Reading: Top 250 Digital Circuits Objective Questions and Answers
Inst Tools > Blog > Digital Electronics MCQ > Top 250 Digital Circuits Objective Questions and Answers
In this article, we published the top 250 digital electronic circuits objective and answers for electrical and instrumentation engineers.
Last updated: May 5, 2022 11:47 am
57 Min Read
The below list provides all the multiple-choice questions (MCQ) related to digital circuits.
1. Circuits made up of combinations of logic gates, with no feedback from outputs to inputs.
A)Latch
B)Memory
C)Combinational logic circuit
D)Sequential logic circuit
2. What digits are used in the binary number system?
A)all of the answers
B)0 and 1
C)high and low
D)true and false
3. Which of the following is a non-volatile device?
A)PLA
B)RAM
C)PLD
D)ROM
4. Which of the following does not form DACs?
A)Current switches
B)Counter
C)Resistor network
D)Reference
5. It is needed to translate a high-level program into a sequence of machine instructions that performs the desired task.
A)Assembler
B)Compiler
C)Debugger
D)Interpreter
6. Low-speed modems method of modulation is usually
A)amplitude modulation
B)frequency-shift keying
C)phase-shift modulation
D)dibit modulation
7. The number of input combinations will equal ​_____ for an N-input truth table.
A)​2N​
B)N
C)​2N – 1​
D)N-1
8. Quad 2-input XOR gates in the 7400 Family of TTL devices have a device number equivalent to
A)7404
B)7486
C)7402
D)7408
9. CMOS means
A)Complements Main-Oxidation Semiconductor
B)Complementary Main-Oxide Semiconductor
C)Correlation in Metal Oxidized Semiconductor
D)Complementary Metal-Oxide Semiconductor
10. The maximum deviation of DAC output from its ideal value, is expressed as a percentage of full scale.
A)Deviation ratio
B)None of the answers
C)Percentage error
D)Full-scale error
11. A counter that counts from a maximum count downward to zero
A)Up/down counter
B)Synchronous counter
C)Down counter
D)Up counter
12. How many different ways can we implement the inversion operation in a logic circuit?
A)One
B)Two
C)Four
D)Three
13. It is said to be a universal gate because any digital system can be implemented with it.
A)NAND
B)OR
C)AND
D)Exclusive OR
14. A system of coordinating I/O between the transmitting and receiving devices.
A)Handshaking
B)Interfacing
C)Charging
D)Polling
15. Use the expression for x = D + [(A+B)C]’ · E to determine the output of the circuit for the conditions A = B = E = 1, C = D = 0.
A)1
B)2
C)10
D)0
16. What is the normal resting state of the SET and CLEAR inputs in a flip-flop
A)High, low
B)Low, low
C)Low, high
D)High, high
17. A digital circuit that takes a 4-bit BCD input and activates the required outputs to display the equivalent decimal digit on a 7-segment display.
A)7-segment display
B)BCD-to-decimal decoder
C)BCD-to-7-segment driver
D)Decimal to BCD driver
18. A technique often used to eliminate decoding spikes.
A)Tristate
B)Strobing
C)Wired-AND
D)Wired-NAND
19. The system program used to translate directly an assembly language to machine language is called
A)text editor
B)compiler
C)assembler
D)debugger
20. The Boolean expression for a six-input OR gate
A)U + V + W + X + Y + Z
B)A · B · C · D · E · F
C)A + B + C
D)A + B + C + D + E + F
21. A program which can be executed on several different computers to compare their speed and performance.
A)Diagnostic program
B)Assembler
C)Compiler
D)Benchmark
22. An electrical connection common to all segments of an LCD.
A)Cascade
B)Backplane
C)Bootstrap
D)Dual slope
23. The most widely used 7-bit alphanumeric code is the
A)Straight binary code
B)Gray code
C)ASCII
D)EBCDIC
24. A computer programming language in which groups of 1s and 0s are used to represent instructions.​
It is also the only language a computer actually understood.
A)Programming language
B)High – level language
C)Machine language
D)Application software
25. What does a computer do with the data it receives from an ADC?
A)Processes the data
B)Stores the data
C)All of the answers
D)Performs calculation
26. A circuit made up of combinations of logic gates, with no feedback from output to input.
A)Combinational logic circuit
B)Asynchronous circuit
C)Sequential logic circuit
D)Clocked circuits
27. An unconnected input is termed as ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A)close
B)floating
C)open
D)disconnected
28. An RS flip-flop will not change in state when
A)R = 0, S = 1
B)R = 1, S = 0
C)R = 0, S = 0
D)R =1, S = 1
29. An IC that transforms parallel data to serial in the asynchronous format and vice versa.
A)USART
B)UART
C)MODEM
D)RS232C
30. From a 3-bit binary counter design using T flip-flops, determine the number of T flip- flops needed in its circuit implementation.
A)1
B)2
C)4
D)3
31. Another name for a decade counter
A)Binary counter
B)frequency divider
C)ripple shift counter
D)BCD counter
32. Meaning of checksum in ROM’s
A)regulates ROM
B)It is a code placed in the last one or two ROM locations that represents the sum of the expected ROM data from all other locations.
C)Used as a means to test for leakage in one or more ROM locations
D)prevents decoding glitches
33. Add 3AF to 23C
A)101A
B)5EB
C)BE5
D)A3B
34. A binary counter that counts from 0000 to 1001 before it recycles.
A)Buffer
B)Ring counter
C)BCD counter
D)Ripple counter
35. A translated program in machine language is called
A)machine program
B)an object program
C)a source program
D)users program
36. A single bit comparator is usually implemented using
A)Exclusive OR
B)NOR gate
C)Exclusive NOR
D)Wired-AND
37. A state causing the flip-flop to change or reverse its state.
A)Reset
B)Toggle
C)Set
D)Non-toggle
38. The processor or central processing unit is
A)the heart of the computer
B)communicates with the user
C)employed RISC
D)supports floating point numbers
39. A digital circuit is also referred to as a/an _______ circuit.
A)sequential
B)electrical
C)logic
D)arithmetic
40. TTL, DTL, and ECL which are frequently used to refer to certain “families” of digital integrated circuits, are actually names of
A)companies that originated the families
B)varieties of positive and negative logic
C)general varieties of electronic circuits are used as logic gates, from which, in essence, the building blocks in each series are constructed.
D)alternatives to positive and negative logic
41. A type of computer bus which is bidirectional.
A)Data bus
B)Calling bus
C)Control bus
D)Address
42. A monostable multivibrator has
A)one stable state
B)two stable states
C)tristate
D)no stable state
43. An astable multivibrator has
A)no stable state
B)tristate
C)two stable states
D)one stable state
44. An instruction that causes data in the accumulator to be moved to the memory or a peripheral register.
A)LOOP
B)FETCH
C)LOAD
D)STORE
45. Which of the following is the language used in making an internet web page?
A)Hightech mark-up language
B)Hypertext make-up language
C)Highertext mark-up language
D)Hypertext mark-up language
46. A logic circuit that is triggered by a clock signal is
A)pulsed
B)synchronous
C)sequential
D)Asynchronous
47. What is the normal resting state of the SET and CLEAR inputs in a NAND gate latch?
A)SET = 0, CLEAR = 1
B)SET = 1, CLEAR = 0
C)SET = CLEAR = 0
D)SET = CLEAR = 1
48. An acceptable voltage range of logic 1 for TTL.
A)2 to 5 V
B)3.5 to 5 V
C)0 to 0.8 V
D)0 to 1.5 V
49. A result which is obtained when one is added to the least significant bit position of a binary number in the 1’s complement.
A)Spike
B)2’s complement form
C)Signed binary numbers
D)Complement
50. The time difference which results when a clock may not arrive at all flip-flops at precisely the same time.
A)Glitch
B)Clock skew
C)Spike
D)Hold
51. A momentary, narrow, spurious, and sharply defined change in volume.
A)Clock
B)Glitch
C)Strobe
D)Strobe
52. In a computer system, it is a unit of hardware where the control keys are located.
A)I/O section
B)Keyboard
C)CPU
D)Console
53. That part of a computer instruction that defines what type of operation the computer is to execute on specified data.
A)Assembly language
B)Mnemonic
C)Op code
D)Machine language
54. What is the condition of the flip-flop when Q = 0 and Q = 1?
A)Preset
B)Undetermined
C)Reset
D)Set
55. A preproduction model of a system built for testing and debugging,
A)Prototype
B)Maybe (colloquial)
C)Wire list
D)Sample
56. Equivalent of decimal value of 178 in straight binary code is _____ and in BCD is ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A)10110010, 101111000
B)111111, 1100000
C)11000, 11111111
D)10111101, 100000
57. The data manipulated by a program is called ​ ​_______ depending on its nature and extent.
A)data base
B)input
C)file
D)all of the answers
58. Which of the following involves digital quantities?
A)Current meter
B)Ten position switch
C)Temperature
D)Radio volume control
59. With OR operation, 1 + 1 = ​ ​ ​ ​ ​ ​ ​ ​ ​
A)2
B)1
C)0
D)10
60. What is the function of the comparator in the ADC?
A)Tells control logic when the DAC output exceeds the analog input
B)Addition and multiplication
C)Compares two parameters only
D)Arithmetic operation
61. A flip-flop which follows its input in the next state.
A)D
B)JK
C)T
D)RS
62. Typical propagation delay range for modern digital integrated circuits is
A)1 to 100 microseconds
B)1 to 100 picoseconds
C)1 to 100 nanoseconds
D)1 to 100 milliseconds
63. It is the required interval immediately following the active edge held of clocks during which the control inputs must be held.
A)Propagation time
B)Hold time
C)Pulsing time
D)Set up time
64. All arithmetic operations take place in the _______ of a computer
A)ROM
B)CPU
C)ALU
D)Microprocessor
65. What is the smallest type of computer in terms of their physical size?
A)Maxicomputer
B)Mainframe
C)Minicomputer
D)Microcomputer
66. An input that disables multiplexers or demultiplexers when it is HIGH.
A)Keyboard
B)Decoder
C)Strobe
D)Binary input
67. What graphical device is used to convert a truth table to its corresponding logic circuit in a simple and orderly process?
A)State table
B)Truth table
C)Karnaugh map
D)State diagram
68. In Boolean algebra, X + 1 =
A)X + 1
B)0
C)1
D)X
69. Which of the following is not a dynamic test instrument?
A)Oscilloscope
B)Logic monitor
C)Logic analyzer
D)Logic probe
70. A circuit that produces an output pulse for a fixed period of time in response to a trigger and then returns to its quiescent state.
A)Astable circuit
B)Monostable circuit
C)Discriminator
D)Bistable circuit
71. What is the major advantage of serial transfer over parallel transfer?
A)one at a time transmission
B)fewer interconnections between registers
C)large interconnections between gates
D)speed
72. Application of excessive current to a fuse in order to open it.
A)Blowing
B)Disconnecting
C)Breaking
D)Shorting
73. What capital letter corresponds to 1000101 in the ASCII code?
A)A
B)D
C)E
D)C
74. A type of multivibrator circuit which generates a square wave of its own is the
A)flip-flop
B)monostable
C)bistable
D)astable
75. The flip-flop can change only when the appropriate clock transition occurs.​
It is a condition called
A)latching
B)clocking
C)edge triggered
D)pulsing
76. How many AND gates and 4-bit binary adders are needed to implement a 2-bit to 3-bit binary multiplier?
A)6 AND gates and one 4-bit binary adder
B)2 AND gates and one 4-bit binary adder
C)9 AND gates only
D)15 AND gates and three 4-bit binary adders
77. Which of the following is a form of De Morgan’s theorem?
A)AB = (A ​ + ​ B)’
B)D. A·B = A’ · B’
C)(A + B)’ = A’ · B’
D)A + B = (AB)’
78. A circuit with no memory characteristic and whose output depends only on the current value of its inputs.
A)Boolean circuits
B)Multiplexers
C)CLC
D)SLC
79. Class of programmable logic devices wherein both its AND and its OR arrays are programmable.
A)Programmable Logic Controller
B)Programmable Array Logic
C)Field Programmable Logic Array
D)Programmable Logic Circuit
80. Simplify the expression y = AB’D + AB’D’.
A)AB’
B)AB
C)BCD
D)D’
81. The ​_____ belongs to a class of codes called the minimum-change codes, in which only one bit in the code group changes when going from one step to the next.
A)Gray code
B)BCD code
C)Morse code
D)Excess-3 code
82. What is the principal register of an arithmetic logic unit?
A)Controller
B)Buffer
C)Accumulator
D)Actuator
83. It represents machine instructions by mnemonic names and allows memory addresses and other ​ constants to be represented by symbols rather than bit strings.
A)Assembly language
B)Assembler
C)Interpreter
D)Machine language
84. There are ​ ​_____ flip-flops for a 3-bit binary counter.
A)3
B)4
C)2
D)5
85. Data retrieval from a memory is called
A)fetching
B)accessing
C)reading
D)getting
86. A command to an ADC to start conversion
A)EOC
B)PAC
C)SOC
D)EAR
87. If a certain circuit acts as AND gate when used with positive logic (H = 1, L = 0), what function will it perform when used with negative logic (H = 0, L = 1).
A)AND
B)NOR
C)OR
D)NAND
88. How many flip-flops are required for a counter that will count 0 to 255?
A)16
B)2
C)8
D)4
89. A T flip-flop can be derived by
A)by inverting the inputs of a JK flip-flop
B)securing an integrated circuit with three inputs
C)connecting the RS flip-flop’s input to ground
D)connecting the two inputs of the JK flip-flop together
90. A circuit that operates in such a way that its output is high when all its inputs are high.
A)OR
B)AND
C)NAND
D)NOR
91. It is the required interval immediately following the active edge of the clock signal during which the control inputs must be held stable.
A)All the time
B)Set up time
C)Pulsing time
D)Hold time
92. One of the standard levels of complexity of integrated circuits which contains 100,000 and more number of gates.
A)VLSI
B)MSI
C)SSI
D)ULSI
93. Duty cycle for repetitive waveform is defined as the
A)Sum of the ON time and the OFF time
B)Ratio of the OFF time to the ON time
C)Ratio of the ON time to the total time
D)Ratio of the total time to the ON time
94. Processors with more than two registers for arithmetic and logical operations are classified as
A)specific registered processors
B)accumulator based
C)serial register processor
D)general register processors
95. How many bits are in a byte?
A)16
B)4
C)2
D)8
96. In clock circuits, SWG means
A)standard wave ground
B)square wave glitches
C)square wave generators
D)standard wire gauge
97. An acceptable voltage range of a logic 0 for CMOS operating at VDD = 5 V.
A)3.5 to 5 V
B)0 to 1.5 V
C)0 to 0.8 V
D)2 to 5 V
98. Refer to the debugging method in which the program is executed one instruction at a time and the register contents can be examined after each step?
A)Syntax analyzing
B)Semantic tracing
C)Text editing
D)Trace
99. A digital circuit that produces an output code depending on which of its inputs is activated.
A)Encoder
B)Demultiplexer
C)Decoder
D)Multiplexer
100. The state of a flip-flop when Q = 0 and Q’ = 1
A)Set
B)Reset
C)Trigger state
D)Tristate
101. This bus carries lines that control the operation of the memory from the microprocessor to the memory.
A)Bus lines
B)Address bus
C)Data bus
D)Control bus
102. High-speed modems transmit between
A)300 and 2400 bps.
B)between 2400 and 9600 bps
C)between 2400 and 9600 bps
D)2400 and 9600 bps
103. A magnitude comparator has 22n entries in the truth table where n =
A)number of outputs
B)number of inputs and outputs
C)number of inputs
D)number of comparator bits
104. An acceptable voltage range of a logic 1 for CMOS operating at VDD = 5 V.
A)3.5 to 5 V
B)2 to 5 V
C)0 to 0.8 V
D)0 to 1.5 V
105. How many inputs does a full adder have?
A)4
B)3
C)2
D)8
106. Convert 1000 1001 0111 (BCD) to its decimal equivalent.
A)798
B)101
C)457
D)897
107. The output of an inverter is connected to the input of a second inverter. Determine the output level of the second inverter.
A)Undetermined state
B)Output level is the same as the input level
C)Output level is the complement of the input level
D)High output is observed
108. Perform binary subtraction to 6 ¼ and 4 ½ would result to
A)1.00
B)1.11
C)10. 11
D)1001. 01
109. An acceptable voltage range of a logic 0 for TTL.
A)2 to 5 V
B)0 to 1.5 V
C)3.5 to 5 V
D)0 to 0.8 V
110. An n-bit binary parallel adder requires ​______ in its least design.
A)n half adders
B)n half subtractor
C)n half subtractor and n full adder
D)n full adders
111. A sequential logic circuit where the storage elements commonly used are time-delay devices (usually gates).
A)Asynchronous SLC
B)Register
C)Synchronous SLC
D)Counter
112. What is the output of an EX-OR gate when a logic signal and its exact inverse are connected to its input?
A)X
B)0
C)1
D)X’
113. A small change made in resistance or capacitance to time a circuit precisely.
A)Bounce
B)Tweaking
C)Trigger
D)Squeaking
114. An equivalent Boolean equation for an exclusive NOR is
A)x’y + xy’
B)xy + xy’
C)xy + x’y’
D)xy’+ x’y’
115. When a flip-flop is set, what are the states of Q and Q’?
A)Q = 0, Q’ = 1
B)Q = 1, Q’ = 1
C)Q = 0, Q’ = 0
D)Q = 1, Q’ = 0
116. Asynchronous flip-flop input used to clear Q immediately to 0.
A)DC reset
B)DC set
C)DC clear
D)DC toggle
117. This occurs when the result of an arithmetic operation is a larger number than the output register can accommodate.
A)Underflow
B)Overflow
C)Lock-ahead carry
D)Inflow
118. In designing a 16 x 1 multiplexer, how many selection lines are needed?
A)4
B)32
C)16
D)2
119. What type of gate is equivalent to a NAND gate followed by an inverter?
A)NOR
B)AND
C)OR
D)XOR
120. A situation in a system where it can never leave or progress to another state.
A)Rest
B)Toggle
C)No change in state
D)Hang-up state
121. “Limbo” state of a flip-flop occurs when
A)both output are the same
B)both outputs are low
C)the outputs are inverse
D)both outputs are high
122. How many logic gates are in a VLSI chip?
A)10,000 or more
B)Anywhere from 100 to 9999 gates
C)Between 12 to 99 gates
D)Less than 12 gates
123. Noise margin, which is one indication of how likely it is that information communicated between digital building blocks will be incorrect due to noise, depends on
A)output current capabilities and input current requirements
B)the “safety margin” between the noise level and the noise figure.
C)output power and required input power for the two logic states
D)the “safety margin” between the output voltage produced by the transmitting block and input voltage required by the receiving block for each of the two-state.
124. The most commonly used IC package for digital integrated circuits is the
A)CMOS pack
B)Flat pack
C)DIP ceramic
D)DIP plastic
125. This type of bus carries the memory address from the computer to the memory.
A)Address bus
B)Parallel bus
C)Control bus
D)Data bus
126. Why are voltage DAC’s generally slower than current DAC’s?
A)Because of its internal construction
C)Because of the response time of the op-amp current-to-voltage converter
D)Because voltage DAC’s have many heat losses
127. If F = XY + X’Y’ Boolean expression is to be implemented using decoders and OR gates, the connection involves
A)2 to 4 line decoder with 1 OR gate
B)2 to 4 line decoder with 3 OR gates
C)3 to 8 line decoder with 2 OR gates
D)3 to 8 line decoder with 4 OR gates
128. The triangle inside the rectangle which is part of the IEEE/ANSI symbol at clock input
B)indicates triggering on a NGT
C)indicates edge-triggered operation
D)indicates the function of those inputs that are common to more than one circuit in the chip
129. What is the hex equivalent of an ASCII code which means “HELP”?
A)48 ​ 45 ​ 4C ​ 50
B)48 ​ 45 ​ 50 ​ 50
C)58 ​ 57 ​ 58 48
D)4C ​ 50 ​ 51 52
130. A table used by a PLD language such as PALASM, to calculate the expected outputs for a set of inputs.
A)Truth table
B)State table
C)Excitation table
D)Simulation table
131. An input signal that can activate or disable a gate.
A)Wired-AND
B)Strobe
C)Tristate
D)Glitch
132. When power is first applied to any flip-flop circuit, it is impossible to predict the initial state of Q and Q’.​
What could be done to ensure that NAND latch always started off in the Q = 1 state?
A)apply a momentary LOW to SET input
B)apply a momentary HIGH to CLEAR input
C)apply a momentary HIGH to PRESET input
D)apply a momentary LOW to CLEAR input
133. Arrival of a clock signal at the clock inputs of different flip-flops at different times as a result of propagation delays.
A)None of the answers
B)Clock skew
C)Buffer address
D)Clock transition
134. Which of the following does not describe a flip-flop?
A)It is a one-bit memory device.
B)Its interval circuitry are usually symmetrical
C)It is a bistable device
D)It is equivalent to a one-shot circuit
135. An area of memory that holds the ASCII characters that are being displayed on a monitor.
A)Space
B)Start bit
C)Terminal
D)Screen image
136. Which of the following does not describe a flip-flop circuit?
A)ROM
B)Bistable multivibrator
C)Memory
D)Latch
137. Text editors and formatters belong to the area of computing known as ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A)software
B)word processing
C)compilers
D)assemblers
138. The decimal system is composed of ​_____ numerals or symbols.
A)2
B)16
C)8
D)10
139. A term synonymous with CLEAR in computer systems.
A)Set
B)Toggle
C)Reset
D)Load
140. A property whereby the output of a digital-to-analog converter either increases or stays the same as the input is increased.
A)Monotonicity
B)Immunity
C)Parity
D)Volatility
141. A decoder with four inputs can have a maximum of how many outputs?
A)8
B)16
C)32
D)4
142. A programmable block of logic within a gate array, that contains a flip-flop for storage and also allows the user to specify logic functions on its inputs.
A)Configurable logic block
B)PLD
C)Block diagram
D)Programmed block
143. What binary number follows 1110?
A)1000
B)1010
C)1111
D)0111
144. Which type of flip-flop is best suited for synchronous transfer because it requires the fewest interconnections from one flip-flop to the other?
A)JK
B)D
C)T
D)RS
145. An analog memory output circuit used to eliminate aperture error is called a
A)DMUX
B)MUX
C)Flip-flop
D)Track/store amplifier
146. What will be the state of Q and Q’ after a flip-flop has been reset?
A)Q = 0, Q’ = 0
B)Q = 1, Q’ = 0
C)Q = 0, Q’ = 1
D)Q = 1, Q’ = 1
147. If each digit of a decimal number is represented by its binary equivalent, the result is a code called
A)Binary system
B)Morse code
C)Straight binary coding
D)Binary-coded decimal
148. The portion of an instruction cycle where the instruction is sent from memory to the instruction register
A)EXECUTE
B)FETCH
C)LOAD
D)ACCUMULATE
149. The state of the flip-flop after the occurrence of a clock pulse is called as its
A)current input
B)next state
C)present state
D)current state
150. The fastest method for transferring data from one register to another is the
A)serial transfer
B)FIFO
C)hybrid transfer
D)parallel transfer
151. An actuator in the DAC
A)controls a physical variable according to an electrical input signal
B)performs conversion of digital data to its analog representation
C)converts a non-electrical physical quantity to an electrical quantity
D)performs calculation
152. Which of the items below is not one of the three major sections of an MPU?
A)Timing and control
B)Register
C)Inversion
D)ALU
153. Speeds of modems are generally classified by the number of ​_____ they can transmit.
B)bits per second
C)cycles per second
D)frequency per second
154. Add the hex numbers 58 and 24.
A)7C
B)C7
C)7D
D)2C
155. What are the three basic parts of a BCD adder circuit?
A)Two connection logic and one 4-bit adder
B)Two 4-bit adders and connection logic
C)One connection logic and 4 full adders
D)Two full adders and one AND gate
156. A JK flip-flop will operate in the toggle mode when
A)J = 0, K = 1
B)J = 0, K = 0
C)J = 1, K = 0
D)J = 1, K = 1
157. Determine the sum-of-product expression for a circuit with four inputs and an output that is HIGH only when A is low at the same time that exactly two inputs are low.
A)A’B’C’ + A’C’D’ + A’B’D’
B)A’B’C’ + C’D’
C)10
D)A’B’C’D + A’B’CD’ + A’BC’D’
158. What is meant by interfacing in a computer system?
A)Synchronization of digital information transmission between computer and external I/O devices
B)Synchronization of data information operation in a computer
C)Finding the fault in a network
D)Connection of computers
159. It consists of the instructions and data that the computer hardware manipulates to perform useful work.
A)Data
B)File
C)Software
D)Program
160. What is the binary ASCII code for a question mark?
A)0100011
B)0111000
C)0111110
D)0111111
161. What is the only input combination that will produce a high at the output of a five-input AND gate?
A)All inputs should be high
B)All inputs should be low
C)At least one high input
D)At least one low input
162. A register which holds the data being written into or read out of the addressed memory location.
A)Hold register
B)Memory data register
C)Glitch register
D)Memory address register
163. The most important memory element which is made of an assembly of logic gates is called
A)flip-flop
B)all of the answers
C)bistable multivibrator
D)latch
164. Instruction mnemonic means
A)representation of a quantity that varies in discrete steps
B)a short abbreviation for the operation
C)a binary code that represents the operation to be performed by the CPU
D)technical term sometimes added to an IC’s description
165. A term used to describe the logic function created when open-collector outputs are tied together.
A)Wired-AND
B)Tristate
C)Wired-OR
D)Totem-pole
166. What happens when the input to a digital IC is left unconnected for TTL ICs?
A)It becomes overheated
B)It acts like logic 1
C)It eventually destroys itself.
D)It acts just like logic 0
167. How does the operation of asynchronous input differ from that of a synchronous input?
A)it works independently of the clock input
B)Not determined by ordinary operation
C)it is mutually the same in function
D)it is very dependent on the clock transition
168. A counter that counts sequentially but does not step through all possible states, it returns to zero after a particular state.
A)Binary counter
B)Decade counter
C)Ripple counter
D)Truncated counter
169. A representation of numbers when negative numbers are obtained by complementing their positive equivalent and adding 1.
A)Signed numbers
B)Indeterminate
C)2’s complement
D)Inversion
170. Add (74)8 with (1.1)2
A)​(700)10​
B)​(10101.01)2​
C)​​(75.4)8​​
D)​​(70.5)8​​
171. How many inputs does a half adder have?
A)8
B)4
C)2
D)1
172. Low-speed modems generally handle data rates between
A)100 and 2400 bps
B)300 and 2400 bps
C)2400 and 9600 bps
D)3000 and 9000 bps
173. An instruction that alters the normal course of a program by causing it to jump to another instruction.
A)ACC
B)Jump
C)Skip instruction
D)Rotate instruction
174. A digital circuit test equipment which is a troubleshooting tool that generates a short- duration pulse when activated manually, usually by pressing the button is the ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A)VOM
B)logic clip
C)logic pulser
D)logic probe
175. What device puts data on the data bus during a write operation?
A)ALU
B)Keyboard
C)CPU
D)Accumulator
176. What is the largest number that can be represented using 8 bits?
A)10111111
B)10111011
C)111111111
D)11011111
177. A square wave oscillator or clock generator
A)Astable circuit
B)Debounding circuit
C)Bistable circuit
D)Monostable circuit
178. Convert (614)8 to decimal.
A)396
B)392
C)384
D)400
179. How many bits are required to represent an eight digit decimal number in BCD?
A)255
B)256
C)4
D)32
180. What JK input condition will always set Q upon the occurrence of the active clock transition?
A)J = 0, K = 1
B)J = 1, K = 0
C)J = 0, K = 0
D)J = 1, K = 1
181. In BCD, the code 1111 is
A)11
B)Invalid
C)letter F
D)A
182. Class of programmable logic devices wherein its AND array is programmable while its OR array is hard-wired.
A)PROM
B)PLA
C)PLD
D)PAL
183. What is the decimal equivalent of (1101011)2?
A)100
B)108
C)96
D)107
184. Which of the following is NOT an advantage of state tables in sequential logic circuit design?
A)They result in synchronous circuit
B)The number of variables is limited
C)They minimize the gating required
D)They are the systematic approach to a design problem
185. Convert (B2F)16 to octal.
A)7547
B)11010
C)5547
D)5457
186. This occurs when the result of an arithmetic operation is a more negative number than the output register can accommodate.
A)Overflow
C)Error
D)Underflow
187. A computer language that enables Programmable Array Logic (PAL) users to generate a file that can be used to blow a PAL.
A)TURBO C++
B)Visual C
C)JEDEC
D)PALASM
188. Data storage in a memory is termed as
A)loading
B)reading
C)memorizing
D)writing
189. A digital circuit that oscillates between two unstable output states.
A)Monostable multivibrator
B)Astable multivibrator
C)Flip-flop
D)Bistable multivibrator
190. A shift register in which the output of the last flip-flop is connected to the input of the first flip-flop.
A)BCD counter
B)Ripple counter
C)Parallel counter
D)Ring counter
191. The one-input RS flip-flop is the ​______ flip-flop.
A)Latch
B)T
C)R
D)D
192. A circuit designed to produce a clean output in response to a switch closure.
A)Attenuator
B)Debouncing circuit
C)Filter circuit
193. How many flip-flops should be used to realize 32-count capacity?
A)5
B)4
C)2
D)6
194. An outstanding advantage of LCDs from LEDs.
A)LCDs essentially act as a capacitor and consume almost no power
B)LCDs generates light
C)LCDs are organized as a 7-segment display for numerical read out
D)LCDs can be multiplexed
195. The time it takes for the DAC output to settle to within ½ step size of its full scale value when the digital input changes from zero to full scale.
A)Settling time
B)Full scale time
C)Hold time
D)Set-up time
196. An IC that contains a large number of interconnected logic functions wherein the user can program the IC for a specific function by selectively breaking the appropriate interconnections.
A)PLD
B)RAM
C)ROM
D)PLC
197. What is an operand address?
A)The binary code that represents the operation to be performed by the CPU
B)The address of the data to be operated as the CPU executes the instruction called for by the opcode
D)A short abbreviation for the operation
198. The ______ operation result will be 1 if any one or more variables is a 1.
A)NOR
B)NOT
C)OR
D)AND
199. What is the next binary number following (10111)2 in the counting sequence?
A)11100
B)11001
C)11000
D)10110
200. A diagram consisting of a set of circles, where each circle contains a number of states within it.
A)State table
B)Karnaugh map
C)Transition diagram
D)Bubble diagram
201. The fan out capability of a digital building block depends on the current capability of its output and the current requirement of each input driven by that output, and maybe defined as the
A)maximum power dissipation that the unit can stand
B)number of other inputs that can transmit to one input
C)number of inputs that one output can transmit to
D)amount of cooling required
202. A ring counter where the output is inverted and tied back to the input
A)Decade counter
B)Johnson counter
C)BCD counter
D)Shift counter
203. A ​______ takes the complete decimal number and represents it in binary.
A)BCD
B)Straight binary code
C)Excess-3 code
D)Gray code
204. A situation when a circuit’s output level for a given set of input conditions can be assigned as either
B)1 or a 0.
C)Low level
D)High level
205. Correcting the faults in a circuit or a system.
A)Debugging
B)Trap
C)Fault corrector
D)Buzz-out
206. A one-input JK flip-flop is the ______ flip-flop.
A)S-R
B)T
C)C
D)D
207. A 20 KHz clock signal is applied to a JK flip-flop when J = 1, K = 1.​
What is the frequency of the flip flop output waveform?
A)40 KHz
B)20 KHz
C)10 KHz
D)5 KHz
208. A block added to the combinational logic circuit to form a sequential logic circuit is the
A)counter
B)clock
C)memory
D)ROM
209. Given: x = A’BC (A+D)’.​
Determine the output of the circuit x if A = 0, B = 1, C = 1 and D = 0.
A)10
B)0
C)1
D)2
210. A multiwire connection between digital circuits is usually called a
A)multiplexed line
B)bus
C)wire wrap
D)ribbon
211. How does a CMOS integrated circuit respond to a floating input?
A)Acts just like a logic 1
B)Open
C)Shorted
D)Unpredictable, may overheat and be destroyed
212. A register which holds the address of the word currently being accessed.
A)Memory data register
B)Access register
C)Memory address register
D)Hold register
213. Class of mass memory devices that use a laser beam to write and read onto a specified coated disk.
A)RAM
B)Mass storage
C)Non-volatile memory
D)Optical disk memory
214. An instruction that causes data to be brought from memory into an accumulator register.
A)FETCH
B)LOOP
C)JUMP
D)LOAD
215. This type of fault has the same effect as an internal short between IC pins.
A)Broken wire
B)Open signal lines
C)Shorted signal lines
D)Poor solder connections
216. How many logic gates are in an MSI chip?
A)Less than 12 gates
C)10,000 or more
D)Between 12 to 99 gates
217. A ______ condition that exists if a circuit output depends on which of two nearly simultaneous inputs arrive at a point in the circuit first.
A)clear
B)glitch
C)race
D)skew
218. The state of the flip-flop before the occurrence of a clock pulse is called as its
A)current input
B)present output
C)present state
D)next state
219. The state of a flip=flop when Q = 1 and Q’ = 0.
A)Glitch
B)Set
C)Reset
D)Latch
220. An included input terminals in a magnitude comparator IC which is significant when both inputs compared are equal is called as its
A)input terminals
B)setting
C)cascading inputs
D)address
221. It converts a non-electrical physical quantity to an electrical quantity.
A)Transducer
B)Converter
C)Compiler
D)Inverter
222. How many logic gates are in an SSI chip?
A)10,000 or more
B)Less than 12 gates
D)Anywhere from 100 to 9999 gates
223. A multiplexer is described by its size through ​_______, where n = number of bits.
A)​2n x m​
B)​1 x 2n​
C)n x 2n​
D)​​2n x 1​
224. Which of the items below can perform parallel-to-serial data conversion?
A)Decoder
B)Binary counter
C)Multiplexer
D)Shift register
225. In Boolean algebra, G + GF =
A)1
B)GF
C)F
D)G
226. In the 7400 Family of TTL Devices, Quad 2-input NAND gates has a device number equivalent to
A)7486
B)7402
C)7432
D)7400
227. In Boolean algebra, B · B’ =
A)B’
B)0
C)1
D)B
228. How many outputs does a full adder have?
A)8
B)4
C)2
D)1
229. What is the largest decimal value that can be represented using 12 bits?
A)4096
B)4095
C)2048
D)144
230. What will be the states of Q and Q’ after a flip-flop has been cleared?
A)Q = 0, Q’ = 0
B)Q = 0, Q’ = 1
C)Q = 1, Q’ = 0
D)Q = 1. Q’ = 1
231. A bistable multivibrator has
A)no stable state
B)one stable state
C)two stable states
D)tristate
232. Which of the following items below is NOT one of the three basic operations of Boolean algebra?
A)Logical complementation
B)Logical addition
C)Logical subtraction
D)Logical multiplication
233. The number of digits used by a number system.
A)Base
B)n
C)Radix
D)​2n​
234. Which of the following is NOT an internal digital IC fault?
A)Shorted signal lines
B)Open signal lines
C)Faulty power supply
235. The most primitive instructions that can be given to a computer are those interpreted directly by the hardware in ______ form.
A)machine language
B)simulator
C)assembly language
D)high-level language
236. Another name for a digital multiplexer is
A)compressor
B)data selector
C)decoder
D)encoder
237. A single word memory location used to temporarily hold data during program execution.
A)Accumulator
B)Stack
C)Register
D)Buffer
238. With a ________, a processor can store data at ay address and read back the stored information at any time.
A)RWM
B)PLA
C)ROM
D)PROM
239. What is the most common type of digital IC package?
A)DIP
B)CMOS
C)Metal type
D)TTL
240. In the data sheet of a digital building block, operating speed is typically expressed in terms of
A)transition frequency
B)capacitance C
C)propagation delay times for both possible output transitions
D)miles per hour or centimeters per second
241. A JK flip-flop can be made to function like a T flip-flop by simply
A)connecting the J and K inputs together as one input
B)connecting earth ground the JK inputs
C)connecting J = 0 and K = 0
D)resetting all inputs of the JK
242. Change in state is
A)toggle
B)reset
C)same state
D)set
243. Small circles on the input or output lines of logic circuit symbols which represent inversion of a particular signal.
A)Bubble
B)Clode
C)Bootstrap
D)Strobe
244. A circuit that goes through 2n-1 states in a random fashion.
A)Pseudo-random sequence generator
B)Counting shift
C)Random generator
D)Register
245. BCD code has always ________ bits per number.
A)2
B)8
C)16
D)4
246. A logic circuit that depends on the status of its selected inputs will channel its data input to one of ​ several data outputs.
A)MUX
B)DMUX
C)ROM
D)RAM
247. Which of the following choices is NOT a characteristic of analog quantity?
A)One quantity is represented by another which is proportional to the first
B)Is considered discrete
C)Variable amplitude
D)They can vary over a continuous range of values
248. Which of the following items below is not a part of the hardware organization in a computer?
A)Hardware realization
B)Implementation
C)Architecture
D)Assembler
249. An abbreviation that represents the opcode of a computer instruction.
A)Instruction
B)ASCII
C)Mnemonic
D)Octets
250. What two types of inputs that a clocked flip-flop has?
B)synchronous control inputs and clock input
C)Asynchronous control inputs and clock input
D)Pulsed control inputs and clock input
Click Here for Answers
Next Quiz:
  • Electronic Devices & Circuits Quiz
  • Fundamentals of Digital Systems Quiz
  • Network Theorems Objective Questions
  • Digital Electronics Objective Questions
  • Electrical Circuits Objective Questions
Quine McCluskey Logic Functions Objective Questions
Design of Combinational Circuits Objective Questions
Programmable Read Only Memory Objective Questions – Part 1
Flip Flops Objective Questions – Part 3
Fast Adder & Serial Adder Multiple Choice Questions
Shift Register Counters Objective Questions
Programmable Array Logic Objective Questions
Read Only Memory (ROM) Objective Questions – Part 2
Multiplexers Objective Questions – Part 1
4-Bit Parallel Adder and Subtractor Objective Questions
Half Subtractor and Full Subtractor Objective Questions
Counter IC Objective Questions
Digital Integrated Circuits Objective Questions – Part 2
K-Map Simplification Objective Questions
Register-Transistor Logic (RTL) Objective Questions
Arithmetic Operation Objective Questions
1’s, 2’s, 9’s & 10’s Complements Objective Questions
Random Access Memory Objective Questions – Part 3
Logic Gates and Networks Objective Questions
Memory Devices Objective Questions – Part 1
Asynchronous Down Counter Objective Questions
Random Access Memory Objective Questions – Part 4
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Motor Cooling Methods
Substation Safety Clearances
Steam Eductor Question
Pipeline Project Management
BUS TIE REACTORS
Current Limiting Reactors in Power System
Pressure and Instrumentation MCQ - Questions & Answers
Pressure and Instrumentation MCQ – Questions & Answers
What is Timeout in Communication Protocols
What is Timeout in Communication Protocols?
