Reading: Dew Point Meter Principle
Inst Tools > Blog > Analyzers > Dew Point Meter Principle
Last updated: January 26, 2019 7:23 pm
Analyzers
3 Min Read
By Cooling at constant pressure if the temperature of air is reduced, the water-vapour in the air will start to condense at a particular temperature. This temperature is called dew point temperature.
Description of Dew Point Meter
The main Parts of arrangement are
  • A shiny surface (mirror) is fixed with a thermocouple.
  • A nozzle is providing a jet of air on the mirror.
  • A light source focused constantly on the mirror.
  • A photo cell to detect the amount of light reflected from the mirror.
Operation of Dew Point Meter
  • The mirror is constantly cooled by a cooling medium. The cooling medium is maintained at a constant temperature.
  • To this mirror is attached a thermocouple whose leads are connected to a millivoltmeter.
  • Constantly a light is made to fall in an angle on the mirror and the amount of reflected light is sensed by a photo cell.
  • Now an air jet is made to fall in an angle on the mirror and the water-vapor (moisture) contained in the air starts condensing on the mirror and they appear as small drops (dew) on the mirror.
  • This moisture (dews) formed on the mirror reduces the amount of light reflected from the mirror and it is detected by photocell. When for the first time, there is a change in amount of transmitted light; it becomes an indication of dew formation.
  • At this instance (that is, when the due formation is detected first), the temperature indicated by the thermocouple attached to the mirror becomes the dew point temperature.
  • Thus this arrangement is used to determine the time at which the dew appears for the first time and dew point temperature.
Application of dew point meter
  • This instrument is used on ships to protect cargoes from condensation damage by maintaining the dew point of air in holds lower than the cargo temperature.
  • Used in industries for determining dew point.
Limitations of dew point meter
There are limitations in cooling fluids and light measurement.
Sling Psychrometer Principle
Fluorescence
Humidity Sensor Working Principle
Total Organic Carbon Analyzers Questions and Answers
Ozone Analyzer Working Principle
What is the Application of Electrical Conductivity Meter?
  • muhammed enes erünal says:
    December 21, 2020 at 3:52 pm
    Could you inform me about DEW point meter application on transformers? İn the transformers there is nitrogen gas because of protection before oil filling process. I want to learn how we can test the DEW point on transformers?
    Thank you in advance
NDIR Analyzer Filter Cells
Analytical Standards
Kiln Inlet Gas Analyzer
What is Gas Chromatography?
Conductivity Analyzers Interview Questions & Answers
Humidity Sensing Absorption Hydrometer Principle
Analyzer Sample Systems
Thermal Conductivity Detector (TCD)
Thermal Conductivity Detector (TCD) Principle
4-wire pH Transmitter Problem
H & B Gas Analyzer Principle and Calibration Procedure
Moisture Calculator
Moisture Calculator
peak of a chromatogram
Measuring Gases Concentration in Chromatograph
Gas Analyzers Interview Questions
Gas Analyzers Interview Questions and Answers
dispersive gas analyzer
Dispersive Spectroscopy
NDIR GAS ANALYSER WORKING PRINCIPLE ANIMATION
NDIR Gas Analyser Working Principle
Ziegler-Nichols open-loop Tuning
Ziegler-Nichols Open-Loop Method
Gas Chromatography Questions & Answers
HAZOP
What is HAZOP ?
Microwave Barrier Level Switch Working Principle
Read Only Memory (ROM) Objective Questions – Part 2
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
Induction Motor Protection Interview Questions
Induction Motor Protection Interview Questions Answers
Air Pre-heater
What is an Air Pre-heater? – Types, Working, Advantages
