve Standards
Types of Control Valve Trim
3-way directional control valves
Directional Control Valves Working Principle
5-Port-2-Position-Valve-Animation
5 Port 2 Position Valve Working Principle
Basics of Butterfly Valves
Control valve performance with varying pressure
Control Valve Performance with Varying Pressure
Foundation Fieldbus Segment Topology
Foundation Fieldbus (FF) Segment Topology
Difference Between LED and LCD
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
DTS sensors
Distributed Temperature Sensors (DTS) in Power Lines
What is Instrumentation and Control
What is Instrumentation and Control ?
DeviceNet
What is DeviceNet?
Field Instrument 4-20mA Calculation
How to do 4-20mA Conversions Easily
STL Programming - SET, RESET, ASSIGN
STL Programming – SET, RESET, ASSIGN
