Reading: Top 10 Industrial safety Objective Questions
Inst Tools > Blog > Instrumentation MCQ > Top 10 Industrial safety Objective Questions
Last updated: June 21, 2025 10:09 am
Instrumentation MCQ Multiple Choice Questions
The purpose of a lock-out/tag-out procedure is to:The purpose of CPR is to:The very first thing you should do if you are the first to witness or discover an accident on the job site is to:The purpose of a cartridge-style respirator is to:Shock is defined as an abnormal condition of the body where:A confined space is deemed ready for employee entry when:One of the common signs of a heart attack is:Heat stroke is often indicated by the following symptoms:Arc blast is caused by:Current measurements are more dangerous to make with a multimeter than voltage measurements because:
Question 1
(A) Improve productivity on the job
(B) Secure harmful energy sources to prevent injury
(C) Slow down work so technicians are less stressed
(D) Save money
(E) Identify personal items to avoid theft
Answer : B
Question 2
(A) Maintain oxygenated blood circulation
(B) Stabilize body temperature to avoid hypothermia
(C) Build upper body strength
(D) Dislodge blood clots within the victim’s lungs
(E) Prevent infection resulting from open wounds
Answer : A
Question 3
(A) Go find at least one co-worker to help you so you can work as a team
(B) Go to the scene and help the person(s) injured
(C) Find and fill out the necessary forms to document the incident
(D) Activate the emergency response system
(E) Contact your supervisor to report the incident
Answer : D
Question 4
(A) Reduce the concentration of particulates in the air you breathe
(B) Provide a pure oxygen breathing environment where there is insufficient oxygen in the air
(C) Enhance your personal appearance for maximum social appeal
(D) Convert exhaled carbon dioxide back into oxygen for re-breathing
(E) Reduce noxious odors in the air you breathe
Answer : A
Question 5
(A) A broken bone has penetrated the skin
(B) The lungs are unable to process oxygen properly
(C) The muscles in the body have “frozen” and will not move
(D) The heart stops beating normally, and “quivers” instead
(E) There is insufficient blood delivered to the body’s cells
Answer : E
Question 6
(A) A company safety inspector has certified it
(B) The unit operations foreman declares it ready
(C) An engineer has completed the necessary calculations
(D) Your supervisor assigns you to the job
(E) An independent inspection agency has completed their survey
Answer : A
Question 7
(A) A sharp pain in the lower area of the spine
(B) Loss of bowel control
(C) A feeling of numbness in the legs
(D) Discomfort in the chest and/or upper body
(E) A general feeling of restlessness and anxiety
Answer : D
Question 8
(A) A sudden affinity for country-western music
(B) Dizziness, vomiting, cold skin, profuse sweating
(C) Cold and clammy skin, thirst, vomiting, confusion
(D) Hot and dry skin, inability to drink, vomiting, confusion
(E) Blue-colored skin, extreme hunger, feelings of anxiety, thirst
Answer : D
Question 9
(A) Poor contact within electrical wire splices
(B) Radio frequency emissions from high-power transmitters
(C) Discharge of high electrical current through open air
(D) Failure to lock-out and tag-out electrical breakers
(E) Ionization of gases near high-voltage electrical conductors
Answer : C
Question 10
(A) You must use both hands to take the measurement
(B) Most multimeters are unfused
(C) The resulting magnetic fields may be very strong
(D) The circuit must be broken (opened)
(E) A fuse protects the voltage measurement ranges, but not current
Answer  : D
Credits : by Tony R. Kuphaldt
Digital Readout Systems Objective Questions
Instrumentation Engineering Quiz – Set 2
Digital Transducers Objective Questions
Types of Flow Meters MCQ – Instrumentation and Control
Robotic Control System – Part II
Measurements & Instrumentation Quiz – Set 6
  • Rajab says:
    October 21, 2019 at 2:08 pm
    good effective knowledge
Realization of Basic Compensators
Diagonalization
High Frequency Amplifiers Objective Questions
Time Division Multiplexing Objective Questions
Thermocouple Temperature Range Questions and Answers
Measurement and Instrumentation Objective Questions – Part 2
Fiber Optic Sources and Detectors Questions
Fiber Optic Sources and Detectors Questions and Answers
Measurement of Errors Objective Questions
Feedback Accelerometer System Objective Questions
Flame Emission Photometers Questions & Answers
Digital Control Systems
Spectrum Analysis of Sampling Process
Beam Balance Systems Objective Questions
Pressure Measurement Multiple Choice Questions
Time Response Analysis
State Variable Analysis – Part II
Multiplexers and Demultiplexers Objective Questions
Level Flow Cascade Control Pumping Station
Introduction to Wastewater Treatment Works and Pumping Station
Intrinsic Safety Barriers
Linear Motion Control
What is Linear Motion Control? – Factors and Example Devices
DC Motor Applications in Industries
Automatic exhaust fan control
XG5000 PLC Programming for Automatic Exhaust Fan
4-20mA Transmitters Easy Calculations
4-20mA Transmitters Calculations
Automated Test Bench - Complex PLC Programming Examples
Automated Test Bench – Complex PLC Programming Examples
