Reading: Liquid Scintillation Counters Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Liquid Scintillation Counters Questions & Answers
1. In liquid scintillation counter, which of the following is a fluorescent substance?
a) Solvent
b) Solute
c) Crystal
d) Reagent
Answer: b
Explanation: In liquid scintillation counter, a mixture of solvent and solute is used. The solute is a fluorescent substance.
2. When UV light is absorbed by the fluor molecules the light emitted is in which of the following colours?
a) Pink
b) Red
c) Green
d) Blue
Answer: d
Explanation: When UV light is absorbed by the fluor molecules the light emitted is in blue colour. Light is emitted when the molecules return to the ground state.
3. In liquid scintillation counter, which of the following is used to convert light into electrical signals?
a) Photo multiplier tube
b) Photo emissive tube
c) Photo voltaic cell
d) Photo reflector
Answer: a
Explanation: The photo multiplier tube converts light into electrical signals in liquid scintillation counter. Two photo multiplier tubes are used in liquid scintillation counter.
4. The reduction in counting efficiency of the scintillation detector is called as __________
a) Disintegration
b) Decay
c) Quenching
d) Reduction
Answer: c
Explanation: The reduction in counting efficiency of the scintillation detector is called as quenching. Substances added to the counting vial can reduce the efficiency.
5. Which of the following is not a type of quenching?
a) Chemical quench
b) Interference quench
c) Colour quenching
d) Self-absorption
Answer: b
Explanation: There are three types of quenching. Interference quench is not a type of quenching.
6. In which type of quenching, the radiation emitted by the isotope is not detected due to absorption of the radiation by the sample itself?
a) Chemical quench
c) Colour quenching
d) Self-absorption
Answer: d
Explanation: In self-absorption, the radiation emitted by the isotope is not detected due to absorption of the radiation by the sample itself. It may occur due to precipitates.
7. Variation of gain with temperature does not cause instability.
a) True
b) False
Answer: b
Explanation: Variation of gain with temperature causes instability. There are various other factors that cause instability.
8. Due to the presence of red, green and yellow colour in the vial, which of the following occurs?
a) Chemical quench
c) Colour quenching
d) Self-absorption
Answer: c
Explanation: Scintillators emit light in the blue region of the spectrum. Due to the presence of other colours, colour quenching may occur.
9. A quench curve can be constructed by plotting the counting efficiency versus ____________
a) Q-number
b) Quench factor
c) H-number
d) Disintegrations
Answer: c
Explanation: A quench curve can be constructed by plotting the counting efficiency versus H-number. This is done using a set of samples with known activity.
10. Photomultipliers used in Liquid scintillation detectors are a source of instability.
a) True
b) False
Answer: a
Explanation: Photomultipliers used in Liquid scintillation detectors are a source of instability. Various factors cause instability.
Linearizing Effect & Regenerative Feedback MCQ
Adaptive Control
Optimal Control Problems – Part 1
Ammonia and Fluoride Electrode Questions & Answers
Measurement and Instrumentation Objective Questions – Part 3
Output Regulator & the Tracking Problem
Nyquist Stability Criterion
Time Response of First Order Systems Objective Questions
Tuning of PID Controllers
Ion Transducers Questions & Answers
Experimentation of Transfer Function
State Models for Linear Continuous Time Systems
Online Analyzers Questions & Answers
Industrial safety Objective Questions and Answers
Top 10 Industrial safety Objective Questions
Pulse Height Analyzer Questions & Answers
Time Response Analysis
Design Considerations for Higher Order Systems
Approximation of Higher-Order Systems by Lower Order
Single Beam and Double Beam Instruments
Nonlinear Control Systems
Actuators Questions and Answers
Standard Test Signals Objective Questions
Transmission Control Protocol
PLC Program for Traffic Light Sequence using Functional Blocks
Heat Exchanger Outlet Temperature Control
Heat Exchanger Temperature Control
Scintillation Counter Theory
Scintillation Counter Principle
P&ID Legend
What is a Legend? – Piping and Instrumentation Diagram
Industrial Automation Systems
Remote Functions in Industrial Control Systems (ICS)
PID with Practical Example
Basics of Loop Checks
