Allen-Bradley MicroLogix 1000 Programmable Logic Controller (PLC)
Suppose we have an Allen-Bradley MicroLogix 1000 controller connected to a pair of pushbutton switches and contactor controlling power to an electric motor as shown in this illustration:
This motor control system has a problem, though: the motor refuses to start when the “Start” pushbutton is pressed. Examine the “live” display of the ladder logic program inside this Allen-Bradley PLC to determine what the problem is:
Identify at least two causes that could account for all you see here.
Answers :
- Contactor coil failed open
- Wire connecting contactor coil to O:0/2 failed open
- Wire connecting VAC-VDC terminal to DC COM terminal failed open
- Wire connecting input switch “commons” to contactor coil failed open
- Output channel O:0/2 defective on the PLC
- 24 VDC power supply in the PLC is insufficient to power the contactor’s coil
Share Your Answer / Comments
Credits : Tony R. Kuphaldt – under CC BY 1.0
For More PLC Questions : CLICK HERE
Also, wire connecting start button failed open or start button is defective.
