Reading: What is Wellhead Control Panel?
Inst Tools > Blog > Control Systems > What is Wellhead Control Panel?
It is very common in the oil & gas plant to control its oil or gas well through a wellhead control panel (usually called WHCP).
Last updated: November 23, 2020 3:11 pm
Control Systems
4 Comments
2 Min Read
Well Head Control Panel (WHCP) controls vital safety parameters of well head platform and provide safe and sequential start-up and shutdown of production wells.
WHCP is designed to operate in “fail safe” mode. The purpose of the panel is to individually and collectively control offshore oil production wells. The WHCP also provide hydraulic pressure to control the actuation of the adjustable choke valves and HIPPS valves on the flow lines.
The following valves are usually connected to each well. They are
  • SSV (Surface Safety Valves)
  • Master Valves (MV)
  • Wing Valves (WV)
  • Down hole valve (DHV)
It is also designed to provide the necessary hydraulic pressure to hold all Wing Valves (WV), Master Valves (LMV & UMV) and Sub-Surface Safety Valves (SSSV) in the open position under normal conditions and to close these valves under abnormal / trip conditions.
The actual logic control for the individual solenoids within this system will be by the PLC/ESD system.
The signals from PLC system connected to the WHCP junction box will control (energize and de-energize) the solenoid valves in WHCP allowing the opening and closing of the wellhead valves.
Normally these solenoids will be energized after an interlocked opening sequence by the platform PLC program.
The WHCP includes 4 master solenoid valves:
  • To close the SSSV for all wells
  • To close the UMV for all wells
  • To close the LMV for all wells
  • To close the WV for all wells
More Information: What is WHCP?
Stroke Checking Procedure for GCV, SRV, IGV, and LFBV
100+ Questions and Answers on Industrial Automation and Control
Centrifugal Compressor Start Permissive and Interlocks
Anti Surge Controller Working Principle
What is DCS? (Distributed Control System)
4 Comments
  • Mahesh says:
    October 4, 2016 at 7:47 pm
    Hii
    But scssv need to open high hydraulic pressure , How much pressure is required for open scssv and ssv exp 200 bar, 150 bar How much pressure is need to open?
    • ahmed ramadan says:
      April 16, 2018 at 5:05 pm
      It depends on the Xmas tree and it’s valves
      some Xmas need 10000 PSI for SSSV and 5000 PSI for SSV .
      best regards
  • Prabhudasu Nedunuri says:
    February 16, 2017 at 6:15 am
    It is depends on the reservoir pressure. Some reservoir pressure is 5000 psi, so we must give more pressure to the scssv. Some WHCP panels like Petronash/petrotec company’s, they set to 6000 psi
  • Adnan Zaidi says:
    October 10, 2019 at 8:08 pm
    SSSV operating pressure is always 1.5 times greater than the bottom hole pressure ( Reservoir pressure ).
Hardwired I/O and Serial I/O – Differences Explained
Difference Between the Sinking and Sourcing?
Process Switches and Alarms
Motor Control using Modbus Communication and Hardwired Signals
How to Do Logic Checks During Plant Pre-Commissioning
Foundation Fieldbus – Advantages, Limitations, Architecture
Variable Speed Control of Propulsion Motor for VSI and CSI type Frequency Converters
Speed Control of Ship Electrical Motor Propulsion
Selector Control Function in DCS
Selector Control Functions
PID Controller Loop Tuning Questions and Answers
PID Controller Loop Tuning Questions and Answers – Part 2
Ziegler-Nichols open-loop Tuning
Ziegler-Nichols Open-Loop Method
Types of Wireless Technologies in Industrial Automation
Troubleshooting PLC Current Loops
Troubleshooting Current Loops with Voltage Measurement
Levels in Industrial Automation
Five Levels in Industrial Automation
PID Controller Tuning
How to tune a PID Controller ?
Megger Circuit Diagram
Multimeter & Megger Principle
Thermocouple Software compensation
Top 20 Service Business Opportunities in the Instrumentation Industry
Top 20 Instrumentation Service Business Opportunities in the Industry
RF Level Sensors Principle
RF Level Switches Working Principle
Non-Contacting-Radar-Level-Transmitter-Animation
Non Contacting Radar Level Transmitter Animation
Torque Tube Level Measurement Principle
Bourdon Tube Pressure Gauge Parts
valve packing assembly
What is Valve Packing ?
