Reading: Pressure Transmitter Circuit
Inst Tools > Blog > Pressure Measurement > Pressure Transmitter Circuit
Last updated: January 22, 2020 9:28 am
1 Min Read
Sketch a circuit whereby the loop-powered pressure transmitter sends a signal to an analog voltage meter (to show respective signal). Be sure to route all wiring and attach any necessary components to terminals on the terminal strip.
Note: avoid connecting more than two wires to each screw terminal on the terminal strip, to avoid “overcrowding” any connection points, and avoid crossing wires over each other.
Pressure transmitters are used to measure pressure or level in the industries. The pressure transmitter outputs the standard 4 – 20 mA signal to represent the measured process variable. In general, the pressure transmitters are 2 wire instruments used in process control applications.
This is just one possible solution:
Credits: Tony R. Kuphaldt
  • Sensor Trim Smart Transmitter
  • Troubleshooting of Transmitter
  • Installation of Pressure Transmitter
  • PT Calibration at the bench
  • Differential Pressure Transmitter
Pressure Sensor Specifications
How Measurement Span of Pressure Gauge Could be Changed?
Pressure Transmitters Heat-traced impulse lines
What is Sensor Trim and Output Trim in Smart Transmitter?
Impulse Piping standards for Field instruments
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
When to use a Diaphragm Seal?
Pressure Transmitter Applications
U-tube Manometer with equal & unequal limb types
Bellows
What is a Barometer?
Pressure Gauges Zero Adjustment
How much Pressure applied to U-tube Water Manometer?
Force Balance Pressure Transmitters
Pneumatic Pressure Transmitters Principle
pressure-switch-calibration-procedure
Pressure Switch Calibration Procedure
pressure gauge snubber
Pressure Gauge Snubbers
Pressure Transmitters Filled impulse lines
5 Valve manifold
5 Valve Manifold Operation
Semi Conductor or Piezo Resistive Strain Gauge Principle
Components of Bourdon Tube Pressure Gauge
Components of Bourdon Tube – Questions and Answers
Process Control & Instrumentation Objective Questions – Set 6
Precoat Filters
Precoat Filters
Total Reflection Spectrometer Questions & Answers
Transistor Amplifier Working Principle
PLC DIN Rail
What is DIN rail ?
types of Orifice Plates
Types of Orifice Plates & Orifice Plate Tappings
Gas-chromatograph-Working-Principle
Gas chromatograph Working Animation
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop?
