Reading: Electrical Contactor, Switch, Circuit Breaker
Inst Tools > Blog > Electrical Basics > Electrical Contactor, Switch, Circuit Breaker
Last updated: September 8, 2018 11:28 am
Electrical Basics
1 Min Read
An Electrical Contactor is a switch. In simple words contactor is a switch which closes its contacts with the help of relay. Most of the contactors operate by electromagnet, thus causing the contactors to close and open by spring or gravity.
The main difference between the contactors and switch is that contactors can be operate remotely whereas switch has to be manually operated at the location. Contactors can be controlled by manual or remote push buttons or by automatic devices such as timers, float switches, thermostats, pressure switches and so on. As the control is both remote and automatic they are employed in lighting, heating, air conditioning and motor loads
  • Circuit Breaker interrupts the fault current which electrical contactor cannot. Generally contactors are connected in series with fuse. Therefore during short circuits fuse acts as fault current interrupting element in the circuit. In simple contactor is a switch with remote control and automatic functions. Circuit breaker is employed to protect the circuit and electrical contactor is used to open and close the contacts
  • Contactors are generally employed in low voltage and medium voltage level. Circuit breakers can be employed up to EHV systems for switching purpose
Understanding Protection Relays – 50, 50N, 51, 51N
Motor Maintenance, Troubles, Regular Checks, Performance
Motor Inrush Current Measurements
What is an Air Circuit Breaker? Working Principle & Applications
All About Electric Fence Gates
What is an Intelligent Motor Control Center? – IMCC
Basic Electrical Engineering Questions & Answers
Electric Stress Control in Cables, Joints, and Terminations
VFD Pros and Cons – Variable Frequency Drives
One Nation One Grid One Frequency – Electrical Engineering
4-20mA Linear Conversion Calculation for VFD Drive (Formula)
What is a Solid State Relay? – Working Principle, Types of Control
Difference Between Alternator and Generator?
Most Asked Questions on Servo Motor
Electric Motors Efficiency Classes
Automatic Circuit Recloser
What is Automatic Circuit Recloser? Principle and Types
Electrical Conduit Seal
Bonding and Grounding Electrical Systems
Testing and Inspection of Bonding and Grounding Systems
Types of Batteries
Cells and Batteries – Types, Applications, Explanation
Top 10 Common Mistakes on Electrical Systems
Intelligent MCC
What is Smart or Intelligent MCC?
Pressure Transmitter Working Principle
Gage and Absolute Pressure Transmitters Principle
Calculate Temperature of RTD
Capacitance Type Level Transmitter Working Principle
Capacitance Level Transmitter Animation
Different Types of HVAC Applications
AND Gate Logic Animation
Digital Building Blocks – GATES
3 Wire RTD Connections
RTD Sensor Connections
Capacitance-Level-Transmitter
Capacitance Level Switch Calibration
Hydraulic Load Cell Principle
