Reading: Time of Flight Mass Spectrometer
Inst Tools > Blog > Multiple Choice Questions > Time of Flight Mass Spectrometer
1. Which of the following is not a component of the time of flight analyser spectrometer?
a) Ion source
b) Field free separation region
c) Electron multiplication region
d) Photo tube
Answer: d
Explanation: Phototube is not a component of time of flight mass spectrometer. Time of flight mass analyser is a type of mass spectrometer.
2. Time of flight mass spectrometer has unlimited mass range.
a) True
b) False
Answer: a
Explanation: Time of flight mass spectrometer is a type of mass spectrometer. It has unlimited mass range.
3. Which of the following is not an advantage of mass spectrometer?
a) Simple
b) Rugged
c) High sensitivity
d) Unlimited mass range
Answer: c
Explanation: Time of flight mass spectrometers have limited sensitivity and resolution. They are simple and rugged.
4. All the ions entering the tube have the same kinetic energy.
a) True
b) False
Answer: a
Explanation: Separation of ions occurs while they are moving from the ion source to the detector. All the ions entering the tube have the same kinetic energy.
5. If all the ions have the same kinetic energy how are their masses related to their velocities?
a) Mass and velocity are equal
b) Mass and velocity are not related
c) Mass and velocity are directly proportional
d) Mass and velocity are inversely proportional
Answer: d
Explanation: If all the ions have the same kinetic energy, mass and velocity are inversely proportional. This is used in separation of ions.
6. Which of the following is true about time of flight analyser spectrometers?
a) Lighter particles arrive at the detector earlier
b) Heavier particle arrive at the detector earlier
c) Lighter and heavier particles arrive together at the detector
d) Lighter particles do not reach the detector
Answer: a
Explanation: Lighter particles arrive at the detector earlier than the heavier particles. The time difference is used to separate the electrons according to their mass.
7. In time of flight mass spectrometer, ions are formed by which of the following methods?
a) Pulsed ionization method
b) Acceleration method
c) Dynamic method
d) Ion excitation method
Answer: a
Explanation: In time of flight mass spectrometer, ions are formed by pulsed ionisation method. It is a type of mass spectrometer.
8. The evacuated tube is also known as which of the following?
a) Pulse tube
b) Detector tube
c) Drift tube
d) Acceleration tube
Answer: c
Explanation: The evacuated tube is also known as drift tube. The electrons move from source to detector through the tube.
9. The current produced by ions arriving at the collector necessitates the use of which of the following?
a) Wide band amplifier
b) Narrow band amplifier
c) Wide band filter
d) Narrow band filter
Answer: a
Explanation: The current produced by ions arriving at the collector has very short duration.Hence, it necessitates the use of wide band amplifier.
10. Which of the following is an ion optic device in which ions pass through a mirror and their flight is reversed?
a) Reversal device
b) Reflectron
c) Mirror arrangement
d) Separation chamber
Answer: b
Explanation: Reflectron is an ion optic device in which ions pass through a mirror and their flight is reversed. It is used in time of flight mass spectrometer.
11. Which of the following statements about mass spectrometers are not true?
a) Time of flight mass spectrometer has the ability to record entire mass spectrum at a time
b) Time of flight mass spectrometers have poor resolution
c) Conventional spectrometer detects only one peak at a time
d) All spectrometers have the ability to record entire mass spectrum at a time
Answer: d
Explanation: Conventional spectrometer detects only one peak at a time. Time of flight mass spectrometer has the ability to record entire mass spectrum at a time.
Infrared Spectrometers Questions & Answers
MCQ on Flow Measurement
Control Loop Multiple Choice Questions
Compensation Techniques : Control Systems
Nitrogen Oxides Questions & Answers
Fluorescent Spectrometer Questions & Answers
Time Domain Analysis
Column Efficiency and Column Resolution Questions and Answers
Linearizing Effect & Regenerative Feedback MCQ
Instrumentation for Electron Spectroscopy
Ion Transducers Questions & Answers
Optimal Control Problems – Part 1
Atomic Absorption Spectroscopy Questions & Answers
Liquid Scintillation Counters Questions & Answers
Analytical Measurement Multiple Choice Questions
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
State Models for Linear Continuous Time Systems
Stability in Frequency Domain
Time Response Analysis
Robotic Control System – Part II
HART Protocol and Fieldbus Interview Questions
FIFO and LIFO Sequences in PLC
What are FIFO and LIFO Sequences in PLC?
pH Analyzer Do’s and Don’ts
Phase Failure Relay
Why is Phase Failure Relay Required in LV Panels?
Digital Control Systems
Z-transform Analysis of Sampled-Data Control Systems
Control Valves - Repeat Actuator Diaphragm Bursts
Control Valves – Repeat Actuator Diaphragm Bursts
Transmitter Range and Sensor Limits
Transmitter Minimum Span, Accuracy & Turndown
Motor ladder Logic
