Reading: Bourdon Tube Pressure Gauge Working Principle Animation
Inst Tools > Blog > Animation > Bourdon Tube Pressure Gauge Working Principle Animation
Last updated: September 13, 2016 11:23 am
Animation How It Works Pressure Measurement
12 Comments
2 Min Read
Bourdon Tube Working Principle Animation
Bourdon tube pressure gauges are extensively used for local indication. This type of pressure gages were first developed by E. Bourdon in 1849. Bourdon tube pressure gauges can be used to measure over a wide range of pressure: form vacuum to pressure as high as few thousand psi. It is basically consisted of a C-shaped hollow tube, whose one end is fixed and connected to the pressure tapping, the other end free, as shown in fig. The cross section of the tube is elliptical.
pressure-gauge-animation
When pressure is applied, the elliptical tube (Bourdon tube) tries to acquire a circular cross section; as a result, stress is developed and the tube tries to straighten up. Thus the free end of the tube moves up, depending on magnitude of pressure. A deflecting and indicating mechanism is attached to the free end that rotates the pointer and indicates the Pressure reading. The materials used are commonly Phosphor Bronze, Brass and Beryllium Copper. For a  2″ overall diameter of the C-tube the useful travel of the free end is approximately 1/8″ . Though the C-type tubes are most common, other shapes of tubes, such as helical, twisted or spiral tubes are also in use.
Also See: Proximity Sensor Working Animation
Metal Foil Strain Gauge Principle
Infrared Non Dispersive CO2 Analyzer Working Principle
Control Valve Working Animation
Gas chromatograph Working Animation
Pressure Gauges with Capsule Sensor Principle
Pressure and Temperature Gauges
12 Comments
  • gajendra says:
    November 24, 2015 at 6:02 am
    What a great site and very good animations, gives the solution even just looking at the animation .salute you
  • Tarun says:
    May 28, 2016 at 1:33 am
    What a teaching style!!!!!
  • onoja friday says:
    June 1, 2016 at 3:02 pm
    What are the difference between Bourdon tube manometer and bourdon tube pressure gauge. What I am searching for is the formal but the latter keep appearing
  • Akshay says:
    July 5, 2016 at 3:42 am
    Great Animation
  • Aung Kaung Myat says:
    January 31, 2017 at 2:30 am
    I would like to get quotation for Pressure Guage.
    • S Bharadwaj Reddy says:
      January 31, 2017 at 6:11 am
      Hi, No sales here, only knowledge sharing. Thanks
  • niharika says:
    April 21, 2017 at 11:24 am
    Good work. thank you
  • Thandanani Vumani says:
    December 14, 2017 at 11:55 am
    How i wish i knew this site when i was a student!
  • hyela danboyi says:
    December 19, 2017 at 9:09 pm
    Good work. Thank you
  • Sreekutty V L says:
    December 30, 2017 at 5:53 am
    thank youuu
  • lily1987 says:
    October 22, 2019 at 7:33 am
    Animation is vivid , really good article.
  • Sairam K says:
    July 9, 2020 at 10:35 pm
    what an animation, the animation tells us the way it works.
208kSubscribersSubscribe
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
Anti Surge Controller Working Principle
Basics of Globe Valves
Temperature Switch Working Principle
Difference between Absolute, Gauge and Differential Pressure Transmitters
Normally-open and Normally-closed Switch Contacts
Pressure Gauge Cocks
Pressure Transmitter Calibration Procedure
Pressure Transmitter Circuit
Pressure Gauge Accessories
Pressure Gauge Accessories Questions and Answers
hall-effect-sensor
Hall Effect Sensor Working Principle Animation
Motor contactors
What is Contactor ?
Uncertainty Calculations of Pressure Calibration
Diaphragm seal for pressure measurement device
When to use a Diaphragm Seal?
Barometer Principle
What is a Barometer?
Pressure Gauge Parts
Pressure Gauges with Bourdon Tube Principle
Typical schematic of Butterfly valve
Automated Block Valve (ABV)
NPT Connections
Difference Between NPT, BSPP and BSPT Seals
Deluge System for Transformer Protection
Deluge System for Transformer Protection Animation
PLC Raw Count Calculation formula for Pressure Transmitter
PLC Raw Count Calculation for Pressure Transmitter
The STAR-DELTA Auto And Manual Program
What is a Current Transformer
What is a Current Transformer?
Difference Between Isolator and Circuit Breaker
