Reading: Liquid Chromatograph- Mass Spectrometer
Inst Tools > Blog > Multiple Choice Questions > Liquid Chromatograph- Mass Spectrometer
1. Introduction of total HPLC effluent into MS is feasible.
a) True
b) False
Answer: b
Explanation: Introduction of total HPLC effluent into MS is not feasible. The simplest method is the introduction of liquid from LC to the MS ion source region.
2. The gas burden from conventional LC flow rates creates nearly _____ times more gas than cryo-pumped vacuum system can handle.
a) 5
b) 10
c) 20
d) 40
Answer: c
Explanation: The gas burden from conventional LC flow rates creates nearly 20 times more gas than cryo-pumped vacuum system can handle.
3. Which of the following should be in position to split the effluent?
a) Interface
b) Ion source
c) Makeup gas
d) Microbore
Answer: a
Explanation: Interface should be in position to split the effluent. LC-MS is a very advantageous method.
4. Which of the following is the most commonly used interface?
a) Nebulizer
b) Chopper
c) Filter
d) Vapourising chamber
Answer: a
Explanation: Nebulizer is the most commonly used interface. The nebulizer gas and the make-up gas are introduced coaxially into the heated nebulization region.
5. Only ______ percent of the effluent of the liquid chromatography must be introduced in the mass spectrometer.
a) 1-2
b) 1-5
c) 1-20
b) 1-15
Answer: b
Explanation: Only 1-5 percent of the effluent of the liquid chromatography must be introduced in the mass spectrometer. Therefore, the total effluent must be split.
6. Which of the following is the normal nebuliser temperature used in LC mass spectrometry?
a) 50-100oC
b) 100-200oC
c) 125-150oC
d) 150-200oC
Answer: c
Explanation: 125-150oC is the normal nebuliser temperature used in LC mass spectrometry. It is suitable for a variety of applications.
7. The ions are focussed and de-clustered through which of the following regions?
a) Dry helium region
b) Wet oxygen region
c) Wet chlorine region
d) Dry nitrogen region
Answer: d
Explanation: The ions are focussed and de-clustered through a dry nitrogen region. It is then sent into the high vacuum analyser.
8. The ions are passed into the high vacuum analyser through which of the following?
a) Orifice
b) Nozzle
c) Nebulizer
d) Venturi tube
Answer: a
Explanation: The ions are sent into the high vacuum analyser through an orifice. It is then mass analysed.
9. Using an interface would reduce detection limit and sensitivity.
a) True
b) False
Answer: a
Explanation: The total effluent must be split. Using an interface would reduce detection limit and sensitivity.
10. Gas burden from conventional LC flow rates is which of the following?
a) 1ml/min of water produces 1.2 l/mm of gas
b) 1ml/min of water produces 2.4 l/mm of gas
c) 2ml/min of water produces 3.2 l/mm of gas
d) 1ml/min of water produces 4.2 l/mm of gas
Answer: a
Explanation: In LC-mass spectrometry, 1ml/min of water produces 1.2 l/mm of gas. This is the gas burden that conventional flow rates produced.
Nyquist Stability Criterion
Radiation Detectors Questions & Answers
The Design Problem
Continuous Wave NMR Spectroscopy Questions & Answers
Time of Flight Mass Spectrometer
Instrumentation of ESR Spectrometer
Instrumentation for Electron Spectroscopy
Liquid Chromatography Questions & Answers
Effect of Adding a Zero to a System
Z-transform Analysis of Sampled-Data Control Systems
State Variable Analysis – Part II
Polar Plots MCQ
Constructing Phase-Trajectories
Single Beam and Double Beam Instruments
Secondary Reference Electrodes Questions & Answers
Stability in Frequency Domain
Tuning of PID Controllers
Top 100 Power Plant Engineering Objective Questions & Answers
Nonlinear Control Systems
Encoder Questions
Encoder Multiple Choice Questions
High Pressure Liquid Chromatography Questions & Answers
Digital Control Systems
Z & S Domain Relationship
zener-diode-as-voltage-regulator
Operation of Zener Diode Voltage Regulator
What is Barring Gear Logic? Why is it Required in the Steam Turbine?
Resistor Y and Delta Network Calculation
Y and Delta Resistor Network Calculations
Gas detection system Interview Questions
Interview Questions on Gas detection System
Stroke Checking Procedure for GCV, SRV, IGV, and LFBV
foam fire protection system
Basics of Foam Fire Fighting System
Electrical Networks Objective Questions
Claw Machine PLC Programming
Doll Claw Machine using Omron PLC Programming
