Reading: DP Transmitter Problem
Inst Tools > Blog > Practical Questions > DP Transmitter Problem
Suppose we encounter a problem with a differential pressure (DP)  transmitter used to measure the pressure drop across a heat exchanger.
Last updated: October 1, 2020 3:40 pm
Practical Questions
2 Min Read
Suppose we encounter a differential pressure (DP)  transmitter used to measure the pressure drop across a heat exchanger.
The typical pressure on the upstream side of this heat exchanger is 850 PSI, while the typical pressure on the downstream side of this exchanger is 837 PSI. The transmitter connects to this heat exchanger via a three-valve manifold.
A single “bleed” valve installed on the transmitter’s low-pressure side is used to vent pressure to the atmosphere prior to removal of the transmitter from the manifold:
The common procedure for operating a 3-valve manifold to place a transmitter back into service after having isolated it from the process and bleeding any stored pressure to the atmosphere is to first close the bleed valve, then open the low-side block valve, then close off the equalizing valve, and finally open the high-side block valve.
Determine how much fluid pressure will be on each side of the transmitter through every step of this procedure:
Determine how much fluid pressure on DP transmitter
Now, suppose someone else (at a later date) was to remove this transmitter from service using the three-valve manifold, and then return it to service following a different order of steps: closing the equalizing valve first, then opening the low-side block valve, and finally opening the high side block valve.
Determine how much fluid pressure will be on each side of the transmitter through every step of this (alternative) procedure:
DP transmitter Pressure
Based on the pressures seen by the transmitter in both procedures, would you recommend one procedure over the other? If so, why?
  • DP Transmitter 5 Way Manifold
  • Control Valve Practices
  • Transmitter Proof Testing
  • Faults in PID Control Loop
  • Process Control High-Level Alarm
Credits: Tony R. Kuphaldt
Identify Two Pressure Switches Logic
Problem on Solar Hot Air Collector and Variable Speed Fan
A Question on Steam Drum Water Level Measurement
Which Tube has most Hydrostatic Pressure?
How Measurement Span of Pressure Gauge Could be Changed?
Identify the Pressure Gauge Error
  • Abdelssami says:
    January 19, 2021 at 1:52 pm
    of cours i Will recommande the first methode because if the pressure in the low side is high enough it may destroy the mesurment élément in the transmitter , so appling the same pressure force in both sides would be the best solution
Solenoid Valves Practical Problems
Define Normal Status of a Process Switch ?
Displacer Type Density Transmitter Question
A Question on Density Gauge
What Affect the Pressure Measurement Accuracy of a Manometer?
Differential Pressure Sensor with Pair of Strain Gauges
Calculate the Voltage across Voltmeters of Thermocouple
How a Bourdon Tube Pressure Gauge might be Adjusted for Linearity?
Inductive proximity switches
How to Connect Proximity Switch (Source Type) to Make LED ON ?
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Programmable Logic Controller (PLC) Questions and Answers – 2
DP Transmitter Block and Bleed Valve
DP Transmitter Block and Bleed Valves
Motor ladder Logic
Which instrument is at fault in this system
Which Instrument is at Fault in this System?
Resistance Temperature Detector (RTD) Questions
Resistance Temperature Detector (RTD) Questions – 1
Calculate the 0%, 50%, and 100% Calibration Points
Hazards of Compressed Air
Paddle switch Working Principle
Paddle Switch Working Principle
DCS Vs PLC
DCS versus PLC Architecture
baffle nozzle Operation
Practical Pneumatic Instruments
Difference Between AA and AAA Batteries
Process Control & Instrumentation Objective Questions – Set 7
Reverse Voltage Characteristics of Photo diode
transmitters shared for BPCS and SIS
SIS Instrument Sharing – Transmitters Shared for BPCS and SIS Example
