In this blog, we listed VLSI Projects for engineering students based on VHDL, MATLAB, Verilog, Xilinx Software, and IEEE projects.
VLSI Projects
| S.No. | VLSI Projects |
| 1 | Adaptive Hold Logic for Aging-Aware Reliable Multiplier Design. |
| 2 | Optimized Design of Secure Differential Logic Gates for DPA Resistant Circuits. |
| 3 | Performance and Power Exploration in Binary64 Division Units. |
| 4 | Digital Phase-Locked Loop Supply Noise Cancellation with An All-Digital Approach. |
| 5 | Ultra-Low-Voltage Asynchronous Delta Sigma Modulator in a 130-nm Digital CMOS Process. |
| 6 | Speculative Adder: Inexact High-Speed and Low-Power VLSI Architecture |
| 7 | Structured Visual Approach to GALS Modeling and Verification for Communication Circuits |
| 8 | Quantum-Dot Cellular Automata X-bit x 32-bit SRAM Design. |
| 9 | FPGA-Based FIR Filter Design |
| 10 | Efficient Systolic Array Architecture Design for DWT. |
| 11 | ASIC Design and Implementation of a High-Speed RSA Encryption Processor. |
| 12 | Scalable NoC Microprocessor with 2.5D Integrated Memory and Accelerator |
| 13 | Technology Optimized LUT Based Bit-Parallel Multiplier for FPGAs. |
| 14 | Optimized 3×3 Shift and Add Multiplier Implementation on FPGA |
| 15 | Caching Partitioned Reconfigurations in Reconfigurable Systems for Hardware Support. |
| 16 | Reconfigurable Systems’ MAC Unit Enhancement Using Multi-Operand Adders. |
| 17 | Binary to RNS Converter Design for jn-Bit Dynamic Range Using Arithmetic Based Modulo. |
| 18 | ASIC Implementation of a Low-Latency Logarithmic Number System Unit. |
| 19 | Design of a High-Speed VLSI Architecture for QR Decomposition in MIMO Systems. |
| 20 | Fast Decoding Design for Critical Bits Using Single Error Correction Codes. |
| 21 | Systematic Cell Design Methodology for Energy and Area Efficient XOR/XNORs. |
| 22 | Cryptographic Multifunction Residue Architectures. |
| 23 | Architecture for Dual-Mode Double Precision Floating Point Division |
| 24 | Functional Broadside Test Generation for Integrated Circuits. |
| 25 | Low-Power CMOS Circuit for Piezoelectric Energy Harvesting |
| 26 | VLSI Architecture for Efficient Implementation of Bilinear Interpolation in Image Processing. |
| 27 | Recursive Discrete Fourier Transform: Software Implementation |
| 28 | Self-Healing Strategy for Cost-Effective Reliable Hardware Systems |
| 29 | Ternary Logic Circuits Synthesis in Emerging Device Technologies |
| 30 | Future VLSI Design: Ultra-Low Power Hybrid MTJ/CMOS Based Full-Adder |
| 31 | Enhanced Built-In Self-Repair Techniques for Embedded Memories Yield and Reliability. |
| 32 | FPGA-Based Bit Error Rate Performance Measurement in Wireless Systems. |
| 33 | SDC-SDF Architecture for Pipelined Radix-2 FFT with Normal I/O. |
| 34 | PEVA Strategy for Lifetime Extension of NAND Flash. |
| 35 | Key Distribution Server Based Data Security Scheme VLSI Implementation for RFID System. |
| 36 | Merging Functional Broadside Test Cubes for Low Power Test Generation. |
| 37 | Bandwidth Efficient QPSK Modulator Design for Low Power VLSI Implementations. |
| 38 | High-Speed All-Pass Transformation-Based Variable Digital Filters Design. |
| 39 | Novel Cross Parity Codes for Low-Complexity Multiple Error Correcting Architectures. |
| 40 | FPGA Configuration Frames Correction: Low-Cost Multiple Bit Upset. |
| 41 | Revisiting Reversible Booth’s Multiplier for Enhanced Performance. |
| 42 | CMOS Receiver Design for Dual Use of Power Lines in Design-for-Testability. |
| 43 | Combining kPartitioning Scheme and TMVP Block Recombination in Digit-Serial Multipliers. |
| 44 | VLSI Decoder Energy Consumption Analysis. |
| 45 | Comparative Analysis of 16-order FIR Filter using Various Multiplication Techniques |
| 46 | Flip Flop Grouping in Data Driven Clock Gating Design Flow. |
| 47 | Multi Precision Adders: Improving Arithmetic Operations. |
| 48 | FFT/IFFT Blocks Implementation for OFDM. |
| 49 | Enhanced Double Precision Floating Point Multiplier Implementation Using VHDL. |
| 50 | Vmin Failure Bias-Induced Healing in Advanced SRAM Arrays |
| 51 | High-Speed ASIC Implementation of a Lossless Data Compression Algorithm for Space Applications. |
| 52 | High-Level Transformations for Obfuscating DSP Circuits. |
| 53 | Design of All Optical Reversible Multiplexer with Mach-Zehnder Interferometer. |
| 54 | Distributed Arithmetic for Approximate Sum-of-Products Design |
| 55 | Weighted Partitioning in Multiplier-less Multiple Constant Convolution Circuits. |
| 56 | High-Speed Parallel CRC Implementation Based on Unfolding, Pipelining, and Retiming. |
| 57 | Binary Multiplier Design with a Memristor-Based Approach |
| 58 | Mixed-Precision Multiply-Accumulate Unit Design for Deep Learning Processors |
| 59 | Energy-Efficient FPGA Implementation of a Real-Time Neural Network-Based Speech Recognition System. |
| 60 | Convolutional Neural Networks: Low-Power Implementation of Mitchell’s Approximate Logarithmic Multiplication |
| 61 | Fault Tolerant Logic Cell Design for FPGA Applications |
| 62 | Adaptive Feedback Equalization for Designing Tunable Subthreshold Logic Circuits. |
| 63 | Advances in Logic Synthesis for Reversible Programmable Logic Arrays. |
| 64 | FPGA Implementation of a High-Efficiency Video Codec (HEVC) for 4K Video Streaming. |
| 65 | Architectural Design for a High Throughput Polar Codes List Decoder. |
| 66 | Architecture for Long Polar Codes with Partial Parallelism. |
| 67 | Efficient Adder Design for Approximate Computing with Configurable Accuracy |
| 68 | Low-Power Broad-Bandwidth Noise Cancellation Circuit Design for In-Ear Headphones. |
| 69 | ASIC Design of a High-Efficiency Turbo Code Encoder for Telecommunication Systems. |
| 70 | Safety-Critical Applications: FPGA Implementation of an Improved Watchdog Timer |
| 71 | VLSI Architecture of Parallel Multiplier–Accumulator Based on Radix-2 Modified Booth Algorithm. |
| 72 | Spurious-Power Suppression Technique for Multimedia/DSP Applications. |
| 73 | Mixed-Decimation MDF Architecture for Radix-2k Parallel FFT. |
| 74 | Digital Multiplierless Realization of the Two-Coupled Hindmarsh–Rose Neuron Model. |
| 75 | ASIC Design of a High-Performance Real-Time Video Codec for Virtual Reality Applications. |
| 76 | High-Performance VLSI Architecture for Reed-Solomon Decoders. |
| 77 | Circuit Complexity Reduction in Fractional-Order Differentiators and Integrators |
| 78 | ASIC Implementation of a Low-Power High-Efficiency GPS Signal Processing Core. |
| 79 | Design of a VLSI Architecture for Real-Time Video De-Interlacing. |
| 80 | Rail Clamp Design Using Comparator-Based Approach. |
| 81 | FPGA Integer Arithmetic Core Optimization through Efficient Scan Register Insertion. |
| 82 | FPGA-Based Implementation of a Real-Time Multi-Sensor Data Fusion System. |
| 83 | Non-Redundant Radix-4 Signed-Digit Encoding in Pre-Encoded Multipliers. |
| 84 | High-Speed, Energy-Efficient Carry Skip Adder for Broad Voltage Level Operation. |
| 85 | Enhanced Memory Reliability with Decimal Matrix Code Against Multiple Cell Upsets. |
| 86 | FPGA-Based VLSI Architecture for Real-Time Optical Flow Estimation in Autonomous Vehicles. |
| 87 | VLSI Design of a High-Speed Floating-Point Unit for Scientific Computing. |
| 88 | Hybrid Hardware/Software Floating-Point Implementations for Optimized Area and Throughput |
| 89 | VLSI Architecture for a High-Speed Real-Time Hough Transform Processor. |
| 90 | Flexible Memory BIST Architecture Design |
| 91 | Radix-4 Memory-Based FFT Utilizing DSP Slices for Efficient Implementation |
| 92 | Nano scale Circuit Design with Low-Power Noise-Immune Methodology Using Coding-Based Partial MRF |
| 93 | Logarithmic Multipliers for Low Power Error-Tolerant Applications |
| 94 | Low Complexity Implementation of LMS Adaptive Algorithm via Critical-Path Analysis. |
| 95 | 32-Bit 4×4 Bit-Slice RSFQ Matrix Multiplier for Rapid Processing |
| 96 | Track-and-Hold Amplifier with 55-GHz Bandwidth in Low-Power 28-nm CMOS. |
| 97 | Highly Accurate Analog Multiplier Circuit in Voltage Mode Implementation. |
| 98 | Approximate High-Radix Dividers Design and Efficient Implementation |
| 99 | Implementing Low Power 1-Bit Full Adder Utilizing Full-Swing Gate Diffusion Input Technique |
| 100 | Chip Design for Turbo Encoder Module Targeting In-Vehicle Systems |
| 101 | ASIC Design of a Low-Power High-Resolution Digital to Analog Converter for IoT Devices. |
| 102 | ASIC Implementation of a High-Speed Optical Flow Calculation Processor. |
| 103 | Super Gate Design Methodology for Graph-Based Transistor Network Generation. |
| 104 | OFDM Transmitter Design and Implementation in VHDL. |
| 105 | Combinational Logic Implementation in Successive Cancellation Decoders for Polar Codes. |
| 106 | Dual-Supply Applications: High-Speed Power-Efficient Voltage Level Shifter Design |
| 107 | FM0/Manchester Encoding for DSRC Applications Using SOLS Technique. |
| 108 | Convolution and Deconvolution High-Speed Algorithm. |
| 109 | Performance Degradation Tolerance in Cache Design by Exploiting Memory Hierarchies. |
| 110 | Programmable Test-per-Scan Logic BIST Modules Designing for Efficiency |
| 111 | Area-Efficient SCL Polar Decoder Optimization. |
| 112 | Error-Tolerant Approximate Radix-4 Booth Multipliers Design |
| 113 | Fixed and Reconfigurable Applications: A High-Performance FIR Filter Architecture. |
| 114 | Min-Sum LDPC Decoding for MLC NAND Flash with Intracell Bit-Error Exploitation. |
| 115 | Error Correction Code-Based Fault Tolerant Parallel Filters. |
| 116 | Scalable Systolic-Like Modular Multipliers for GF(2m) Based on Irreducible All-One Polynomials |
| 117 | Sequential Observation in POST for Automotive Functional Safety Assurance |
| 118 | Fundamental Energy Limits Enhancement in Field-Coupled Nano computing Circuits |
| 119 | Efficiency Retiming in Fixed-Point Circuits. |
| 120 | Static D-Latch Standard Cell Characterization Using an Efficient Setup Time Model. |
| 121 | High-Speed VLSI Architecture for Real-Time Processing of Synthetic Aperture Radar Data. |
| 122 | FPGA Implementation of a Real-Time Digital Video Stabilization Algorithm. |
| 123 | High-Speed Parallel LFSR Architectures Based on State-Space Transformations |
| 124 | Scalable Deep Learning Accelerator Unit on FPGA |
| 125 | Approximate 15-4 Compressor Multiplier Design and Analysis |
| 126 | Radix 8 Booth Multipliers with a Slack-based Pipeline Architecture for High Performance. |
| 127 | Area Efficient Reconfigurable Multimode Interleaver Address Generator for Radios. |
| 128 | PRAM Lifetime Improvement with Process Variation Considerations. |
| 129 | FPGA-Based Implementation of a High-Speed Optical Character Recognition System. |
| 130 | FPGA Implementation of Compressor-Based Vedic Multiplier. |
| 131 | Energy Dissipation Analysis in Quantum-Dot Cellular Automata Logic Gates. |
| 132 | Deadlock-Free ID Assignment in Advanced Interconnect Protocols for High Performance. |
| 133 | High-Speed VLSI Architecture for DCT-Based Feature Extraction in Image Recognition. |
| 134 | Voltage-Scaled Clock Distribution Networks Design Methodology. |
| 135 | Encrypted Images: Lossless and Reversible Data Hiding with Public Key Cryptography. |
| 136 | Efficient Modulo 2n+1 Multiply Add Add Units Design and Implementation. |
| 137 | FPGA-Based Real-Time Object Tracking System for Surveillance Applications. |
| 138 | Novel Components and Methodology for Reverse Converter Design via Parallel-Prefix Adders. |
| 139 | Efficient BCD Adders Design in Quantum Dot Cellular Automata. |
| 140 | Error Correction Protocols for Silicon PUF Responses using Key Reconciliation |
| 141 | FPGA-Based Reconfigurable FIR Filter Design. |
| 142 | Efficient Residue Number System Scalers for Extended Three-Moduli Set |
| 143 | Low-Power Weighted Pseudorandom Test Pattern Generation for Scan-Based BIST |
| 144 | RNS Comparison Enhancement via Dynamic Range Partitioning. |
| 145 | Low-Complexity Digit-Serial Multiplier Over GF(2m) Using Toeplitz Block-Toeplitz Decomposition |
| 146 | VLSI Design for an ASIC-Based Real-Time Speech Recognition System. |
| 147 | Montgomery Modular Multiplication: High-Performance VLSI Architectures. |
| 148 | Subthreshold SRAM with Aligned Boosted Write Wordline and Negative Write Bitline. |
| 149 | Integer Transform Architecture VLSI Design for HEVC |
| 150 | Design of Area-Power Efficient FIR Filters with Tap Delay-and-Accumulate Cost Aware Coefficient Synthesis Algorithm |
| 151 | FPGA Implementation of a Multi-Standard Video Format Converter. |
| 152 | Performance Evaluation of Fixed-Width Modified Baugh-Wooley Multiplier on FPGA. |
| 153 | Modified Partial Product Generators in Redundant Binary Multipliers. |
| 154 | Power and Area Efficient Approximate Multiplier Designs |
| 155 | ASIC Implementation of a High-Speed Digital Predistortion Processor for RF Power Amplifiers. |
| 156 | CMOS PWM Transceiver Utilizing Self-Referenced Edge Detection. |
| 157 | Single Layered Logic Generator Block Design and Simulation Using Quantum Dot Cellular Automata. |
| 158 | High Speed Computing: Low Power Multiplier Architectures Using Vedic Mathematics. |
| 159 | Fast Carry Chains in FPGAs for Approximate Quaternary Addition |
| 160 | HEVC Standard’s Low Power Approximate DCT Architecture |
| 161 | FPGA-Based Implementation of Multi-Precision Floating Point Arithmetic Unit |
| 162 | Built-In Redundancy Analysis for Memory with Various Spare Hardware-Efficient Designs |
| 163 | Low Error Floating-Point Sine/Cosine Function Based TCORDIC Algorithm |
| 164 | Unequal-Error-Protection Codes for Embedded Memory in DSPs. |
| 165 | CMOS Chopper Analog Multiplier with Four-Quadrant Functionality |
| 166 | FPGA Implementation of Pipeline Large-FFT Processor for Operating Frequency Improvement |
| 167 | Vertical-Horizontal Binary Common Sub-expression Elimination for Efficient FIR Filter Synthesis. |
| 168 | Energy-Efficient VLSI Design for a Biometric Recognition System Based on Iris Patterns. |
| 169 | Rail-to-Rail Input Range Low-Power ASK Detector for Minimal Modulation Indexes. |
| 170 | Configurable Adder Design for Approximate Computing Applications |
| 171 | Approximate Circuits Design by Gate-Level Pruning |
| 172 | Low Power ECG Acquisition System with Fully Digital Architecture. |
| 173 | VLSI Design of a High-Speed Real-Time Phase Unwrapping Processor for SAR Imaging. |
| 174 | Energy Efficiency in Radix-16 Sequential Multiplier Designs |
| 175 | Adaptive Filters with Error Nonlinearities: Algorithm and Architecture |
| 176 | Compact Digital Circuits: High-performance Engineered Gate Transistor-Based |
| 177 | Reconfigurable FPGA Approach for Adaptive Median Filtering: Impulse Noise Suppression. |
| 178 | VLSI Architecture for an Efficient Implementation of the K-Means Clustering Algorithm. |
| 179 | Energy-Efficient VLSI Design of a Digital Stethoscope for Heart Rate Monitoring. |
| 180 | Data-Controlled Segmentation in Parallel Pseudo-Exhaustive Testing of Array Multipliers |
| 181 | Architecture Generation for Type-3 Unum Posit Adder/Subtractor |
| 182 | Subthreshold SRAM Cell Design with Dynamic Feedback Control in Single-Ended 8T. |
| 183 | Bit-Level Optimization for Multiple Constant Multiplications in FIR Filter Implementation. |
| 184 | Test Versus Security: Analyzing Past and Present Challenges. |
| 185 | Energy-Efficient VLSI Architecture for Real-Time Video Encryption. |
| 186 | FPGA-based Reconfigurable Constant Multiplication |
| 187 | Ternary Multiplier Analysis Using Booth Encoding Technique. |
| 188 | Integer DCT Architectures for High Performance in HEVC |
| 189 | Bus Bridge Design between OCP and AHB Protocol. |
| 190 | Low-Power Processor Design for Predicting Ventricular Arrhythmia using ECG. |
| 191 | Designing a Low Power 4×4 Bit Multiplier using Dadda Algorithm with an Optimized Full Adder |
| 192 | Area-Time Efficient FFT-Based Montgomery Multiplication Architecture |
| 193 | Polar Codes: Efficient Soft Cancelation Decoder Architectures |
| 194 | Energy-Efficient TCAM Search Engine Design with Priority-Decision Memory Technology |
| 195 | Speed Binning Using On-Chip Ring Oscillators in Statistical Framework and Built-In Self System. |
| 196 | Design of a VLSI Circuit for Real-Time Electrocardiogram QRS Detection. |
| 197 | Statistical Analysis of MUX-Based Physical Unclonable Functions for Secure Hardware Design. |
| 198 | 3-D CPU-FPGA-DRAM Hybrid Architecture for Low-Power Computation. |
| 199 | Low Power Neuromorphic Integrated Circuit Tolerant to Device Mismatch. |
| 200 | Design of a High-Speed VLSI Architecture for Real-Time Histogram Equalization. |
| 201 | VLSI Implementation of a Configurable High-Speed LDPC Codec for Broadband Communications. |
| 202 | Efficient Parallel Decoder for the Extended Golay Code with Single and Double-Adjacent Error Correction. |
| 203 | Distributed Embedded Multiprocessors: Efficient Synchronization. |
| 204 | memristor-CMOS Hybrid Look-up-table Design and Application in FPGA |
| 205 | Power and Area Efficient Digital FIR Filter with Modified MAC Unit. |
| 206 | VLSI Architecture for Efficient Implementation of the Smith-Waterman Algorithm. |
| 207 | Creation of Faithfully Rounded Truncated Multipliers and Arrays. |
| 208 | MIGFET Devices Utilization in Binary Adder Circuit Design |
| 209 | Unity-Gain SDF-FFTS with Multiplier less Architecture |
| 210 | Mixed-Logic Line Decoders: Low Power, High-Performance 2-4 and 4-16 Designs |
| 211 | Approximate Adder Design with Optimized Lower Part Constant-OR |
| 212 | GALS Modelling and Verification Structured Visual Approach for Communication Circuits |
| 213 | FPGA Implementation of a Convolutional Neural Network Accelerator for Real-Time Object Detection. |
| 214 | Advance Microcontroller Bus Architecture Analysis and Implementation on AHB Bridge. |
| 215 | Montgomery Modular Multiplication: Low-Cost High-Performance VLSI Architecture. |
| 216 | Implementation of Binary to Gray Code Converter Using Quantum Dot Cellular Automata |
| 217 | Optimizing Constant Vector Multiplication with Improved Signed Digit Representation. |
| 218 | High-Speed Computing Using Low Power Vedic Mathematics in 45nm Technology Multipliers. |
| 219 | Energy-Efficient Inexact Multipliers with Hybrid High Radix Encoding |
| 220 | Extending Orthogonal Latin Square Codes for Enhanced Error Correction. |
| 221 | Square Computation Using Dedicated Reversible Quantum Circuitry. |
| 222 | Precision-Oriented Low-Power High-Speed Comparator for Accurate Applications |
| 223 | VLSI Design of a High-Performance Gabor Filter for Texture Analysis. |
| 224 | High-Throughput Energy-Efficient Decoder Architectures for Belief Propagation in Polar Codes |
| 225 | FM0/Manchester Encoding VLSI Design with SOLS Technique for DSRC Applications. |
| 226 | Efficient Non-binary LDPC Codes Decoding with Extended Min-Sum Algorithm. |
| 227 | Probabilistic Error Modeling for Approximate Adder Circuits |
| 228 | VLSI Implementation of a High-Speed Coherent Demodulator for Digital Communication Systems. |
| 229 | Innovative QCA Threshold Gate with Five-Input Multiple-Function |
| 230 | Integer DCT Architectures Tailored for High Efficiency Video Coding. |
| 231 | Efficient Design of the Add-Multiply Operator Using Optimized Modified Booth Recoder. |
| 232 | 64-bit Radix-16 Booth Multiplier with Improved Partial Product Array |
| 233 | High-Speed Floating Point Multiplier Design Using Karatsuba Algorithm. |
| 234 | Fully Digital Front-End ECG Acquisition Architecture with Ultra-Low Voltage Operation |
| 235 | Dynamic Circuit Technique for Low-Power Microprocessors Using Flexible Charge Recycling. |
| 236 | Overloaded CDMA Crossbar Architecture for Network-On-Chip |
| 237 | VLSI Architecture for Radix-2 Modified Booth Algorithm in Parallel Multiplier Accumulator. |
| 238 | Improved Fixed-Width Adder-Tree Efficiency |
| 239 | Low-Power High-Speed TI-SAR ADC with High SNDR in 65-nm CMOS Technology |
| 240 | Signal Feed-Through Scheme Based Low-Power Pulse-Triggered Flip-Flop Design. |
| 241 | Quantum-Dot Cellular Automata Based Novel SRAM Design. |
| 242 | Low Switching Power and Ultra-Low RBL Leakage in 10T SRAM with Half-VDD Precharge |
| 243 | Logic Generator Block Design Using Quantum Dot Cellular Automata in a Single Layer. |
| 244 | High-Speed FPGA Implementation of ECC Processor Based on RSD. |
| 245 | Quantum Dot Cellular Automata Based Flip-Flop Circuits: A Novel Approach |
| 246 | CWFP: Collective Write back and Fill Policy for DRAM Cache. |
| 247 | Energy-Efficient ASIC Design for a Portable Real-Time Electroencephalogram Monitoring System. |
| 248 | Extended Four-Moduli Set Residue-to-Binary Converter Design |
| 249 | Innovative CDMA Encoding/Decoding Method for On-Chip Communication Networks. |
| 250 | Analysis and Design of Inexact Floating-Point Adders. |
| 251 | Nano scale CMOS Technology-based 12T Memory Cell for Aerospace Applications |
| 252 | LLR-based List Decoder for Polar Codes with Multi-bit Decision |
| 253 | FPGA-Based Architecture for Real-Time Sobel Edge Detection. |
| 254 | High-Speed Accuracy-Controllable Approximate Multiplier |
| 255 | Hybrid Test Points in Logic Built-In Self-Test with Capture-per-Clock |
| 256 | Single Layered Logic Generator Block Design Using Quantum Dot Cellular Automata. |
| 257 | Sense Amplifier Half-Buffer: High-Performance Asynchronous Logic QDI Cell Template |
| 258 | Advanced Encoding and Decoding Architecture of Polar Codes on FPGA. |
| 259 | Compressor-Based MAC Architecture for Low Power DSP Applications. |
| 260 | Multiple Error Correcting Architecture Using Cross Parity Codes Over GF(2m). |
| 261 | Pipeline Timing Errors One-Cycle Correction with Standard Clocked Elements. |
| 262 | Generalized Efficient Conflict-Free Address Schemes in Memory-Based FFT Processor Design |
| 263 | Squaring Algorithm Enhancement Using an Implicit Arbitrary Radix Number System. |
| 264 | Power Dissipation Minimization in Digital Circuits Using Rule-Based Approach. |
| 265 | Probabilistic Gradient Descent Bit-Flipping’s Efficient Hardware Implementation |
| 266 | Energy-Efficient Data Processing in loT Sensors with Inexact Arithmetic Circuits |
| 267 | Challenges in Trojan Insertion for Reversible Computing Architectures |
| 268 | Low Power 16-bit RISC Processor Using Advanced Pipelining Techniques. |
| 269 | LMS Adaptive Algorithm: Critical Path Analysis and Low Complexity Implementation. |
| 270 | FPGA-Based Implementation of a High-Speed Network Packet Processor. |
| 271 | Majority Logic Formulations for Parallel Adder Designs Reducing Delay and Circuit Complexity |
| 272 | High-Speed 256-Bit Carry Look Ahead Adder in 22nm Strained Silicon Technology. |
| 273 | Securing Scan-Based Attacks on Secure-ICs with On-Chip Comparison. |
| 274 | A Fast-Acquisition All-Digital Delay-Locked Loop with Starting-Bit Prediction Algorithm. |
| 275 | STT-RAM Performance Barrier Analysis with Read Performance Consideration. |
| 276 | ASIC Design of a Low-Power High-Efficiency Wireless Charger Transmitter Controller. |
| 277 | Built-in Self-Calibration Technique for ±1 LSB INL in 14-Bit SAR ADCs. |
| 278 | Improved Diagnostic Abilities and Logic Testing with Test-per-Clock Pattern Loading |
| 279 | Efficient VLSI Architecture for Convolution Based DWT Using MAC |
| 280 | Ultra-low-Energy Adder Designs: A Variation-Aware Study. |
| 281 | Low-Power Unsigned Divider Design with Adaptive Approximation |
| 282 | High-Yield 5 nm Underlapped FinFET SRAM Design with P-Type Access Transistors. |
| 283 | Architecture for Nonbinary LDPC Codes with Min–Max Decoder for Trellis and High-Order Galois Fields |
| 284 | Scalable Approximate DCT Architectures for Efficient HEVC Compliant Video Coding |
| 285 | 8-bit Microcontroller Design in VHDL. |
| 286 | Boolean Logic Circuits Mapping Methodology on Memristor Crossbar |
| 287 | Deep Learning Accelerator Unit on FPGA – DLAU |
| 288 | Solving RF-SoC Integration in Multichannel Systems Through Digital Fractional Division. |
| 289 | VLSI Implementation of DA-Based Reconfigurable FIR Digital Filter. |
| 290 | ASIC Design of a Low-Power High-Resolution Magnetometer for Navigation Systems. |
| 291 | Energy-Efficient Carry Skip Adder Operating Across Supply Voltage Levels. |
| 292 | VLSI Architecture for High-Speed Computation of the Discrete Hartley Transform. |
| 293 | FPGA-Based Implementation of a Real-Time Adaptive Beamforming System for Radar Applications. |
| 294 | Implementing a 16×16 Multiplier Using Vedic Mathematics for Enhanced Speed. |
| 295 | Design of a Versatile Multimedia Functional Unit Using Spurious Power Suppression Technique. |
| 296 | Dynamic Reconfiguration of Approximate Arithmetic Units for Video Encoding. |
| 297 | FPGA-Based VLSI Architecture for Matrix Inversion Using Gauss-Jordan Method. |
| 298 | VLSI Implementation of a Low-Complexity Bio-Signal Processor for Portable Health Monitoring Devices. |
| 299 | Majority Logic-Based Field-Coupled QCA Nano computing Adder and Subtractor Circuit Design. |
| 300 | Latch-Type Sense Amplifier Modification in 28-nm for Coupling Suppression |
| 301 | FPGA Implementation of Reconfigurable Channelization Architecture for SDR Applications. |
| 302 | LUT-Based Multiplier Approach for Short Word Length DSP Systems |
| 303 | MIMO Baseband Processing: Efficiency Enablers of Lightweight SDR. |
| 304 | Improving Defect Diagnosis Accuracy with A Test Selection Procedure. |
| 305 | Energy-Efficient FPGA Implementation of a Real-Time Eye Gaze Tracking System. |
| 306 | Current-Mode Clock Synthesis (CMCS) Design |
| 307 | Floating-Point Expansions in Extended Precision Arithmetic Algorithms. |
| 308 | Dual-Quality 4:2 Compressors for Dynamic Accuracy Configurable Multipliers. |
| 309 | Separated Dictionaries in Code Compression for Embedded Systems. |
| 310 | FPGA-Based Implementation of a High-Speed Network Traffic Management Processor. |
| 311 | Power Reduction in Dynamic Systems Using Scenario-Aware Bias Addition Technique |
| 312 | Low-Power Design Using Encoded Partial Products in Approximate Multipliers |
| 313 | Write Buffer-Oriented Energy Reduction in L1 Data Cache for Embedded Systems. |
| 314 | Configurable Joint Detection and Decoding Architecture in MIMO Wireless Communications. |
| 315 | Advancements in Pre-Encoded Multipliers with Non-Redundant Radix-4 Signed-Digit Encoding. |
| 316 | Hardware Realization of Sum of Absolute Difference Component Generator |
| 317 | Clock Gating Based on Auto Gated Flip Flops for Look Ahead. |
| 318 | Nonvolatile Spintronic Flip-Flops: Design of Defect and Fault-Tolerant |
| 319 | High-Speed and Low-Power Design Using Multiple Constant Multiplication Algorithm. |
| 320 | Computation-in-Memory Parallel Adder Implementation |
| 321 | Low-Power Split-Radix FFT Processors Using Radix-2 Butterfly Units. |
| 322 | Self-Motivated Arbitration Scheme Design for Multilayer AHB Busmatrix. |
| 323 | Implementing Fast Radix-10 Multipliers for High-Speed Decimal Calculations. |
| 324 | Delay Analysis in Current Mode Threshold Logic Gate Designs |
| 325 | Adiabatic Quantum-Flux-Parametron Logic-Based Carry Look-Ahead Adder Families |
| 326 | Gated Voltage Level Translator with Integrated High-Performance Multiplexer |
| 327 | VLSI Architecture for Radix-Sort-Based Finding of First W Maximum/Minimum Values. |
| 328 | Dynamic Feedback Control in Single-Ended 8T Sub-threshold SRAM Cell Design |
| 329 | VLSI Design of a High-Resolution Time-to-Digital Converter for LIDAR Applications. |
| 330 | FPGA Implementation of a High-Efficiency H.265/HEVC Decoder Module. |
| 331 | Evolutionary Digital Circuits Design Approach for Approximation |
| 332 | Multiple Page Sizes in NAND Flash Memory for High-Performance Storage Devices. |
| 333 | JPEG Image Compression Standard Design. |
| 334 | Digital Sensor Macros Network for Power Supply Noise Profile Extraction in SoCs. |
| 335 | Energy-Efficient Approximate Multiplier Design with Logic Compression |
| 336 | Low Latency Architecture for Matching Encoded Data with Hard Systematic Error Correcting Codes. |
| 337 | Binary64 Division with Redundant Number Systems: Energy-Efficient VLSI Realization |
| 338 | Lightweight AES S-box Design Using LFSR. |
| 339 | Cooperative Jammer in MIMO Secrecy Channel: Secrecy Rate Optimization. |
| 340 | Rapid Decoding Techniques for Single and Adjacent Error Correction Codes |
| 341 | CRC Encoder and Decoder Design and Simulation with VHDL |
| 342 | Efficient Binary Adder Designs Utilizing Quantum-dot Cellular Automata. |
| 343 | Low-Voltage Low-Power Design of Double-Tail Comparator. |
| 344 | Power Droop Reduction During Launch-On-Shift Scan-Based Logic BIST. |
| 345 | Performance Enhancement in NB-LDPC Decoder with Reduced Message Exchange. |
| 346 | Polynomial Weight Functions in a Novel Cellular Network Architecture. |
| 347 | VLSI Design Considerations for Convolutive Blind Source Separation. |
| 348 | Quantum-Dot Cellular Automata-Based Efficient Binary Comparators Design. |
| 349 | ASIC Implementation of a Low-Power Face Detection Processor. |
| 350 | Trigger-Centric Loop Mapping on Coarse-Grained Reconfigurable Architectures. |
| 351 | Enhanced SRAM Cells with Half-Select-Free Design and Comprehensive BTI Analysis for Low Leakage |
| 352 | Built-In Self-Repair Optimization for Multiple Memories. |
| 353 | Distributed Arithmetic Based LMS Adaptive Filter for Area and Power Efficiency |
| 354 | Area Efficient 1024-Point Radix-22 FFT Processor with Feed-Forward Multiple Delay Commutators |
| 355 | Efficient One-Pass Seed Generation Method for LFSR-Based Testing. |
| 356 | Low-Power Programmable PRPG with Enhanced Test Compression Capabilities. |
| 357 | Coplanar Full Adder Design in Quantum-Dot Cellular Automata via Clock-Zone Based Crossover. |
| 358 | Hybrid 1-bit Full Adder Circuit’s Low-Power High-Speed Performance Analysis |
| 359 | Scalable Fixed Point QRD Core Using Dynamic Partial Reconfiguration on FPGA. |
| 360 | High-Performance FIR Filter Architecture for Fixed and Reconfigurable Applications. |
| 361 | Area-Delay Efficient Adder Design in Quantum Dot Cellular Automata. |
| 362 | 16-bit QPSK (Quadrature Phase Shift Keying) Design. |
| 363 | AES Encryption Algorithm Design with 128-bit Key Length. |
| 364 | Xilinx System Generator Optimized for Sobel Edge Detection Technique. |
| 365 | ARX-Based Cryptography Side-Channel Protected Processor Architecture – SPARX |
| 366 | VLSI Architecture for Reconfigurable Pulse Shaping FIR Interpolation Filter in DUC. |
| 367 | Variation-Tolerant Nonvolatile Low-Power Lookup Table Design. |
| 368 | Modified Cosine-Based Comb Decimation Filters: Design, Analysis, and Implementation |
| 369 | High-Speed VLSI Architecture for Integrated Image Enhancement and Edge Detection. |
| 370 | Real-Time Electrical Capacitance Tomography: A New Parallel VLSI Architecture. |
| 371 | Universal, Scalable, and Efficient Clocking Scheme for Quantum Dot Cellular Automata. |
| 372 | Multi-Precision Floating Point Multiplier Design for High-Speed, Low-Power Applications. |
| 373 | Adaptive Hold Logic in Aging Aware Reliable Multiplier Design. |
| 374 | Extended Burst Error-Correction Codes with Quadruple Adjacent Error Correction Capability |
| 375 | Parallel Prefix Adders: Design and Delay, Power, and Area Estimation. |
| 376 | ASIC Implementation of a High-Speed Lattice Reduction Algorithm for MIMO Detection. |
| 377 | Min–Max Decoder Architecture for Nonbinary LDPC Codes with Two-Extra-Column Trellis |
| 378 | Low-Power Content-Addressable Memory Based on Sparse Clustered Networks. |
| 379 | Energy-Efficient and Variation-Tolerant Design Considerations for Nonvolatile Logic |
| 380 | Area-Delay-Power Efficient LMS Adaptive Filter with Fixed-Point Operations for VLSI Implementation. |
| 381 | Novel Components and Methodology for Reverse Converter Design via Parallel Prefix Adders. |
| 382 | Binary Signed-Digit Representation in Floating-Point Butterfly Architectures. |
| 383 | Convolution Efficient FPGA Implementation. |
| 384 | Utilizing Fast Radix-10 for Efficient BCD Multiplication. |
| 385 | SEC-DED-DAEC Codes Derived from Orthogonal Latin Square Codes for Error Correction. |
| 386 | Dual-Mode Double Precision Floating Point Division Architecture |
| 387 | Energy-Efficient ASIC Design for a Real-Time Portable Ultrasound Imaging System. |
| 388 | Complex Number Multiplier Design Using High-Performance Booth-Wallace Algorithm. |
| 389 | Custom Accelerator Design for Homomorphic Encryption Applications |
| 390 | High-Speed Configurable Adder for Approximate Applications |
| 391 | Analyzing the Effect of Switched-Capacitor CMFB on Fully Differential OpAmp’s Gain for Integrator Design |
| 392 | AES-like Block Ciphers: Countermeasures against Differential Fault Analysis |
| 393 | Viterbi Decoder Design for Multi-Standard Receiver Optimization. |
| 394 | Multi-operand Logarithmic Addition/Subtraction via Fractional Normalization |
| 395 | LFSR-Based Test Generation from Non-Test Cubes: Computing Seeds. |
| 396 | Sub-threshold Adiabatic Logic Implementation for Ultra-Low-Power Applications. |
| 397 | Enhancing FFTs Fault Tolerance Using Error Correction Codes and Parseval Checks. |
| 398 | Reversible Decoder Design in Xilinx Using Combinational Circuits |
| 399 | High-Speed ASIC Implementation of a Multichannel EEG Signal Processing Unit. |
| 400 | Digital Low-Power Baseband Processor Design for RFID Tags. |
| 401 | High Performance 64-bit MAC Unit Design. |
| 402 | Wide-Tuning-Range VCO Design with Frequency-Tuning Negative-Conductance Boosted Structure. |
| 403 | Space Applications: Complementary Dual-Modular Redundancy Dynamic Memory for Area and Energy Efficiency |
| 404 | Extending Orthogonal Latin Square Codes for Error Correction. |
| 405 | Pipelined Reconfigurable Fixed-Width Baugh-Wooley Multipliers Power-Efficient Design. |
| 406 | Reconfigurable FIR Interpolation Filter VLSI Architecture for Multistandard DUC. |
| 407 | A Novel XOR-Free Approach in Convolutional Encoder Implementation. |
| 408 | NULL Conventional Logic Without Registers |
| 409 | Input Test Data Volume Reduction Techniques for Skewed-Load Tests. |
| 410 | On-Chip Bus Design with OCP Interface. |
| 411 | Design of a Low Power VLSI Architecture for Image Scaling in Portable Devices. |
| 412 | 8-bit ALU Design with Full Adder and Multiplexer for Low Power |
| 413 | FPGA Implementation of a High-Dynamic Range Image Processing Unit. |
| 414 | Parallel Self-Timed Adder Design Using Recursive Methods. |
| 415 | Reliability and Performance in NAND Flash/SCM Hybrid Solid-State Drives. |
| 416 | Scalable Microprogrammed FIR Filter Architectures Using Vedic Multipliers on FPGA. |
| 417 | Efficient VLSI Architectures for Cryptographic Multifunction Residue Number System Operations. |
| 418 | Low-Power Parallel Chien Search Architecture with a Two-Step Approach. |
| 419 | Post-Silicon Skew Tuning with Fault Detection and Tolerance Architecture. |
| 420 | FPGA Configuration Frames: Low-Cost Multiple Bit Upset Correction in SRAM-Based. |
| 421 | 8-bit RCA Adder Analysis Across Different Nanometer Regimes. |
| 422 | Parallel Prefix Adders: Design and Delay Power Area Estimation. |
| 423 | Byte-Reconfigurable LDPC Codec Design for ECC in NAND Flash Memory Systems. |
| 424 | Design and Analysis of Truncated Ternary Multipliers. |
| 425 | TM-RF: Aging-Aware Power-Efficient Register File Design in Modern Microprocessors. |
| 426 | ASIC Implementation of a Low-Power High-Speed FFT Processor for OFDM Systems. |
| 427 | High-Speed Current-Steering DAC with SUC-Based Full-Binary Design. |
| 428 | Voltage Over-Scaling Limits for Error-Resilient Applications |
| 429 | Efficient VLSI Implementation of a High Resolution D/A Converter for Audio Applications. |
| 430 | High-Performance VLSI Architecture for Real-Time Wavefront Reconstruction in Adaptive Optics. |
| 431 | Stereo Matching Enhancement with Error Resilient and Energy Efficient MRF Message-Passing. |
| 432 | VLSI Design of Low-Cost and High-Precision FFT Processors |
| 433 | Improved DCM-Based Tunable True Random Number Generator for Xilinx FPGA |
| 434 | Xilinx System Generator for EEG Signal Denoising Using Wavelet Transform |
| 435 | Low-Power Test Set Generation Based on Functional Broadside Tests. |
| 436 | Wideband Low-Noise Amplifier Design Technique for Sub-mW Applications. |
| 437 | Stochastic LU Decomposition Scheme for MIMO Receivers: Hardware and Energy Efficiency. |
| 438 | New Hybrid Double Multiplication Architectures with Serial Out Bit Level Mastrovito Multiplier. |
| 439 | Efficient Deployment of Radix 8 Booth Multipliers Using a Slack-based Approach. |
| 440 | Enhanced Efficiency Passive Noise Shaping in SAR ADCs |
| 441 | Montgomery Modular Multiplication: A VLSI Architecture for High-Performance and Low-Cost. |
| 442 | Efficient Modular Adders Design with Reversible Circuitry |
| 443 | Low Transistor Ternary CNTFET SRAM Cell: Design and Performance Evaluation. |
| 444 | AMBA-Advanced High-Performance Bus (AHB) Protocol IP Block Design. |
| 445 | Energy-Efficient VLSI Architecture for Pattern Matching in Network Intrusion Detection Systems. |
| 446 | Power and Area Efficient LMS Adaptive Filter Design with Fixed-Point Arithmetic. |
| 447 | Fast Computation and Low Complexity for Recursive MDCT and IMDCT Algorithms. |
| 448 | A Parallel Radix-Sort-Based VLSI Architecture for High-Speed Applications. |
| 449 | Low-Latency ECC Processor Implementation Over GF(2m) on FPGA |
| 450 | High-Throughput Hardware Design for One-Dimensional SPIHT Algorithm. |
| 451 | VLSI Design of a Low-Power and High-Accuracy GPS Baseband Processor. |
| 452 | Dynamic Voltage Scaling Multiplier with Operands Scheduler for Power Efficiency. |
| 453 | Aging-Aware Reliable Multiplier with Adaptive Hold Logic for Enhanced Performance. |
| 454 | Efficient VLSI Realization of Decimal Multiplication with Sign-Magnitude Encoding |
| 455 | ASIC and FPGA Benchmarked Reliable Low-Latency Viterbi Algorithm Architectures |
| 456 | Reversible Decoder and Its Applications in Quantum-Dot Cellular Automata. |
| 457 | SEC–DAEC Codes Implementation Optimization in FPGAs. |
| 458 | On-Chip Power Management via Digitally Controlled Pulse Width Modulator. |
| 459 | Fast Fault-Tolerant Architecture for Sauvola Local Image Thresholding Using Stochastic Computing. |
| 460 | Distributed RFID Systems: A Novel Coding Scheme for Secure Communications. |
| 461 | Optimal Algorithm for Energy Saving in Embedded Systems with Multiple Sleep Modes. |
| 462 | Energy-Efficient Data Encoding Techniques for Reducing the Power Consumption in Network-on-Chips. |
| 463 | Binary Adders Efficiency Improvement in QCA. |
| 464 | FIR Filter Design Based on Improved DA Algorithm and FPGA Implementation. |
| 465 | O(N) Comparison-Free Sorting Algorithm: An Efficient Approach |
| 466 | VLSI Architecture for High-Speed Computation of the Fast Walsh-Hadamard Transform. |
| 467 | Fast Floating Point Multiplier Unit for High-Speed Applications. |
| 468 | Resource Constraint Environments: Modified Advanced Encryption Standard (MAES) |
| 469 | Efficient ASIC Implementation of CORDIC Algorithm for Wireless Communication Protocols. |
| 470 | High-Performance VLSI Architecture for Real-Time Dynamic Scene Analysis and Reconstruction. |
| 471 | Visible Watermarking Implementation in a Secure Still Digital Camera Using VLSI Design. |
| 472 | Design of a Low-Power VLSI Circuit for Real-Time Ambulatory Cardiac Monitoring. |
| 473 | Efficient FPGA Implementation of Intra Prediction in HEVC |
| 474 | Cyclic Redundancy Check (CRC) Generator Design in Verilog. |
| 475 | Bit Error Rate Performance Measurement of Wireless Systems Using Field Programmable Gate Arrays. |
| 476 | High-Performance VLSI Architecture for Real-Time Image Segmentation Using Active Contours. |
| 477 | Analog Equalizer with a Tunable and Current-Reusable Active Inductor for I/O Links. |
| 478 | Energy Efficient Implementations of Streaming Applications on FPGAs via Clock-gating |
| 479 | Adaptive Traffic Light Controller Using FPGA for Intelligent Control. |
| 480 | Diagnostic Vectors Election from Detection Test Sets in COMEDI for Logic Circuits |
| 481 | Enhancing Decimal Multipliers’ Performance Using Hybrid BCD Codes. |
| 482 | VLSI Implementation of an Adaptive Noise Cancellation System. |
| 483 | FPGA Implementation of a High-Performance Digital Predistorter for Wireless Transmitters. |
| 484 | Design and Analysis of a Low Power Magnitude Comparator |
| 485 | FPGA-Based Adaptive Filter Design for Noise Cancellation in Audio Signals. |
| 486 | Dual-Clock VLSI Design for H.265 Sample Adaptive Offset Estimation Targeting 8k Ultra-HD TV Encoding |
| 487 | Multi ported Memory Efficient Designs on FPGA |
| 488 | Quantum-Dot Cellular Automata Based Efficient BCD Adders Design |
| 489 | Recursive Multipliers Approximate Error Analysis |
| 490 | Approximate Compressors for Energy-Efficient Multiplication Design and Analysis. |
| 491 | Adaptive Logic Implementation for Minimum-Energy-Point Systems. |
| 492 | Quaternary Logic Lookup Table Implementation in Standard CMOS. |
| 493 | Scan Flip-Flop Design for High-Performance Serial and Mixed Mode Scan Test |
| 494 | Permanent Faults In-Field Test for FIFO Buffers of NoC Routers. |
| 495 | One-Dimensional Median Filter: A Low-Power VLSI Architecture. |
| 496 | Design and Implementation of a Low-Power VLSI Circuit for ECG Signal Processing. |
| 497 | Borrow-Save Adders for Low-Power Addition under Threshold Voltage Variability |
| 498 | Reducing Hardware Complexity in Parallel Prefix Adders |
| 499 | VLSI Architecture for a High-Speed Real-Time Fourier Transform Processor. |
| 500 | Digital FM Receiver Construction Using Phase Locked Loop. |
| 501 | ASIC Implementation of a High-Performance Digital Phase-Locked Loop. |
| 502 | Energy-Efficient VLSI Architecture for the AES-GCM Encryption Standard. |
| 503 | 16-bit QAM Modulator Design. |
| 504 | Design Methodology for Secure Differential Logic Gates to Enhance Circuit Security Against Differential Power Analysis Attacks. |
| 505 | Memristor-Based Multipliers Optimization |
| 506 | Redundant Representation Digit-Level Serial-In Parallel-Out Multiplier for Finite Fields |
| 507 | ASIC Design of a Low-Power High-Speed True Random Number Generator. |
| 508 | Vedic Multiplier Proposal with High-Speed Quaternary Signed Digit Number System |
| 509 | 2-D Lifting-based Discrete Wavelet Transform Efficient Architecture. |
| 510 | Design of a VLSI Architecture for Real-Time Implementation of the Kalman Filter. |
| 511 | Power Reduction in Launch and Capture Testing for SoCs. |
| 512 | VLSI Design for a High-Performance Real-Time Image Denoising Processor. |
| 513 | Fast Radix 10 Multiplication with Redundant BCD Codes. |
| 514 | Power-Efficient High-Speed Multiplier Design Using Operands Scheduling for Dynamic Voltage Scaling. |
| 515 | Exploiting Carry-Save Arithmetic in Flexible DSP Accelerator Architectures. |
| 516 | Color Demosaicking VLSI Design: Fully Pipelined, Low-Cost, High-Quality for Real-Time Video Applications. |
| 517 | Dynamically Reconfigurable Logic Gates in Single-Flux-Quantum Logic Circuits Design. |
| 518 | Error Correction with Double Error Cellular Automata and Compact Syndrome Coding in Resilient PUF Design |
| 519 | Low-Voltage Operation in 22-nm FinFET Technology Based Full-Swing Local Bitline SRAM Architecture. |
| 520 | Combinational Circuits Optimization via Transistor-Level Reconfiguration |
| 521 | MUX-Based Physical Unclonable Functions: Statistical Analysis. |
| 522 | Normal I/O Pipelined Radix-2 FFT with Combined SDC-SDF Architecture. |
| 523 | Cost Reduction in Triple Adjacent Error Correction of Orthogonal Latin Square Codes. |
| 524 | Efficient Low-Power Forward and Reverse Body Bias Generator in 40 nm CMOS |
| 525 | Optimizing Power-Accuracy Trade-off in Approximate Adders |
| 526 | FPGA-Based VLSI Architecture for Real-Time Pedestrian Detection in Automotive Applications. |
| 527 | Deadlock-Free ID Assignment in Advanced Interconnect Protocols with High Performance |
| 528 | Double-Edged Pulse width Modulation Serial Communication with Source Coding and Preemphasis. |
| 529 | High Throughput S-box for AES Application Using Multiplexers. |
| 530 | VLSI Design for a Low-Power High-Performance FFT Processor in Communication Systems. |
| 531 | 3–5 GHz UWB Receivers: Band-Selective Low-Noise Amplifier with Improved Active Inductor |
| 532 | Variable Digital Filters Design with Modified Second-Order Frequency Transformations. |
| 533 | Versatile Reconfigurable Decoder for LDPC and Polar Codes |
| 534 | 64-bit Hybrid Adder Design with Low Voltage and Power Utilizing Radix-4 Prefix Tree Structure. |
| 535 | BCH Codes One-Pass Chase Decoding: Error Locator Polynomial Searching Algorithm and Architecture. |
| 536 | Low-Voltage Operation Optimized Sense-Amplifier-Based Flip-Flop Design |
| 537 | 32-bit RISC CPU Design Based on MIPS. |
| 538 | Error Correction Codes in Fault Tolerant Parallel Filters. |
| 539 | VLSI Design of a High-Performance and Low-Power SRAM Cache for Embedded Systems. |
| 540 | Reduced Complexity Wallace Tree Multiplier for Power and Area Efficiency. |
| 541 | Programmable Truncated Multiply and Accumulate for DSP with Razor-Based Energy Reduction. |
| 542 | FPGA-Based VLSI Architecture for a Real-Time Adaptive Noise Reduction System. |
| 543 | 0.5 V Supply ECG Acquisition System with a Fully Digital Front-End Architecture. |
| 544 | Modified Partial Product Generator for Efficient Redundant Binary Multipliers. |
| 545 | Systematic Design of Faithfully Rounded Truncated Multipliers and Arrays. |
| 546 | High-Speed DDR SDRAM Controller Design and Implementation. |
| 547 | FPGA Implementation of 3D Discrete Wavelet Transform for Real-Time Medical Imaging. |
| 548 | Reconfigurable Approximate Carry Look-Ahead Adder – RAP-CLA |
| 549 | ASIC Design of a Low-Power High-Performance Correlator for Wireless Communication Systems. |
| 550 | FPGA-Based VLSI Architecture for Real-Time Video Stabilization. |
| 551 | Network-on-Chip Design for Enhanced Turbo Decoders. |
| 552 | New Full Adder/Full Subtractor – Reversible Parity Preserving Optimal Design |
| 553 | Implementation of Vedic Floating Point Multiplier on FPGA. |
| 554 | Ultra large-Scale SoC Architectures Scan Test Bandwidth Management. |
| 555 | High-Performance Network Processing through DDR3 Based Lookup Circuit. |
| 556 | Implementations of Efficient 4-Bit Burst Error Correction for Memory Applications |
| 557 | Cryptography Application: An Efficient Reversible LFSR Design. |
| 558 | Twin Precision Multiplication Acceleration Design. |
| 559 | Energy-Efficient VLSI Design for Real-Time Spike Sorting in Neural Signal Processing. |
| 560 | SET-Based Digital to Time Converter Design. |
| 561 | VLSI Architecture for a High-Performance Wavelet Packet Transform. |
| 562 | Cache Update Trackers’ Area-Aware Design for Post Silicon Validation. |
| 563 | A Dynamically Reconfigurable Multi-ASIP Architecture for Turbo Decoding. |
| 564 | VLSI Design of Low-Power High-Resolution Sigma-Delta Modulators for Audio Applications. |
| 565 | Optimized 1024 Point Radix-2 FFT Processor on FPGA for Improved Area and Frequency. |
| 566 | 10/100 Mbps Ethernet Switch Design for Networking Applications. |
| 567 | Design and Implementation of Low-Power Configurable Booth-Multiplier. |
| 568 | Fault Tolerant Bit-parallel Polynomial Basis Multiplication over GF(2m). |
| 569 | A Normal I/O Order Radix-2 FFT Architecture to Process Twin Data Streams for MIMO. |
| 570 | Area-Efficient FPGA Implementation of a Deep Neural Network Accelerator. |
| 571 | VLSI Architecture for High-Speed Computation of the Radon Transform in Medical Imaging. |
| 572 | High-Speed Hardware 1D DCT/IDCT Implementation. |
| 573 | RTL Implementation of AMBA ASB APB Protocol at System on Chip Level. |
| 574 | Novel Hardware Architecture for Polynomial Matrix Multiplications in Reconfigurable Systems. |
| 575 | Matching Architecture for Hard Systematic Error-Correcting Codes. |
| 576 | Implementation of Lossless DWT/IDWT for Medical Images. |
| 577 | Low Error, Energy-Efficient Fixed-Width Booth Multiplier with Conditional Probability Estimation. |
| 578 | Rapid Sign Detection for the Residue Number System Moduli Set {2n+1 – 1, 2n – 1, 2n}. |
| 579 | Memorization-Based Approximate Computing for Low-Power FPGA Design. |
| 580 | Multi-Level 2D DWT Architecture without Off-Chip RAM for Low Complexity and Critical Path |
| 581 | Fast Lock-in ADPLL for Dynamic Voltage and Frequency Scaling at 0.52/1 V. |
| 582 | Fully Combinational Pipelined S-Box Implementation on FPGA. |
| 583 | Efficient 3-D Discrete Wavelet Transform Architecture Design. |
| 584 | Area–Delay–Power Efficient Carry-Select Adder Design. |
| 585 | High-Performance VLSI Architecture for the LZW Compression Algorithm. |
| 586 | Approximate Arithmetic Computing with Novel Data Format |
| 587 | Low Redundancy Codes for Adjacent Error Correction with Parity Sharing |
| 588 | Area-Delay-Power Considerations in RNS Reverse Converter Adder Placement Method. |
| 589 | ASIC Design of a Low-Power High-Speed Chip-to-Chip Communication Interface. |
| 590 | Design of a Low-Power VLSI Circuit for Real-Time PPG Signal Processing. |
| 591 | Cross Parity Codes Architecture for Multiple Error Correction. |
| 592 | Accurate Gaussian Random Number Generation in VLSI via the Central Limit Theorem. |
| 593 | VLSI Design of a Compact and High-Speed Division and Square Root Unit. |
| 594 | Communication System Power Optimization Using Clock Gating Technique. |
| 595 | VLSI Design of a High-Speed Real-Time LiDAR Signal Processing Unit. |
| 596 | Brent-Kung Adder-based Low Power and High-Speed Carry Select Adder. |
| 597 | SEA Path Delay-Based Hardware Trojan Detection. |
| 598 | NII Metric Compression in Memory-Reduced Turbo Decoding Architectures. |
| 599 | Scalable Power Droop Reduction during Scan-Based Logic BIST |
| 600 | VHDL Implementation of UART with Single Error Correction Capability. |
| 601 | High-Speed ASIC Implementation of a Recursive Least Squares Adaptive Filter. |
| 602 | Turbo Encoder Design and Simulation in Quantum-Dot Cellular Automata. |
| 603 | FPGA Implementation of a Real-Time Lane Detection System for Autonomous Vehicles. |
| 604 | Markov Random Field-Stochastic Logic-Based Low Power Area-Efficient DCT Implementation |
| 605 | High-Performance ASIC Implementation of a Real-Time Multispectral Image Classification System. |
| 606 | Reversible Watermarking Implementation for JPEG2000 Standard. |
| 607 | Recursive Approach to Designing a Parallel Self-Timed Adder for Asynchronous Applications. |
| 608 | Multiple-Bit-Error Correction: Cache-Assisted Scratchpad Memory Design. |
| 609 | CMOS Active Inductor Design Methodology and Noise Analysis for High-Frequency Applications. |
| 610 | A Low Power Reconfigurable Linear Feedback Shift Register (LFSR). |
| 611 | RF Power Gating Technique for Low-Power Adaptive Radios. |
| 612 | Fixed-Width Booth Multiplier with Sign-Digit-Based Conditional Probability Estimation for Low Error Energy Efficiency |
| 613 | Design of a VLSI Architecture for Advanced Motion Estimation in Video Compression. |
| 614 | Scalable Architecture for Montgomery Modular Multiplication with Low Latency. |
| 615 | General Linear Feedback Shift Register (LFSR) Structures High Speed VLSI Architecture. |
| 616 | FPGA-Based Implementation of a High-Speed Real-Time Spectrum Analyzer. |
| 617 | Carry Select Adder with Area Delay Power Efficiency. |
| 618 | Embedded Systems Code Compression Using Separated Dictionaries |
| 619 | Multibit Flip-Flop Integration with Probability-Driven Clock Gating |
| 620 | Aerospace Application Focused Area-Efficient and Reliable RHBD 10T Memory Cell Design |
| 621 | Delta-G Modulo-(2^n Parallel Prefix n-3) Adder via Double Representation of Residues. |
| 622 | Multi-cycle Tests Generation using LFSR |
| 623 | Gigabit Ethernet MAC Transmitter Design. |
| 624 | Parallel Sparse LU Factorization Method for Circuit Analysis Accelerated with GPU. |
| 625 | Square Root Carry Select Adder in Modified Wallace Tree Multiplier. |
| 626 | Energy-Efficient Approximate Multiplication for DSP and Classification Applications. |
| 627 | Reconfigurable CORDIC: Conceptual Design and Implementation. |
| 628 | Energy Efficiency in Speculative Look ahead Microprocessors. |
| 629 | Improved Reversible Fault Tolerant LUT-Based FPGA Design. |
| 630 | CNTFET-Based High-Performance Ternary Adder Design |
| 631 | Scalable IoT Endpoint Devices with Near-Threshold RISC-V Core with DSP Extensions |
| 632 | Functional Test Sequence Compaction Using Restoration-Based Procedures and Set Covering Heuristics. |
| 633 | Factoring Technique Based Low-Power Design for Digit-Serial Polynomial Basis Finite Field Multiplier |
| 634 | A Novel Approach for Add-Multiply Operator Design Using Modified Booth Recoding. |
| 635 | Design of a High-Speed VLSI Architecture for 3D-DCT in Video Compression. |
| 636 | MIPS Instruction Set Based Advanced Low Power RISC Processor Design. |
| 637 | Exploration of Carry Propagation Free Compressors in Approximate Multiplier Designs |
| 638 | FPGA Implementation of a Real-Time Multi-Filter Image Processing System. |
| 639 | Energy Complexity Analysis in LDPC Decoder Circuits |
| 640 | Design of a Low-Power VLSI Circuit for Real-Time Wireless Sensor Data Processing. |
| 641 | VLSI Design of Low-Complexity Large Integer Multipliers for Homomorphic Encryption |
| 642 | Adiabatic Logic Utilization in Combinational Coding Circuits for Energy Efficiency |
| 643 | Advanced Microcontroller Bus Architecture (AMBA) Implementation for Application-Specific Integrated Circuits (ASICs) and Field-Programmable Gate Arrays (FPGAs). |
| 644 | Enhanced Error Correction Codes for Multiple-Cell Upsets in Space Applications |
| 645 | In-Field Structural Testing via Preemptive Built-In Self-Test. |
| 646 | Reducing Energy Consumption in Network-on-Chip with Data Encoding Techniques. |
| 647 | Sleep Convention Logic Design for Testability. |
| 648 | FPGA Implementation of a High-Speed Real-Time Machine Vision System. |
| 649 | Flexible Management of ECC for Transient Error Protection in Last-Level Caches. |
| 650 | Efficient Binary Comparators Design in Quantum Dot Cellular Automata. |
| 651 | Fixed Width Booth Multiplier with Conditional Probability for Accuracy Adjustment. |
| 652 | RSD-Based ECC Processor: A High-Speed FPGA Implementation. |
| 653 | Combinational Clock Gating Approach in Nanometer VLSI Circuits for Glitch-Free Operations. |
| 654 | Novel Rectifying Encoder Solutions Based on Delta-Sigma |
| 655 | Efficient Integer DCT Architectures for High Efficiency Video Coding. |
| 656 | RS-232 System Controller Design. |
| 657 | HUB Floating-Point Addition with Unbiased Rounding Technique |
| 658 | Reconfigurable Multi-ASIP Architecture for Turbo Decoding in Diverse Communication Systems. |
| 659 | AES Encryption and Decryption Algorithm Design with 128-bits Key Length. |
| 660 | Enhancements in Floating-Point Systems Using HUB Formats for Round-to-Nearest Methods. |
| 661 | Edge-Directed Video Up-scaler: High Efficiency VLSI Implementation. |
| 662 | Design of a High-Performance VLSI Architecture for Over-the-Horizon Radar Signal Processing. |
| 663 | VLSI Implementation of Median Filter Using Accumulative Parallel Counters. |
| 664 | Hybrid-mode Floating Point Conversion Co-processor: HMFPCC. |
| 665 | Advanced Clock-Gating Techniques for Low-Power Vector Processing in Fused Multiply-Add Operations |
| 666 | Hybrid Architectures: LUT/Multiplexer in FPGAs. |
| 667 | Neural Network Models in FPGA Logical Architecture Development. |
| 668 | Multiple Chain Failures Diagnosis in Scan Chain Masking Environment. |
| 669 | Network-on-Chip Data Encoding Techniques for Reducing Energy Consumption. |
| 670 | Flip-Flop SRAM Cells with Single MTJ for Nonvolatile Performance. |
| 671 | Energy-Efficient ASIC Design for a Wearable Real-Time Activity Recognition System. |
| 672 | Ultra-Low-Voltage Wideband Low-Noise Amplifier Design Technique. |
| 673 | High-Speed Modified TSPC D Flip-Flop with Low Power Design and Comparative Analysis |
| 674 | Low Power Test Set Generation Using Functional Broadside Tests. |
| 675 | Low-Latency Polar Decoder Architecture Using 2-Bit Decoding for Efficient Implementation. |
| 676 | USB 2.0 Transceiver Macro-cell Interface (UTMI) Implementation. |
| 677 | Penta MTJ-Based Combinational and Sequential Circuits: Low-Power Robust Easily Cascaded Designs. |
| 678 | Coarse-Grained Reconfigurable Architectures: Memory-Aware Loop Mapping. |
| 679 | Innovative Low Power 4-Bit Arithmetic Logic Unit Using Full-Swing GDI Technique |
| 680 | Computing Reliability with Two Approximate Voting Schemes |
| 681 | FPGA-Based VLSI Architecture for a Real-Time Depth Image-Based Rendering System. |
| 682 | Energy-Efficient Approximate Multiplier with Logic Compression |
| 683 | Stochastic Circuits Utilizing Parallel Sobol Sequences for Enhanced Energy Efficiency |
| 684 | Composite Class-AB–AB Miller Op-Amp with High Gain and Stability |
| 685 | Constant Matrix Multiplication Optimization for Low Power and High Throughput |
| 686 | Implementing Hardware Algorithms for Binary Multiplication |
| 687 | Design of a VLSI Architecture for Scalable Video Coding in Multimedia Applications. |
| 688 | Design of Low-Power Pulse-Triggered Flip-Flop with Signal Feed-Through Scheme. |
| 689 | ASIC Design of a Low-Latency Polar Decoder for 5G Communication Systems. |
| 690 | Physical Design-Aware Synthesis of Fault-Tolerant Quantum Circuits. |
| 691 | Sub-threshold Operation Analysis and Design of Classical CMOS Schmitt Trigger |
| 692 | Approximate Booth Multiplier Design for Power Efficiency |
| 693 | Scalable Reconfigurable Wide-Input Range Stochastic ADC Using Only Standard Cells. |
| 694 | FPGA-Based Floating Point Multiplier Architectures Using DSP48E |
| 695 | BCH Code Norm Syndrome Based Decoding for Error Correction Efficiency |
| 696 | High-Speed Ternary Full Adder and Three Input XOR Circuits Using CNTFETs. |
| 697 | High-Speed and Energy-Efficient Approximate Multiplier – RoBA |
| 698 | Energy-Efficient VLSI Architecture for Deep Learning-Based Image Super-Resolution. |
| 699 | Low Power Neural Signal Amplification in SCL 180nm Technology |
| 700 | Enhancing NAND-Flash Memory with Array Dispersion LDPC Decoder Architectures. |
| 701 | Built-in Self-Test Circuit for Droop Measurement in Digital Low-Dropout Regulators |
| 702 | Double Precision Floating Point Multiplier Implementation Using VHDL on FPGA. |
| 703 | CMOS Image Sensors: A Low-Power Incremental Delta–Sigma ADC. |
| 704 | FM0/Manchester Encoding VLSI Architecture Using SOLS Technique for Dedicated Short Range Communications. |
| 705 | Square Computation Dedicated Reversible Quantum Circuitry Design. |
| 706 | Low-Power High-Speed Dual Modulus Prescalers with Branch-Merged TSPC Scheme. |
| 707 | Encoder and Decoder Efficient Hardware Implementation for Golay Code. |
- Latest Electrical Projects Ideas
- Power Systems Project Ideas
- Top Electrical Major Project Titles
- Digital Image Processing Projects
- Digital Signal Processing Projects
