Reading: Bode Plots MCQ
Inst Tools > Blog > Multiple Choice Questions > Bode Plots MCQ
Bode Plots MCQ
7 Min Read
Bode Plots MCQ
1. Assertion (A): Relative stability of the system reduces due to the presence of transportation lag.
Reason (R): Transportation lag can be conveniently handled by Bode plot.
a) Both A and R are true but R is correct explanation of A
b) Both A and R are true but R is correct explanation of A
c) A is true but R is false
d) A is false but R is true
Answer: b
Explanation: Transportation lag can be conveniently handled on Bode plot as well without the need to make any approximation.
2. Assertion (A): The phase angle plot in Bode diagram is not affected by the variation in the gain of the system.
Reason(R): The variation in the gain of the system has no effect on the phase margin of the system.
Answer: c
Explanation: The variation in the gain of the system has effect on the phase margin but phase plot is not affected.
3. A system has poles at 0.01 Hz, 1 Hz and 80Hz, zeroes at 5Hz, 100Hz and 200Hz. The approximate phase of the system response at 20 Hz is :
a) -90°
b) 0°
c) 90°
d) -180°
Answer: a
Explanation: Pole at 0.01 Hz gives -180° phase. Zero at 5Hz gives 90° phase therefore at 20Hz -90° phase shift is provided.
4. The constant M-circle represented by the equation x^2+2.25x+y^2=-1.25 has the value of M equal to:
a) 1
b) 2
c) 3
d) 4
Answer: c
Explanation: Comparing with the M circle equation we have the value of M =3.
5. What is the value of M for the constant M circle represented by the equation 8x2+18x+8y2+9=0?
a) 0.5
b) 2
c) 3
d) 8
Answer: c
6. The constant N loci represented by the equation x^2+x+y^2=0 is for the value of phase angle equal to:
a) -45°
b) 0°
c) 45°
d) 90°
Answer: d
Explanation: Centre = (-0.5, 0)
Centre of N circle is (-1/2, 1/2N)
N =tanα
α =90°.
7. All the constant N-circles in G planes cross the real axis at the fixed points. Which are these points?
a) -1 and origin
b) Origin and +1
c) -0.5 and 0.5
d) -1 and +1
Answer: a
Explanation: Centre of N circle is (-1/2, 1/2N)
N =tanα
Constant –N circles always pass through (-1, 0) and (0, 0).
8. Consider the following statements:
Nichol’s chart gives information about.
i. Closed loop frequency response.
ii. The value of the peak magnitude of the closed loop frequency response Mp.
iii. The frequency at which Mp occurs.
Which of the above statements are correct?
a) 2 and 3
b) 1 and 2
c) 1 and 3
d) 1,2 and 3
Answer: d
Explanation: Nichol’s chart gives information about closed loop frequency response, value of the peak magnitude of the closed loop frequency response Mp and the frequency at which Mp occurs.
9. Which one of the following statements is correct? Nichol’s chart is useful for the detailed study analysis of:
a) Closed loop frequency response
b) Open loop frequency response
c) Close loop and open loop frequency responses
d) None of the above
Answer: a
Explanation: Nichol’s chart is useful for the detailed study analysis of closed loop frequency response.
10. In a bode magnitude plot, which one of the following slopes would be exhibited at high frequencies by a 4th order all-pole system?
a) -80dB/decade
b) -40 dB/decade
c) 40 dB/decade
d) 80 dB/decade
Answer: a
Explanation: A 4th order all pole system means that the system must be having no zero or s-term in numerator and s4 terms in denominator. One pole exhibits -20dB/decade slope, so 4 pole exhibits a slope of -80 dB /decade.
11. Frequency range of bode magnitude and phases are decided by :
a) The lowest and higher important frequencies of dominant factors of the OLTF
b) The lowest and highest important frequencies of all the factors of the open loop transfer function
c) Resonant frequencies of the second factors
Answer: d
Explanation: T. F. = Kp (1+Tds)
There is only one zero which will give slope of +20dB/decade.
12. OLTF contains one zero in right half of s-plane then
a) Open loop system is unstable
b) Close loop system is unstable
c) Close loop system is unstable for higher gain
d) Close loop system is stable
Answer: c
Explanation: OLTF contains one zero in right half of s-plane then Close loop system is unstable for higher gain.
13. The critical value of gain for a system is 40 and gain margin is 6dB. The system is operating at a gain of:
a) 20
b) 40
c) 80
d) 120
Answer: a
Explanation: Gm (dB) = 20log⁡GM
GM =2
As we know, GM =K (marginal)/K (desired)
K desired =40/2 =20.
14. Nichol’s chart is useful for the detailed study and analysis of:
d) open loop and Close loop frequency responses
Answer: a
Explanation: Nichol’s chart is useful for the detailed study and analysis of closed loop frequency response.
15. The roots of the characteristic equation of the second order system in which real and imaginary part represents the :
a) Damped frequency and damping
b) Damping and damped frequency
c) Natural frequency and damping ratio
d) Damping ratio and natural frequency
Answer: b
Explanation: Real part represents the damping and imaginary part damped frequency
Level and Density Measurement Objective Questions
NO2 Analyzer Questions & Answers
The Infinite Time Regulator Problem
Concept of Stability in Control Systems
Adaptive Control
The Z-Transfer Function
Nyquist Stability Criterion
Pulse Height Analyzer Questions & Answers
Controllability & Observability
Pumps Quiz
Electrical Measurements and Instrumentation Objective Questions & Answers
Measurement and Instrumentation Objective Questions – Part 1
Sulphur Di-oxide Monitoring Questions & Answers
Time Response Analysis
Steady-state Errors & Error Constants
Differential Equations of Physical Systems & Dynamics of Robotic Mechanisms
Nonlinear Control Systems
Construction of Phase -Trajectories
Ion Analyzers Questions and Answers
Ammonia and Fluoride Electrode Questions & Answers
Sensivity Enhancement for NMR Spectroscopy Questions & Answers
Liquid Chromatography Questions & Answers
Liquid Scintillation Counters Questions & Answers
Commissioning Checklist for Industrial Automation System
Commissioning Checklists for Industrial Automation Systems
PLC Hoist Crane Programming
Rotor Angle Stability of Synchronous Generators in Power System
electric valve actuator
Electrical Actuators
Practical Level Sensors Questions and Answers
Measurements & Instrumentation Quiz – Set 2
Cable Shield
High-frequency Signal Cables
pH sensor calibration procedure
