Reading: Dahlander Motor Control Circuit and Power Circuit
Inst Tools > Blog > Electrical Basics > Dahlander Motor Control Circuit and Power Circuit
In this article, you will learn the dahlander motor control circuit and power circuit diagrams and their explanation.
Last updated: September 28, 2022 2:22 pm
Hussien Ghareb
Electrical Basics
Welcome back, in the last article “The Idea Behind Dahlander Motors” we were curious about the need for Dahlander motors and we learned the main idea beyond these motors also when and how to use these types of induction motors.
Power Circuit of a Dahlander MotorControl Circuit of the Dahlander Motor
Today we are going more practically by discussing the dahlander motor control circuit and How it could be performed using the “classic control circuit design”.
Dahlander Motor
As we discussed before, the speed control of the normal Induction motors is not simple and can be made by adjusting two different factors (Frequency of the power source, Number of poles in the motor winding).
Dahlander motor is nothing more than a two-speed induction motor and we can handle these two speeds by switching the configuration of the electrical windings, indirectly adding or removing poles, and thus varying the rotor speed.
For further explanation please find the previous post (“Dahlander Motors”)
Here in below figure we can see the power circuit diagram for a Dahlander motor, the circuit consists of:
Protection Element: we can see (F1) that represents the protection fuse for the power circuit this element could be replaced by a suitable circuit breaker or motor overload, it depends on your application and the desired response of your protection element.
Delta connection contactor (K1):
This contactor is responsible for connecting the internal coils of the dahlander motor as a delta connection to set the lower speed. The respective image is shown on the left side of the below image.
The power supply phases should be connected at [U1, W1, V1] using K1 contactor.
Double star contactors
Double star contactors (K2 – K3):
These two contactors are responsible for connecting the internal coils of the dahlander motor as a double star connection to set the highest speed. The respective image is shown on the right side of the above image.
The power supply phases should be connected at [U2, W2, V2] using K3 contactor, and [U1, W1, V1] should be shorted using K2 contactor.
Here we can see the below Figure the control circuit of a Dahlander Motor.
This motor is controlled by three stop (NC) push buttons, (STOP1) to stop the two stages of the motor, (STOP2) to stop the delta stage, and (STOP3) to stop the double star stage.
Also, there are two start (NO) push button, one for the delta stage and the other for the Double star stage.
There must be an electrical interlock between the two stages to prevent any hazards (like phases shortage) when you are switching between the two stages.
DOL Starter Circuit Diagrams
Earth Leakage Circuit Breaker
Star Delta Starter Circuit Diagrams
Control Two Motors after Time Delay
Thermal Protection Relay for Motors
Motor Maintenance, Troubles, Regular Checks, Performance
How to Size a Cable for Industrial AC Motors?
What are Switchgear Interlocks?
What is insulation? How to Choose the Insulation Material?
  • Gratius says:
    February 12, 2023 at 9:32 pm
    my name is Uwiragiye From Rwanda how can i get a dahlander motor
Partial Discharge in Power Lines and its Detection through Sensors
Electrical Terminology
Motor VFD Drive features
Why Circuit Breakers Don’t Protect People?
MCB vs Fuse Questions and Answers
Electric Motor Winding Temperature Sensors
What is a Power Transformer? – Components and Types
Difference Between RCCB and MCCB
LCS Configuration equipped with LOTO Facility
VFD Commissioning and Testing Procedure
Difference Between Metering CT and Protection CT
Types of MCB
Types of MCB
Semiconductor Fuse
What is a Semiconductor Fuse?
Lead Acid Battery Operation
How does a Lead Acid Battery Work?
Rotary Encoder
Rotary Encoder Interview Questions and Answers
Why is HV Testing important in Electrical Panels?
Parity Generators Objective Questions
Classification of HVAC chillers
Classification of HVAC Chillers
Induction Motor Operating Characteristics
PLC datasheet
How to Read the PLC Datasheet? – Important Notes About PLC
Why are Impulse Lines often Installed in a Sloping Manner (Angle)
Why are Impulse Lines often Installed in a Sloping Manner?
Vibration Sensor
Vibration Probes Questions and Answers
interview-questions-and-answers-on-natural-gas
Oil and Gas Interview Questions Answers
Level Measurement Objective Questions
Level and Density Measurement Objective Questions
