Reading: Measuring Instruments MCQ
Inst Tools > Blog > Instrumentation MCQ > Measuring Instruments MCQ
Learn about the measuring instruments with the MCQ which focuses on the types, principles, and, applications.
Last updated: July 24, 2024 4:26 pm
Instrumentation MCQ
Measuring Instruments MCQWhat instrument measures atmospheric pressure?What instrument is used to measure the speed of wind?Which instrument measures humidity in the air?Which instrument is used to measure angles in navigation and astronomy?What device measures the rotational speed of a shaft or disk?Which instrument measures the specific gravity of liquids?Which device is used to measure radiation levels?What instrument measures the altitude of an object above a fixed level?What instrument is used to measure the thickness of materials?What instrument measures the potential difference between two points in an electric circuit?What instrument measures the acidity or alkalinity of a solution?Which device is used to measure the thermal radiation emitted by an object?Which device is used to measure electric current?What instrument measures the amount of oxygen in the blood?What instrument is used to measure the intensity of light?What instrument is used to measure temperature?Which device is used to measure electric resistance?What instrument is used to measure the turbidity of a liquid?What instrument is used to measure the intensity of an earthquake?Which device measures the oxygen levels in water?
You will learn the measuring instruments through multiple-choice questions with detailed explanations from the below video.
Question 1
A. Anemometer
B. Barometer
C. Thermometer
D. Hygrometer
Show the Answer
Barometer
Question 2
A. Altimeter
B. Hygrometer
C. Barometer
D. Anemometer
Show the Answer
Anemometer
Question 3
A. Pyrometer
B. Barometer
C. Hygrometer
D. Anemometer
Show the Answer
Hygrometer
Question 4
A. Barometer
B. Tachometer
C. Sextant
D. Gyroscope
Show the Answer
Sextant
Question 5
A. Oscilloscope
B. Tachometer
C. Dynamometer
D. Potentiometer
Show the Answer
Tachometer
Question 6
A. Hydrometer
B. Flowmeter
C. Pyrometer
D. Hygrometer
Show the Answer
Hydrometer
Question 7
A. Barometer
B. Galvanometer
C. Geiger counter
D. Anemometer
Show the Answer
Geiger counter
Question 8
A. Anemometer
B. Altimeter
C. Hygrometer
D. Barometer
Show the Answer
Altimeter
Question 9
A. Barometer
B. Voltmeter
C. Anemometer
D. Micrometer
Show the Answer
Micrometer
Question 10
A. Voltmeter
B. Ammeter
C. Ohmmeter
D. pH meter
Show the Answer
Voltmeter
Question 11
A. Voltmeter
B. Spectrometer
C. Refractometer
D. pH meter
Show the Answer
pH meter
Question 12
A. Pyrometer
B. Hydrometer
C. Thermocouple
D. Manometer
Show the Answer
Pyrometer
Question 13
A. Galvanometer
B. Ammeter
C. Ohmmeter
D. Voltmeter
Show the Answer
Ammeter
Question 14
A. Barometer
B. Spirometer
C. Thermometer
D. Oximeter
Show the Answer
Oximeter
Question 15
A. Photometer
B. Spectrometer
C. Manometer
D. Calorimeter
Show the Answer
Photometer
Question 16
A. Barometer
B. Anemometer
C. Hygrometer
D. Thermometer
Show the Answer
Thermometer
Question 17
A. Ammeter
B. Voltmeter
C. Ohmmeter
D. Galvanometer
Show the Answer
Ohmmeter
Question 18
A. Turbidimeter
B. Refractometer
C. Spectrometer
D. Calorimeter
Show the Answer
Turbidimeter
Question 19
A. Anemometer
B. Hygrometer
C. Seismometer
D. Barometer
Show the Answer
Seismometer
Question 20
A. Dissolved oxygen meter
B. Conductivity meter
C. Oximeter
D. Hydrometer
Show the Answer
  • Digital Measuring Instruments
  • What is a Barometer?
  • Laser Doppler Anemometer
  • Magnetic Wind Instruments Questions
  • Hot Wire Anemometer Principle
Measurements & Instrumentation Quiz – Set 4
Self Balancing Potentiometer Objective Questions
Electrical and Electronics Circuit Measurement Objective Questions
Analog to Digital Converters Objective Questions
Instrumentation Engineering Quiz – Set 2
Gyroscope Objective Questions
Instrumentation Engineering Students Test
Ionization Transducers Objective Questions
Smart Sensors Objective Questions
Shift Registers and Counters Objective Questions
Semiconductor Sensors Objective Questions
Force Measurement Objective Questions
Measurement of Impedance Objective Questions
Multiple Choice Questions on Sensors & Transducers
Types of Pressure
Types of Pressure – Instrument Questions and Answers
Oscillators and Signal Generators Objective Questions
Basic Digital Building Blocks Objective Questions
Ladder Logic Questions and Answers
Inverse Transducers Objective Questions
DP transmitter Elevated 10 Feet above the Vessel
principle of time base generator
Time Base Generator
Arc Fault Breaker (AFB) Electrical Problem Solved
Erasable Programmable Read Only Memory Objective Questions
Question on Remote Seal with Capillary Tubing Transmitter
Allen-Bradley MicroLogix 1000 controller
PLC Switch Actuation Status
Rack Type PLC
PLC Input Output Modules
Amine Pump Trip - Root Cause Analysis
Amine Pump Trip – Root Cause Analysis
