Reading: Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Inst Tools > Blog > Electrical Machines > Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Last updated: April 28, 2016 8:55 am
Electrical Machines
1 Min Read
Advantages of Squirrel-Cage Induction Motors
The advantages of squirrel-cage motors compared with the slip ring induction motors are given below
(i) They are more robust and cheaper
(ii) Comparatively they have  higher efficiency and power factor
(iii) Since the risk of sparking is eliminated by the absence of slip rings and brushes, they are explosion-proof.
Advantages of Slip ring Induction Motors
The advantages of the wound rotor (Slip ring) Induction motors compared with the squirrel-cage motors are given below
(i) They have very high starting torque
(ii) They have very low starting current
(iii) They have a means of varying speed by use of external rotor resistance.
Advantages and Disadvantages of Squirrel Cage Induction motor
Synchronous Motor Working Principle
Difference between Star and Delta Connections
Why Starting Current of Induction Motor is High
Electrical Motor Starter Circuits
What is a Transformer Tap Changer
  • Subhadra says:
    July 22, 2019 at 8:15 pm
    Thank you
Transformer Tap Changing Working Principle
AC Motor Braking
Induction Motors Faults and Protection
Applications of Synchronous Motors
Transformer Energy Losses & Efficiency
Differences Between AC and DC Motors
Stepper Motor Basics, Types, Modes, Wiring, Questions
Difference Between Squirrel Cage and Slip Ring Motors
Questions and Answers on Motors and Generators
100+ Questions and Answers on Motors and Generators
Importance of Hysteresis Loop
DC Motor Applications in Industries
Star to Delta Conversion
Star to Delta and Delta to Star Conversion Formula
Motor Star Delta Connections
Metering pumps
Metering Pumps
BLDC Motor Vs AC Induction Motor
Advantages and Disadvantages of Slip Ring Induction Motor
PLC Fault Diagnosis - PLC Training Documents
PLC Fault Diagnosis – PLC Training Documents
Humming Sound in Transformer
Why is the Humming Sound Produced in Transformer?
X-Ray Fluorescence Spectrometry Questions and Answers
Basic Requirements of Sizing the Control Valves
Basic Requirements of Control Valves Sizing
Paddlewheel flowmeter principle
What is a Paddle Wheel Flow Meter?
Instrumentation Bulk Material
Instrumentation Bulk Material Requirements in Oxygen Service
float-type level switch control a pump
Argonite Fire Suppression System Animation
Argonite Fire Suppression System Working Principle
