  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Effect of Adding a Zero to a System – II
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Multiple Choice Questions > Effect of Adding a Zero to a System – II
Last updated: November 27, 2021 5:41 pm
6 Min Read
1. Which of the following can be measured by the use of a tacho-generator?
a) Acceleration
b) Speed
c) Speed and acceleration
d) Displacement
Answer: b
Explanation: Tacho generator is used to measure the velocity or relative velocity of the system.
2. _____________ is not a final control element.
a) Control valve
b) Potentiometer
c) Electro-pneumatic converter
d) Servomotor
Answer: b
Explanation: Potentiometer among all the options cannot be the final control element as this is responsible to get the output in measurable form.
3. Which of the following is the definition of proportional band of a controller?
a) The range of air output as measured variable varies from maximum to minimum
b) The range of measured variables from set value
c) The range of measured variables through which the air output changes from maximum to minimum
d) All of the mentioned
Answer: c
Explanation: Proportional band controller is the range of measured variables through which the air output changes from maximum to minimum.
4. In pneumatic control systems the control valve used as final control element converts
a) Pressure signal to electric signal
b) Pressure signal to position change
c) Electric signal to pressure signal
d) Position change to pressure signal
Answer: b
Explanation: In pneumatic control systems the control valve is used as the final control element to convert pressure signal to position change.
5. Pressure error can be measured by which of the following?
a) Differential bellows and strain gauge
b) Selsyn
c) Strain gauge
d) Strain gauge and potentiometer
Answer: a
Explanation: Pressure error can be measured by differential bellows and strain gauge.
6. Assertion (A): Feedback compensation is preferred to series compensation.
Reason (R): No amplification is required as the energy flows from higher to lower levels.
a) Both assertion and reason are true and R is correct explanation of A
b) Both A and R true but R is not correct explanation of A
c) A is true but R is false
d) A is False but R is true
Answer: a
Explanation: Feedback compensation is preferred to series compensation or cascade compensation because:
In a feedback compensator energy transfer is from higher to a lower one thereby obviating the need for the feedback amplification.
7. Assertion (A): A PI controller increases the order of the system by units but decreases the steady state error.
Reason (R): A PI controller introduces a pole at either the origin or at a desired points on the negative real axis.
Answer: a
Explanation: I is proportional +integral controller. Thus integral controller add a pole either at origin or at the desired point on the negative real axis, so order of the system gets increased but it reduces the steady state error of the offset error.
8. Assertion (A): A derivative controller produces a control action for constant error only.
Reason (R): The PD controller increases the damping and reduces the peak overshoot.
Answer: d
Explanation: The integral control action produces a control action for error constant not derivative controller. A derivative controller improves the transient state of the control system apart from increasing the bandwidth, overshoot and rise time.
9. A plant is controlled by a proportional controller, if time delay element is introduced in the loop its:
a) Phase margin remains the same
b) Phase margin increases
c) Phase margin decreases
d) Gain margin increases
Answer: c
Explanation: When a delay element is introduces in a control system, it only affects the phase margin of the system and new value of the phase margin is decreased.
10. Assertion (A): Lead compensation is used to improve the system’s stability
Reason (R): Lead compensation achieves the desired result through the merits of its phase lead contribution.
Answer: a
Explanation: A lead compensator provides a better gain margin by introducing a positive shift in the phase plot and thus increasing the phase crossover frequency. Thus the system becomes comparatively more stable by using a lead compensator.
Construction of Phase -Trajectories
Biosensors Questions & Answers
Thermal Conductivity Analyzers Questions & Answers
Time Response of Second Order Systems – IV
Constructing Phase-Trajectories
208kSubscribersSubscribe
H2S Analyzers Questions & Answers
Sulphur Di-oxide Monitoring Questions & Answers
Programmable Logic Controllers Multiple Choice Questions
Digital Control Systems Multiple Choice Questions
Level and Density Measurement Objective Questions
Block diagram Algebra Objective Questions
Instrumentation of ESR Spectrometer
Necessary Conditions for Stability & Non-Linear Systems
Pneumatic Systems Objective Questions
Construction of Root Loci
Time Response Analysis
Performance Indices
Infrared Gas Analyzers Questions & Answers
Pressure Measurement Multiple Choice Questions
Feedback and Non-feedback Systems Objective Questions
PID Controllers Multiple Choice Questions
PID Controller Multiple Choice Questions
Bipolar Junction Transistors Questions & Answers
Measurement and Instrumentation Objective Questions – Part 1
Discover More
Diode-positive-limiter
Positive & Negative Diode Clippers
Single Phase VSI Objective Questions
Interface Level Measurement Selection Guide
Direct Acting Control Valve Positioner
Pneumatic Valve Positioner Working Principle
Electrical Cables Interview Questions & Answers
Conductor Size Selection in Distribution Power System
Level Transmitter configuration in PLC
Scaling with Parameters (SCP) Instruction in PLC
Tags in Functional Block Diagram in Studio 5000
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
