Test your technical skills with our 150 computer networks multiple choice questions and answers.
Computer Networks Multiple Choice Questions
The sample 25 questions are listed below.
Question 1:
Which one of the following is a data link protocol?
A) point to point protocol
B) HDLC
C) Ethernet
D) all of these answers
Question 2:
Data communication system within a building or campus is
A) MAN
B) LAN
C) WAN
D) None of these answers
Question 3:
The transmission data rate is decided by
A) transport layer
B) network layer
C) data link layer
D) physical layer
Question 4:
The term ‘duplex’ refers to the ability of the data receiving stations to echo back a confirming message to the sender.
In full duplex data transmission, both the sender and the receiver ______
A) can send or receive data one at a time
B) can receive and send data simultaneously
C) can do one way data transmission only
D) cannot talk at once
Question 5:
The network layer protocol of the internet is
A) hypertext transfer protocol
B) internet protocol
C) Ethernet
D) none of these answers
Question 6:
CRC stands for
A) cyclic redundancy check
B) code redundancy check
C) code repeat check
D) cyclic repeat check
Question 7:
Application layer protocol defines
A) types of messages exchanged
B) message format, syntax and semantics
C) rules for when and how processes send and respond to messages
Question 8:
TCP/IP model does not have _________ layer but OSI model have this layer.
A) presentation layer
B) application layer
C) both session layer and presentation layer
D) session layer
Question 9:
Most packet switches use this principle
A) None of these answers
B) Store and forward
C) Both Stop and wait & Store and forward
D) Stop and wait
Question 10:
Which of these is not a guided media?
A) Fiber optical cable
B) Wireless LAN
C) Copper wire
D) Coaxial cable
Question 11:
Coding schemes can be divided into two broad categories ________
A) Block Coding and Convolution Coding.
B) Hamming coding and convolution coding
C) character coding, integer coding
D) hamming coding and block coding
Question 12:
Which one of the following tasks is not done by the data link layer?
A) framing
B) channel coding
C) flow control
D) error control
Question 13:
A) framing
B) channel coding
C) flow control
D) error control
Question 14:
Data Link Control Protocol (HDLC) is implemented at the _________
A) Data link layer
B) Network layer
C) transport layer
D) Physical layer
Question 15:
A distributed network configuration in which all data/information pass through a central computer is
A) All of these answers
B) star network
C) bus network
D) ring network
Question 16:
OSI stands for
A) none of these answers
B) operating system interface
C) open system interconnection
D) optical service implementation
Question 17:
A _________ is a device that forwards packets between networks by processing the routing information included in the packet.
A) firewall
B) all of these answers
C) router
D) bridge
Question 18:
In OSI network architecture, the dialogue control and token management are responsibilities of?
A) session layer
B) network layer
C) data link layer
D) transport layer
Question 19:
The physical layer translates logical communication requests from the ________ into hardware-specific operations.
A) network layer
B) transport layer
C) data link layer
D) application layer
Question 20:
TCP/IP model was developed _________ the OSI model.
B) prior to
C) simultaneous to
D) after
Question 21:
Which transmission media has the highest transmission speed in a network?
A) electrical cable
B) optical fiber
C) coaxial cable
D) twisted pair cable
Question 22:
HTTP refers to?
B) Hyper Text Transmission Protocol
C) Hyper Text Transfer Protocol
D) Hyper Text Tie Protocol
Question 23:
Communication circuits that transmit data in both directions but not at the same time are operating in
A) a simplex mode
B) a half-duplex mode
C) an asynchronous mode
D) a full-duplex mode
Question 24:
In the IEEE standards, 802.5 standards is also called?
A) Token Ring
B) Ethernet
C) Wireless Token Area Network
D) Token Bus
Question 25:
Each IP address can identify the _________ or ________ of IP packets.
A) source, length
B) source, destination
C) length, size
D) Size, destination
Click on the below button to launch the Quiz. Each question carries 1 mark. You have to score 50% of the marks to pass the test.
All 100 questions and answers are available in the Quiz.
Share your suggestions through the comments section.
Next Quiz:
