Reading: Working Principle of Single Phase Preventer Relay
Inst Tools > Blog > PLC Tutorials > Working Principle of Single Phase Preventer Relay
In this post, we will learn the working principle of a single-phase preventer relay, their types, applications, and advantages.
Last updated: October 17, 2023 1:55 pm
In this post, we will learn the working principle of a single-phase preventer relay.
Single Phase Preventer RelayApplicationsTypesWorking Principle
A three-phase supply drives the control components and field devices of an electrical panel. The controlling part is done by PLC.
As the outputs are controlled by PLC, if the three-phase supply fails, then there must be some means to protect the field devices from operating.
Because, if there is any phase failure and still the field device is operating, then it may damage it. If one supply fails, then still the field device like motor will continue to operate.
This will increase the load current in the remaining two phases and result in an unbalanced stator current. This can damage the motor windings.
This protection can be done by a single-phase preventer relay. A single-phase preventer relay is a control device that detects any failure in phase supply and energizes its auxiliary relay contacts.
This contact is then given to the PLC which turns off its outputs through programming written.
Applications
Generally, this relay can be used to protect the circuit against the following types of failures –
  • over-voltage,
  • under-voltage,
  • over frequency,
  • under frequency,
  • asymmetry,
  • phase failure, etc.
Types
This relay works by two methods –
  1. current sensing and
  2. voltage sensing.
Both these types continuously monitor the phase sequence and if any failure occurs, then the internal trip circuit activates the relay contacts and sends a trip signal to the PLC.
Different types of single-phase preventer relays
Working Principle
Refer to the image (right-side) above for reference. It generally has 8 terminals. 3 terminals are for 3-phase supply, 2 terminals are for single-phase supply powering the relay device and 3 terminals are for auxiliary contacts.
The device has many settings for timers and other control parameters for accurately monitoring the phase sequence. The circuit inside continuously monitors the unbalance phase sequence or abnormal phase operation, and activates the relay output.
Corresponding logic is written in the PLC to sense the digital input given from this relay and turn off all the outputs. This will disconnect the motor or other field equipment from the three-phase supply and protect it from damage.
Practically, there are many causes that result in phase failure. Sometimes, the contactors of a motor may get open-circuited; or one of the fuses of any three-phase supply gets blown or melts; or the contactors are coated due to oxidation which will cause it to become non-conducting, etc.
In any case, the wrong phase supply can damage the windings of the motor and so, it is necessary to use this device to prevent any untoward incident.
  • Compare Single-phase and Three-phase Power
  • How to Prevent Ground Loop in Analog Circuit?
  • PLC Programming Question and Answer
  • Three-Phase Rectifier Quiz
  • Single Phase Induction Motor Questions
How to Connect PLC with SCADA System via OPC UA?
PLC Raw Count Calculation for Pressure Transmitter
Smart Spray System using Wecon PLC
Motor Starter Logic using Siemens PLC Tia Portal
What is a Floating License? – Automation Software Systems
Controlling of Tank Level Using Proportional Controller in PLC
How to Use Modbus Poll and Modbus Slave Software?
What is Thin Client in SCADA? – Purpose, Advantages
Difference Between PLC and SCADA
PLC Program for Flow Totalizer
How to Troubleshoot a PLC System?
Wet Contacts and Dry Contacts in PLC Systems
PLC Program for Temperature Control using Thermostat
Masked Move Instructions
How to use Masked Move Instruction in PLC
PLC Automatic Control of Two Outputs with one Input
Communication between Intouch Scada and Allen Bradley PLC
Communication between InTouch Scada and Allen Bradley PLC
Types of Scan Time in a PLC
Programmable Logic Controller (PLC) Scan Time – Types, Theory
Difference between Signal Cables and Control Cables
Laws of Boolean Algebra using Ladder Logic
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
Difference Between Permittivity and Permeability
Fiber Optic Sources and Detectors Questions
Fiber Optic Sources and Detectors Questions and Answers
RTD lead resistances Wiring
Resistance Temperature Detectors Working Principle
Center Tapped Full Wave Rectifier Operation
Basics of Anti-Surge Control System
What is Anti Surge System?
Compressor IP Case Discharge Temperature Gradually Increases
Compressor Anti-Surge Control near-miss incident
Measure Duty Cycle using Multimeter
How to Measure Duty Cycle using Multimeter
