Reading: Synchronous Generator Salient Pole vs Non Salient Pole
Inst Tools > Blog > Electrical Machines > Synchronous Generator Salient Pole vs Non Salient Pole
Last updated: December 22, 2018 1:13 am
Electrical Machines
2 Min Read
Salient Pole Synchronous Alternator:
  • Salient pole Generators will have large diameter and short axial length
  • Pole shoes cover 2/3 of the pitch
  • Salient Poles are laminated in order to reduce eddy currents
  • They are used in hydraulic turbines or diesel engines
  • Salient pole generators will have typical speed about 100 to 375 rpm.
  • As the  speed of the water turbine is slow  hence more number of poles are required to attain the frequency. Therefore Salient pole machines will have typically number of poles will be between 4 to 60.
  • Cheaper compared to cylindrical rotor machines for speeds below 1000rpm.
  • Causes excessive windage losses
  • Flux distribution is not uniform due to the presence of salient poles, hence emf waveform generated is not good compared to cylindrical machine
  • Salient Pole Synchronous Generators are employed in Hydro-Power plants.
Non-Salient pole Synchronous Alternator:
  • Non-Salient pole generators will have smaller diameter and longer axial length
  • They are used for High speed operation (typically speed will be 1500 and 3000 rpm)
  • Better in dynamic balancing because of absence of salient poles.
  • Less windage loss
  • Robust construction and noiseless operation
  • Nearly sinusoidal flux distribution around the periphery, therefore gives a better emf waveform than salient pole machine
  • No need to provide damper windings (except in special case to assist the synchronising) because the field poles themselves acts as efficient dampers.
  • Non-Salient pole generators are used in Thermal,Gas and in Nuclear Power plants.
What happen When Synchronous Generator loss Excitation
Synchronous Motor Starting Methods
DC Motor Applications in Industries
Zigzag Transformers Theory
Use of line reactors
6.6kV HV Induction motor Protection
Applications of Synchronous Motors
Transformer Tap Changing Working Principle
Induction Motor Operating Characteristics
Differences Between AC and DC Motors
Induction Motors Faults and Protection
Advantages & Disadvantages Induction Motor
Difference between Permanent Magnet BLDC and DC Motor
Synchronous Motor Working Principle
Classification of valves
Losses in a DC Generator
Questions and Answers on Motors and Generators
100+ Questions and Answers on Motors and Generators
Parallel Operation of Alternators
Electrical-Switches-Working-Animation
Difference between Star and Delta Connections
AC Induction Motor Construction
Basics of AC Induction Motors
Alarm Trip for 24v DC Loop
Advantages & Disadvantages of Synchronous Motors
Advantages and Disadvantages of Slip Ring Induction Motor
SMART Transmitters Block Diagram
Smart Transmitters LRV & URV
Performance Characteristics of Sensors and Transducers
Metal Seated Ball Valves
Metal Seated Valves and Soft Seated Valves : Differences
Three-Phase Power Supply
Single Phase versus Three Phase Power
PLC Example on Manufacturing Line Assembly
Scintillation Counter Theory
Scintillation Counter Principle
Establish Communication Between Two PLC Via PROFIBUS Protocol
Four Wire Current Loop
4-wire Transmitters Current Loops
