Reading: Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Inst Tools > Blog > Electrical Basics > Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Last updated: September 19, 2016 1:45 am
Electrical Basics
2 Min Read
Valve Regulated Lead Acid (VRLA) Batteries are popularly termed as maintenance free lead acid batteries. Each cell in VRLA battery will have a value (automating operating) to allow the gas to escape if developed by the over charging the cells and to hinder the entrance of oxygen from the air into the cell
These VRLA batteries are also called sealed lead acid batteries and also recombinant batteries. Oxygen which evolve during discharging at the positive plate of the battery recombine with the hydrogen which  evolve at the negative plate of the cell to from water. This results in prevention of the water loss and unlike flooded batteries water is not needed to be added periodically. The valve present in VRLA cell acts as a safety valve which opens when the concentration of hydrogen gas inside the battery increases dangerously high. Some of the advantages of VRLA cell is listed below:
Advantages:
  • VRLA battery is maintenance free and no periodic water refilling is not required
  • Reduced demand on ventilation
  • The capacity range of VRLA battery is high (12000 Ah)
  • VRLA batteries will have longer life. Life span of this batteries will be around 10 years
  • Feasibility for float charge operation with the same voltage of the cells, to continue in using existing charging equipment
  • VRLA batteries are economical
What is Electrical Busbar? Types, Advantages, Disadvantages
Variable Frequency Drive (VFD) Working Principle
Difference Between Trunking and Conduit
Difference between Stepper Motor and Servo Motor
Single Phase versus Three Phase Power
What is Megger Test?
Motor STAR – DELTA Starter Working Principle
Why is Phase Failure Relay Required in LV Panels?
Importance of Neutral Wire
Testing and Inspection of Bonding and Grounding Systems
Motor Cooling Methods
What is an Electrical Drive? Types, Advantages, Disadvantages
Motor Maintenance, Troubles, Regular Checks, Performance
Single Line Diagram (SLD) Example
Electrical Drawings
Dahlander Motor
Dahlander Motors – Principle, Advantages, Disadvantages
Switched Mode Power Supply (SMPS)
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
Star and Delta Wiring Animation
Why is White Powder Used in Electrical Cables
Why is White Powder Used in Electrical Cables?
Electric Stress Control in Cables, Joints and Terminations
Electric Stress Control in Cables, Joints, and Terminations
Drum water level control
Closed Loop Control System : Boiler Water Level Control System
Industry 4.0
Industry 4.0
Disadvantages of Resistance Temperature Detectors (RTD)
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 1
ORP-sensor-calibration
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
PLC Program to Drain Same Products from Two Tanks
