Reading: Features of PID Controller actions
Inst Tools > Blog > Control Systems > Features of PID Controller actions
Last updated: May 6, 2020 5:31 pm
Control Systems
2 Min Read
Purpose of each Controller action
  • Proportional action is the “universal” control action, capable of providing at least marginal control quality for any process.
  • Integral action is useful for eliminating offset caused by load variations and process self regulation.
  • Derivative action is useful for canceling lags, but useless by itself.
Limitations of each action
  • Proportional action will cause oscillations if sufficiently aggressive, in the presence of lags and/or dead time. The more lags (higher-order), the worse the problem. It also directly reproduces process noise onto the output signal.
  • Integral action will cause oscillation if sufficiently aggressive, in the presence of lags and/or dead time. Any amount of integral action will guarantee overshoot following setpoint changes in purely integrating processes.
  • Derivative action dramatically amplifies process noise, and will cause oscillations in fastacting processes.
Special applicability of each action
  • Proportional action works exceptionally well when aggressively applied to processes lacking the phase shift necessary to oscillate: self-regulating processes dominated by first-order lag, and purely integrating processes.
  • Integral action works exceptionally well when aggressively applied to fast-acting, self-regulating processes. Has the unique ability to ignore process noise.
  • Derivative action works exceptionally well to speed up the response of processes dominated by large lag times, and to help stabilize runaway processes. Small amounts of derivative action will sometimes allow more aggressive P and/or I actions to be used than otherwise would be possible without unacceptable overshoot.
Gain and phase shift of each action
  • Proportional action acts on the present, adding no phase shift to a sinusoidal signal. Its gain is constant for any signal frequency.
  • Integral action acts on the past, adding a −90 deg phase shift to a sinusoidal signal. Its gain decreases with increasing frequency.
  • Derivative action acts on the future, adding a +90 deg phase shift to a sinusoidal signal. Its gain increases with increasing frequency.
Integral Controller Principle
Yokogawa DCS and SIS System Architecture
Heuristic PID Tuning Method
Ziegler-Nichols Open-Loop Method
PID Tuning Recommendations based on Process Dynamics
Loop Calibrator to Simulate a 4-20 mA Signal
Compressor Emergency Shutdown Root Cause Analysis
What is Alarm Prioritization? – Types of Alarms
What is Instrumentation and Control ?
Industry 4.0 Explained – Industrial Internet of Things
System Architecture and Process Control Systems Philosophy
Hot Well Level Control System in Condensing Turbine
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Compare DCS, PLC, RTU
Difference between DCS, PLC, and RTU ?
how-a-4-20ma-transmitter-works
How a 4-20mA Transmitter Works?
Types of Noise in Electronics
Distributed Control System Questions and Answers
Distributed Control System Objective Questions
LED Stumps in Cricket
How do LED Stumps in Cricket Work?
Instrument Control Package (ICP)
Package Control and Safety Systems Implementation Methods
DCS Troubleshooting Control Valve Loop
Difference Between Industrial Computer and Normal Computer
Difference Between Industrial Computer (IPC) and Normal Computer (PC)
Valve Technician Interview Questions
What Every Instrument Engineer Should Know
Common Mistakes in Instrumentation
How transformer works?
actuated-valve-schematic
Components of Shutdown Valve
Types of Interrupts Organization Blocks in Tia Portal
Types of Interrupt OB in Siemens Tia Portal
fieldbus cables layout
H1 FF Data Link layer
Relief Valve
Pressure Relief Valve Principle
