Reading: #5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Inst Tools > Blog > PLC Tutorials > #5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Use cryptographic hashes, or checksums to check PLC program integrity and raise an alarm when they change.
Last updated: September 21, 2021 2:30 am
Use cryptographic hashes, or checksums if cryptographic hashes are unavailable, to check PLC code integrity and raise an alarm when they change.
ChecksumsHashesExampleSiemens Implementation ExampleRockwell Implementation Example
Security ObjectiveTarget Group
Integrity of PLC logicProduct Supplier Integration / Maintenance Service Provider Asset Owner
Checksums
Where (cryptographic) hashes are not feasible, checksums may be an option. Some PLCs generate a unique Checksum when code is downloaded into the PLC Hardware.
The Checksum should be documented by the manufacturer / integrator after SAT and be part of warranty / service-conditions.
If the checksum feature is not natively available in the controller, this can also be generated in the EWS/HMI and probed e.g., once a day to compare with the hash of the original code in the PLC to verify that they are matching. While this won’t provide real time alerts, it’s good enough to track if anyone is attempting changes to the PLC code.
The checksum value can also be moved into a PLC register and configured for an alarm when it changes, the value can be sent to historians etc.
Hashes
PLC CPUs generally do not have the processing capacity to generate or check hashes while running. Attempting a hash might actually cause the PLC to crash.
But the PLC’s engineering software might be able to calculate hashes from the PLC code and save them either in the PLC or somewhere else in the control system.
Use Cryptographic checks for PLC
Example
PLC vendors that are known to have checksum features:
  • Siemens (see example)
  • Rockwell
Also, external software can be used for generating checksums:
  • Version dog
  • Asset Guardian
  • PAS
Example for creating checksums in Siemens S7-1500 PLC:
GetChecksum-Function Block reads actual checksum and with a lightweight script the “SAT- Checksum” can be stored as reference.
A deviance from the Reference-Checksum can be stored with the Datalog-Function.
This is partial example of how an organization can develop a level of PLC program change detection capability within their ICS environment.
This example is specifically for a Rockwell Automation ControlLogix PLC and is not complete; however, it illustrates how to retrieve the PLC processor state into a register within the PLC.
Once in a register in the PLC, the organization can use it create a configuration change alarm for display on an HMI, transmit the raw state information to an HMI for trending and monitoring, or send it to a Historian for long term capture.
This practice provides an opportunity, using existing tools and capabilities, to gain situational awareness of when critical cyber assets change. It is up to the organization to complete the use of this example in a method that works best in their environment.
  1. From the Controller Properties Dialog Box, select the configure button on “Change to Detect”
  2. Within the selection window, choose all items to be monitored
  3. Create a Tag to receive the processor state information. This tag can be of type “LINT” or a 2-word array of type “DINT”
  4. Use the Get System Values (GSV) instruction to get the processor state information from memory and move it into a Tag that can be used in logic or read at the HMI
Why?
Beneficial for…?Why?
  SecurityKnowing if PLC code was tampered with is essential for both noticing a compromise and verifying if a PLC is safe to operate after a potential compromise.
  ReliabilityHashes or checksums can also be a means to verify if the PLC is (still) running code approved by the integrator/manufacturer.
Maintenance/
References
Standard / frameworkMapping
MITRE ATT&CK for ICSTactic:  TA002 – Execution, TA010 – Impair Process Control
Technique:  T0873 – Project File Infection, T0833 – Modify Control Logic
ISA 62443-3-3SR 3.4 : Software and information integrity
  ISA 62443-4-2CR 3.4 : Software and information integrity
EDR 3.12 : Provisioning product supplier roots of trust
  ISA 62443-4-1SI-1 : Security implementation review
SVV-1 Security requirements testing
  MITRE CWECWE-345: Insufficient Verification of Data Authenticity
CWE-353: Missing Support for Integrity Check
CWE-354: Improper Validation of Integrity Check Value
Source: PLC Security
How to Create New Project Using Simatic Manager
PLC Example on Manufacturing Line Assembly
PLC Program for Fish Feeding System
Motor ON OFF Logic in PLC
MOVE Instruction in PLC – What You Need to Know?
  • Jason Jones says:
    March 16, 2023 at 12:14 am
    This functionality is built-in to Mitsubishi Electric iQ-R series PLC’s. The loaded firmware, parameterization, and programs/global tags can be monitored separately and in real-time using system memory of the CPU (SD2020-2025).
Ladder Logic Vs. Other Programming Languages – PLC Basics
What is Thin Client in SCADA? – Purpose, Advantages
PLC Programming Example for Motor Forward and Reverse Control
What is Function Module in Siemens PLC?
PLC Example on Switch Program with Timers
PLC Ladder Logic Example based on Set Coil and Reset Coil
PLC Compressor Control Ladder Logic
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
PLC Logic for Stairway Lighting
Smart Automation Solutions: PLC Logic for Stairway Lighting
PLC Program for Valves
PLC Pump Permissive Interlocks
scada hmi
Functions of SCADA
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
S7 Organizational blocks
Siemens PLC Tia Portal – OB100 Start-up Organization Block
Simatic Hardware Configuration
Configuration of Profibus Network in Siemens PLC
Site Acceptance Test (SAT) of PLC System
PLC System Site Acceptance Test (SAT)
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
Beta ratio ( β )
Important Factors in Flow Measurement
full-wave-bridge-rectifier-with-voltage-regulator
Basics of Voltage Regulators
TIA Portal MOVE Instruction
Electricity Magnetism
Business Skills Every Engineer Needs
Lead Acid Battery Operation
How does a Lead Acid Battery Work?
What Do You Learn in Software Engineering
What Do You Learn in Software Engineering?
