Reading: Difference between AC and DC
Inst Tools > Blog > Electrical Basics > Difference between AC and DC
In this article, you will learn the difference between AC and DC. Compare the alternating current and direct current.
Last updated: May 7, 2023 1:05 pm
vicky
Electrical Basics
Electric current is defined as the flow of charged particles per unit time. In most conductive substances, these charged particles are electrons that exist within the molecular structure of the material.
Alternating Current (AC)Direct Current (DC)Difference between AC and DC
Some materials have tightly bonded electrons and while others have loosely bonded electrons that can move freely through the substance. These free electrons are negatively charged and their movement constitutes electric current.
Electric current is categorized into two types: Alternating Current (AC) and Direct Current (DC), depending on the flow of charged particles.
Alternating Current (AC) periodically changes the direction of its electric charge. AC supply is commonly used in household appliances, offices, and other equipment.
AC was first developed in 1832 using a Dynamo Electric Generator, based on the principles discovered by Michael Faraday.
Alternating Current
AC is depicted as a waveform called a sine wave as shown in the above figure, which measures the electric cycles per second. One complete cycle consists of a positive half-cycle and a negative half-cycle.
The frequency of AC is measured in Hertz (Hz), and in India, the AC supply frequency is 50 Hz. AC is easy to generate and transport across long distances, and it can power electric motors used in refrigerators, washing machines, and other household devices.
Direct Current (DC)
Direct Current (DC) flows in one direction with a steady voltage. DC supply is commonly used to charge batteries and to power electrical and electronic devices like mobile phone batteries, electric vehicles, and flat-screen televisions.
In DC circuits, electrons move from the negative side to the positive side. DC is produced by photovoltaic cells, batteries, or electrochemical cells.
The SI unit of electric current is Ampere, represented as A. The force needed to drive the flow of charged particles in a conductor is called voltage.
Understanding the differences between AC and DC is important for anyone working with electrical or electronic devices.
The following table shows the comparison between alternating current and direct current.
AC is safe to transfer over long distances while maintaining electric power, even up to the distance of two cities.DC cannot travel for long distances as it loses power.
In AC, the electrons change their direction periodically from forward to backward or vice versa.Photovoltaic cells, batteries, and electrochemical cells are the sources of DC current.
The frequency of AC circuits is typically between 50-60 Hz.DC current does not have a frequency; its frequency is zero.
AC generators are the primary source of AC power.AC current has three types: sinusoidal AC, triangular, and square trapezoidal AC.
The direction of current flow changes due to rotating magnets in AC.DC current has two types: pure DC and pulsating DC.
High energy loss is observed in DC, so it is not preferred when transmitting over large distances.No change in the direction of current flow is seen in DC due to steady magnetism.
Less energy loss occurs during transmission in AC compared to DC.The voltage or current level cannot be changed in the DC supply.
AC supply can be stepped up or stepped down based on the requirement.The voltage or current level cannot be changed in DC supply.
It is not possible to store AC power in batteries.DC can be stored in batteries.
  • What is a Buchholz Relay?
  • Importance of Neutral Wire
  • Induction Motor Problems
  • Cables between VFD & Motor
  • What is a Current Transformer?
Why Are Charcoal and Salt Added to an Earthing Pit?
Download Electrical Enclosure Book
What is Torque Boosting in Variable Frequency Drive (VFD)?
Top 100 Electrical Machines Projects for Electrical Engineers
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Lightning Arrester Basics and Terminology
  • Trevor Kalubangwe says:
    May 7, 2023 at 8:35 pm
    Interested in learning electricity
Partial Discharge in Power Lines and its Detection through Sensors
Difference between Soft Starter and VFD
Why do we need to Control the Motion using VFD drives?
Electrical Engineering Documents – Engineers Questions
Industrial Circuit Breakers – Most Common Types – Principle
Difference Between RCCB and MCCB
Motor Control Timer Circuit – Automatic Motor START and STOP
Basics of Electrical Transformer
Difference between MCB and RCBO
Difference Between MCB and RCBO
What is an ELV System - Extra Low Voltage
What is an ELV System? – Extra Low Voltage
Garage Door Roller Shutter
Three phase induction motor nameplate
How to Size a Cable for Industrial AC Motors?
Why is IGBT used in VFD
Why is IGBT used in VFD?
Difference Between Regenerative and Dynamic Braking
Safety Tips When Working With Electricity
Difference between Signal Cables and Control Cables
Digital Electronics MCQ
Digital Integrated Circuits Objective Questions – Part 2
What is Pump Redundancy
What is Pump Redundancy?
Specific-Conductance-Calibration-Procedure
Specific Conductance Calibration Procedure
What is Multi-touch Technology
What is Multi-touch Technology? – Industrial Automation
Advantages and Disadvantages of Per Unit System
Force Commutated Inverters Objective Questions
Comparators Objective Questions
