Reading: Why Symmetrical Components Used for Unbalanced faults in Power System
Inst Tools > Blog > Power Systems > Why Symmetrical Components Used for Unbalanced faults in Power System
Last updated: September 19, 2016 4:52 am
Power Systems
3 Min Read
Symmetrical Components:
Any unbalanced three phase system of currents, voltages or other sinusoidal quantities can be resolved in to three balanced of phasors which are known as symmetrical components of the original unbalanced system. This three balanced systems constitutes three sequence networks which are solved separately on single phase basis.
The symmetrical components differ in phase sequence, i.e, the sequence in which the phasor quantities attains the maximum value. Any unbalanced system quantities (current, voltage, other sinusoidal quantities) can be represented in set of symmetrical quantities which constitutes positive sequence components, negative sequence components and zero sequence components.
Why Sequence Component:
In symmetrical power system (it is the system in which the three phases are identical), phasor quantities such as current, voltage of different sequences does not react to each other. Current in the one sequence will induce the voltage drop in respective sequence only.
Since in symmetrical system as there is no interaction between the quantities of different sequences, currents of any sequence is considered to flow in an independent network associated with that sequence only. In simple words we will get different sequence networks for positive, negative and zero sequence components, for example positive sequence current will flow in positive sequence network only. The single phase equivalent circuit of any component consists of impedances associated with that circuit and it is called sequence network for particular sequence component.
This helps in analyzing the system performance when there is unbalanced fault, interaction between the quantities (voltage, current) of different sequences can be determined by interconnecting the sequence networks (positive, negative and zero) at the fault location.
Main advantage of sequence components are isolating the quantities (voltage, current) in to components (positive, negative, zero) which helps in better criteria for controlling factors for different applications
  • In Stability analysis investigations the synchronizing force between the machines is affected by the positive sequence components.
  • Heating effect due to unbalanced currents depend on the negative sequence components. (when heating is observed due to unbalanced currents that determines presence of negative sequence component currents flowing the system. By reducing the unbalanced currents heating effect and negative sequence components can be reduced.
  • When earth fault occurs zero sequence currents flows through the system. Hence all ground or earth fault relay operates on determining the zero sequence components.
Current Limiting Reactors and Short Circuit Currents
Voltage Variations Effects on Power Plant Equipment
Neutral Grounding Practice in Power System
Shunt Capacitor Advantages in Power System
Shunt Vs Series Capacitors Advantages
Advantages & Disadvantages of AC power and DC power
Auto Recloser Circuit Breaker in Power System
Rotor Angle Stability of Synchronous Generators in Power System
Underground Cable Fault Identification Methods
Silicon Carbide Lightning Arresters Working Principle
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
Advantages and Disadvantages of Per Unit System
Why Grounding
Generating Station Grounding Principles
Power System Protection Quiz
Electrical Power System Protection Quiz
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
ungrounded-or-isolated-neutral-system-disadvantages
Ungrounded or Isolated Neutral System Disadvantages
harmonics-disadvantages-in-power-system
Harmonics Disadvantages in Power System
Reactive Power Sources and Sinks in Power System
Mitsubishi PLC Programming Tutorials
Faceplate in WinCC
Siemens HMI Training – Using UDTs with Faceplates
Control Valve Positioners
Purpose of Isolation valve
What are Isolation valves? – Purpose, Types, Configurations
Motion Detection based Street Light PLC Logic Solution
Motion Detection based Street Light: PLC Logic Solution
Simatic Prosave HMI
How to Backup and Restore from Simatic Prosave HMI?
