Reading: Electrical Measurements and Instrumentation Objective Questions & Answers
Inst Tools > Blog > Instrumentation MCQ > Electrical Measurements and Instrumentation Objective Questions & Answers
Last updated: June 21, 2025 10:05 am
Instrumentation MCQ Multiple Choice Questions
6 Min Read
[1] A 10MHz CRO has
(a) 5MHz sweep
(b) 10MHz vertical oscillator
(c) 10MHz horizontal oscillator
(d) 10MHz supply frequency
[2] Which of the following instruments can be used to measure AC current only?
(a) Permanent Magnet Type ammeter
(b) Induction type ammeter
(c) Moving iron voltmeter
(d) Moving iron ammeter
choose the right Answer:
  1. D only
  2. B only
  3. A, B, D
  4. B and D only
[3] An oscilloscope indicates
(a) Peak to peak value of voltage
(b) DC value of voltage
(c) RMS value
(d) Average value
[4] In a ballistic galvanometer, the deflecting torque is proportional to
(a) the current through coil
(b) square of current through coil
(c) square-root of current through coil
(d) sine of measured
[5] The error of an instrument is normally given as a percentage of
(a) measured value
(b) full-scale value
(c) mean value
(d) rms value
[6] If the instrument is to have a wide range, the instrument should have
(a) Linear scale
(b) Square-law scale
(c) Exponential scale
(d) Logarithmic scale
[7] The resistance can be measured most accurately by
(a) Voltmeter-ammeter method
(b) bridge method
(c) multimeter
(d) Megger
[8] The repeat accuracy of an instrument can be judged from its
(a) static error
(b) linearity error
(c) dynamic error
(d) standard deviation of error
[9] Which of the following meters has a linear scale?
(a) Thermocouple meter
(b) Moving iron meter
(c) Hot wore meter
(d) Moving coil meter
[10] No eddy current and hysteresis losses occur in
(a) Electrostatic instruments
(b) PMMC instruments
(c) Moving iron instruments
(d) Electrodynamo meter instruments
[11] Two voltmeters have the same range 0-400V. The internal impedance are 30,000 Ohms and 20,000 Ohms. If they are connected in series and 600V be applied across them, the readings are
(a) 360V and 240V
(b) 300V each
(c) 400V and 200V
(d) one of the meters out of the range and other 100V
[12] The full-scale deflection current of an ammeter is 1 mA and its internal resistance is 100Ohm. If this meter is to have full deflection at 5A, what is the value of the shunt resistance to be used?
(a) 49.99 Ohms
(b) 1/49.99 ohms
(c) 1 Ohm
(d) 2 Ohms
[13] The full-scale deflection current of an ammeter is 1 mA and its internal resistance is 100Ohm. This is to have full deflection when 100V is measured. What is the value of series resistor to be used?
(a) 99.99 K ohms
(b) 100 K ohms
(c) 99.99 ohms
(d) 100 ohms
[14] Why is a MISC meter not recommended for DC measurement?
(a) The meter is calibrated for AC and it’s error for DC would be high
(b) The meter does not respond to DC signals
(c) The error is high due to hysteresis effect
(d) The error is high due to eddy current effect
[15] The EMF of Weston standard cell is measured using
(a) Moving- iron meter
(b) Moving-coil meter
(c) Digital Volt meter
(d) Potentiometer
ANSWERS
[1] A 10MHz CRO has
Ans: C
Ans: 2
Ans: A
Ans:A
Ans: B
Ans:D
Ans: B
Ans: D
Ans: D
Ans: A
Ans: A
Ans: B
Ans: A
Ans:  C
Ans: D
More Instrumentation MCQ : CLICK HERE
Feedback Accelerometer System Objective Questions
Common Valve Abbreviations in US Engineering Drawings
Magnetic Wind Instruments Questions & Answers
Fluorescent Spectrometer Questions & Answers
Vibration Probes Questions and Answers
Data Loggers Objective Questions
Instrumentation Engineering Documents Questions Answers
Photo Electric Transducers Objective Questions
Time Response of Second Order Systems – I
DCS Quiz
Level Sensors MCQ – Industrial Instrumentation
Measurements & Instrumentation Quiz – Set 5
Analyzers Based on Gas Density Questions & Answers
Time of Flight Mass Spectrometer
Robotic Instrumentation Objective Questions
pH Meters Questions & Answers
Optimal Control Systems
PLC Wiring
Ultrasonic Sensors Objective Questions
Industrial safety Objective Questions and Answers
Top 10 Industrial safety Objective Questions
Ion Analyzers Questions and Answers
Ion Selective Electrodes Questions and Answers
Basic Temperature Sensors MCQ
Basic Temperature Sensors MCQ Questions Answers
Real-time and historical SCADA Trends
What are Trends in SCADA?
Installation Precautions of Thermocouple and RTD
Pressure Gauges with Zero Adjustment
Pressure Gauges Zero Adjustment
Butterfly Valve Failure caused Fire
Butterfly Valve Failure Caused Serious vicinity Heavy Fire
PLC Programming for Tank Farm Management
Motors Inrush Currents
Motor Inrush Current Measurements
control-valve-actuators
Control Valve Selection Tips
PLC Programmer Unknown Do's
Unknown Do’s Need to Know as a PLC Programmer
