Reading: Nyquist Stability Criterion
Inst Tools > Blog > Multiple Choice Questions > Nyquist Stability Criterion
Nyquist Stability Criterion MCQ
1. Which principle specifies the relationship between enclosure of poles & zeros by s-plane contour and the encirclement of origin by q(s) plane contour?
a) Argument
b) Agreement
c) Assessment
d) Assortment
Answer: a
Explanation: Argument principle specifies the relationship between enclosure of poles & zeros by s-plane contour and the encirclement of origin by q(s) plane contour.
2. If a Nyquist plot of G (jω) H (jω) for a closed loop system passes through (-2, j0) point in GH plane, what would be the value of gain margin of the system in dB?
a) 0 dB
b) 2.0201 dB
c) 4 dB
d) 6.0205 dB
Answer: d
Explanation: Gain Margin is calculated by taking inverse of the gain where the Nyquist plot cuts the real axis.
3. For Nyquist contour, the size of radius is _______
a) 25
b) 0
c) 1
d) ∞
Answer: d
Explanation: For Nyquist contour, the size of radius is ∞.
4. Consider a feedback system with gain margin of about 30. At what point does Nyquist plot crosses negative real axis?
a) -3
b) -0.3
c) -30
d) -0.03
Answer: b
Explanation: Gain Margin is always inverse of the point which cuts the Nyquist on the real axis.
5. According to Nyquist stability criterion, where should be the position of all zeros of q(s) corresponding to s-plane?
a) On left half
b) At the center
c) On right half
d) Random
Answer: a
Explanation: According to Nyquist stability criterion zeroes must lie on the left half on the s plane.
6. If the system is represented by G(s) H(s) = k (s+7) / s (s +3) (s + 2), what would be its magnitude at ω = ∞?
a) 0
b) ∞
c) 7/10
d) 21
Answer: a
Explanation: On calculating the magnitude of the system and putting the value of frequency one gets the magnitude as 0.
7. Consider the system represented by the equation given below. What would be the total phase value at ω = 0? 200/[s3 (s + 3) (s + 6) (s + 10)].
a) -90°
b) -180°
c) -270°
d) -360°
Answer: c
Explanation: The phase can be calculated by the basic formula for calculating phase angle.
8. Due to an addition of pole at origin, the polar plot gets shifted by ___ at ω = 0 ?
a) -45°
b) -60°
c) -90°
d) -180°
Answer: c
Explanation: Addition of pole causes instability to the system.
9. In polar plots, if a pole is added at the origin, what would be the value of the magnitude at Ω = 0?
a) Zero
b) Infinity
c) Unity
d) Unpredictable
Answer: b
10. In polar plots, what does each and every point represent w.r.t magnitude and angle?
a) Scalar
b) Vector
c) Phasor
d) Differentiator
Answer: c
Explanation: Each and every point on the polar plot is the phasor where value of frequency varies.
Robotic Control System – Part I
Pulse Height Analyzer Questions & Answers
Approximation of Higher-Order Systems by Lower Order
Stability Analysis by Describing Functions
Construction of Root Loci
Electrochemical Methods for Oxygen Analysis Questions & Answers
Radiofrequency Mass Spectrometer
Atomic Absorption Spectroscopy Questions & Answers
Combination Electrode Questions & Answers
Root Locus in Control Systems
Biosensors Questions & Answers
Operation of Chromatography Questions & Answers
Programmable Logic Controllers Multiple Choice Questions
Digital Control Systems
The Z-Transform
Paramagnetic Oxygen Analyzers Questions & Answers
MCQ on Measurement and Instrumentation
Feedback and Non-feedback Systems Objective Questions
Optimal Control Systems
Infrared Gas Analyzers Questions & Answers
Simple Loop with Local Indication
Instrument Loop Test Requirements and Operation Procedures
Captive Power Plant Trip Root Cause Analysis
Pressure and Level Control Loop
Problem on Pressure and Level Control Loops
Ozone analyzer principle
Ozone Analyzer Working Principle
Pyrometer Principle
Optical Pyrometer Working Principle Animation
Calculate Resistance from Temperature for RTD
RTD Calculator : Calculate Resistance from Temperature
Industry 4.0 Explained
Industry 4.0 Explained – Industrial Internet of Things
simple latching motor control circuit
Motor Control Circuit Wiring
