Reading: Create a Function (FC) for a Valve Logic in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Create a Function (FC) for a Valve Logic in Siemens PLC
Last updated: March 4, 2021 2:43 pm
Let us study how to create a Function Block (FC) for a Valve Control Logic in PLC. This article focuses on Siemens function block programming for the control valve with example.
Valve LogicCreate a Function (FC) in Siemens PLCFC Block
Valve Logic
There are two valve functions in this application. Valve opening and closing can be controlled by giving OPEN and CLOSE commands. So Consider two outputs for valve open command and valve close command.
Valve Control Logic
When we need to write a logic for many valves in a plant then we use the FC blocks. So here we will write the logic for the valve by using the FC block.
For example, we have one valve to control it manually from PLC. So we need two buttons in the graphics for controlling the valve position, i.e. for valve opening and valve closing.
An operator will press the valve open button for the valve opening position. Similarly, the operator press the valve close button for the valve closing position.
Valve has the two proximity switches installed on it to know the valve position. So, two feedback signals will be generated for the open position and also for the close position. So PLC will receive these feedback signals and display the valve status on the graphics.
In this example, we will take FC block and write the logic for the valve. Declare all temporary variables in the table.
After configuration of FC, take OB 1 and call FC in OB 1. You Call this FC block many times in the logic. Use the FC block for each time when you want to implement the control logic for the valves.
For example, we will consider one valve control logic.
PLC Valve Control Example
List of Inputs:-
  • I0.0:- valve Open
  • I0.1:- Valve close
List of Outputs:-
  • Q0.0:- Valve ON
  • Q0.1:- Valve Open Command
  • Q0.2:- Valve Close Command
OB1:- Organization block for valve control logic. FC 1 is called in OB 1. As shown in the below figure we can drag FC 1 in OB 1 for valve control logic.
Create a Function (FC) Siemens PLC
FC Block
We have called FC 1 only for one valve in the OB1. Generally, FC can be called multiple times. If there are more valves in the application, FC 1 can be called for another valve also, no need to write logic every time.
For FC, no need to create separate DB like FB configuration. Here when we press the valve open (I0.0), the valve (Q0.0) will be ON and if the valve close (I0.1) is pressed, the valve will be closed.
Control Valve Function in PLC
FC 1:- In Simatic manager, we can configure FC or another block by clicking on insert new object.
Add Function in the program as shown in the below figure.
Configure FC block in Simatic Manager
After FC configuration, declare all temporary variables in the table as shown in the below figure.
FC configuration in PLC
Network 1:-
In this network, we have taken a temporary variable for valve ON/OFF. By pressing the valve open, valve can be opened and by pressing the close button, valve can be closed.
Valve Open Ladder Logic
Network 2:-
If the valve (Q0.0) is ON, Valve open command (Q0.1) should be ON.
Valve Open Command in PLC
Network 3:-
If the valve (Q0.0) is ON, valve close command (Q0.2) should be ON.
Valve Close Command in PLC
As per the above explanation, you can write the logic for other valves also. Call FC in OB 1 for the second valve and configure the inputs and outputs.
Note:- This is the simple example for the FC block used for valve application in PLC, we can use this concept in other examples also.
Author: Bhavesh
Control Valve Ladder Logic
PLC Tank Filling Logic
Proximity Switch Principle
Solenoid Valve Working
Motor Control using PLC
PLC vs PAC – Understanding the Key Differences and Similarities
What is Midline Instruction in Siemens PLC?
PLC Program for Star Delta Motor Starter
Basic Pumping System Application Used in Industrial Automation
PLC Project Examples for EcoStruxure Machine Expert
PLC Pump Control: 10 seconds ON & 20 seconds OFF
How to Read the PLC Datasheet? – Important Notes About PLC
What is NOR Flash Memory in PLC?
What is the DDE Protocol?
Automation System for Hazardous Environments
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
What is a Network Switch?
PLC Program for Tank Heating Control using Heater
PLC Programming for Tank Heating Control using Heater
PLC Program to Control Level of Two Tanks
PLC Level Control of Two Tanks
Sequential Operation of Output Bits using Two Push buttons
Flexible Input Output Modules
Preventive Maintenance of Variable Frequency Drive
Parameters of SRT_DINT instruction
Tia Portal – OB20 Time Delay Interrupt Organization Block
Block diagram Algebra Objective Questions
de-energized-to-safe-mode
Problem on Weigh feeder
wash column temperature control
Pneumatic Instrumentation
Selection of Fire and Gas Detectors
Basic Guidelines for Selection of Fire and Gas Detectors
Cleat Wiring
Types of Electrical Wiring
Capacitor Filter Operation
