Reading: Selection Criteria for Toxic Gas Detector
Inst Tools > Blog > Fire & Gas System > Selection Criteria for Toxic Gas Detector
Last updated: December 8, 2019 8:37 pm
Fire & Gas System
2 Min Read
Toxic Gas (H2S) Detector
A detector is sensitive to toxic gas.
The following are some minimum requirements applicable for combustible gas detector selection, however, requirements vary from industry to industry.
Toxic gas (H2S ) detectors shall be based on electrochemical cell technology. They shall be suitable for detecting H2S in the range of 0-100 ppm.
The detector shall be a self-contained device comprising of the sensor element and all monitoring and signal conditioning electronics required to provide a linear 4-20 mA output signal to monitoring cards in the main fire and gas panel.
With attachments fitted (including filters ), the detector output shall achieve 20% of actual H2S concentration within 10 seconds and 50% within 30 seconds. This condition may be different for different installations.
Gas detection instrument and their components used for H2S detection shall be constructed of materials resistant to or protected against corrosion due to the presence of H2S.
The sensor shall be of a highly specific response to H2S gas to reduce the chances of false alarms resulting from the presence of other gases.
Provision shall be made for testing the detectors by application of test gas. The method employed shall not necessitate the removal of dust and splash filters, gas collecting cones or similar attachments.
The alarm setpoint shall be user selectable for high/low alarms and the output contacts shall be of latching type requiring a deliberate manual action to reset.
The shelf life of test ampoules shall be minimum six (6) months and shall be clearly indicated. This condition may be different for different installations.
Carbon Monoxide Gas Hazards
Gas Detectors Interview Questions & Answers
What is Bump Testing ?
What is Manual Call Point (MCP) ?
MOS Type Gas Sensor Principle
Interview Questions on Fire Alarm System
What is a Fire Pump? – Definition, Principle, Types, Comparison
Sensor Technologies in Gas Detectors
Industrial Flame Detectors
Gas Detectors Working Principle
Why LEL important in Gas Detection?
Chlorine Gas Hazards
Deluge Valve Working Principle
oxygen Safety Analyzer
Oxygen Safety Analyzer
Infrared Hydrocarbon Gas Detector Calibration Procedure
Which Gases Can a Multi-Gas Detector Detect
Which Gases Can a Multi-Gas Detector Detect?
Gas Detectors Practical Problems and Troubleshooting
Purpose of End of Line (EOL) Resistor in Fire & Gas System ?
Why we use End of Line (EOL) Resistor in Fire and Gas System ?
Fixed Gas Detectors vs. Portable Gas Detectors
Rate of Rise Thermal Detectors Working Principle
Gas Detection System Abbreviations
Sensivity Enhancement for NMR Spectroscopy Questions & Answers
Valve stem travel
Control Valves Mechanical Friction Problems
Floating Neutral - Electrical Engineering Basics
What is Floating Neutral? – Electrical Engineering Basics
Analytical Control System of Heat Exchanger Questions
Choppers Test Questions
Integrated Injection Logic (IIL) Objective Questions
Calculate the 0%, 50%, and 100% Calibration Points
