Reading: Ion Spectroscopy Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Ion Spectroscopy Questions & Answers
Last updated: November 27, 2021 5:37 pm
1. In Ion spectroscopy, the primary ion is usually which of the following?
a) Inert gas ion
b) Halogen ion
c) Oxygen group gas ion
d) Hydrogen
Answer: a
Explanation: In Ion spectroscopy, the primary ion is usually an inert gas ion. When primary ion having particular kinetic energy is incident on a surface certain phenomena can occur.
2. The kinetic energy of the primary ion should be in which of the following range?
a) 0.1-4 keV
b) 0.2-1 keV
c) 0.4-2 keV
d) 0.3-5 keV
Answer: d
Explanation: The kinetic energy of the primary ion should be 0.3-5 keV. These primary ions are made incident on the surface.
3. If the primary ion is elastically scattered, the kinetic energy of the reflected primary ion will depend on which of the following?
a) Charge of the primary ion
b) Charge of the surface ion
c) Mass of the surface ion
d) Number of surface ions
Answer: c
Explanation: If the primary ion is elastically scattered, the kinetic energy of the reflected primary ion will depend on the mass of the surface ion. The reflected ion is measured by ISS.
4. Which of the following causes the phenomena of sputtering?
a) Primary ion gets embedded in the solid
b) Primary ion is elastically scattered
c) Primary ion is reflected
d) Primary ion is refracted
Answer: a
Explanation: Primary ion may penetrate through few layers of the surface and get embedded in the solid. This causes scattering.
5. The fragments formed during sputtering can be either neutral atoms or ions. The ions can only be positive.
a) True
b) False
Answer: b
Explanation: The fragments formed during sputtering can be either neutral atoms or ions. The ions can be positive or negative.
6. Which of the following is the energy range of ISS?
a) 1 keV
b) 2 keV
c) 4 keV
d) 8 keV
Answer: a
Explanation: The energy range of the ISS is 1 keV. ISS stands for ion scattering spectroscopy.
7. Which of the following is the spectral range of SIMS?
a) 0-10 amu
b) 0-100 amu
c) 0-500 amu
d) 0-1000 amu
Answer: c
Explanation: The spectral range of SIMS is 0-500 amu. SIMS stands for secondary ion mass spectroscopy.
8. Both ISS and SIMS have depth profiling capability.
a) True
b) False
Answer: a
Explanation: Both ISS and SIMS have depth profiling capability. ISS is slow in depth profiling but SIMS is rapid.
9. Which of the following is denotes the absolute quantitative analysis of SIMS?
a) 30%
b) 70%
c) 50%
d) Not possible
Answer: d
Explanation: Absolute quantitative analysis is not possible in SIMS. It is possible in ISS.
10. Which of the following is the amount of matrix effect that occurs in SIMS?
a) Very low
b) Low
c) Some
d) Severe
Answer: d
Explanation: Severe matrix effects occur in SIMS. Some matrix effects occur in ISS.
11. Which of the following is the x-y resolution of ISS?
a) 1 µ
b) 10 µ
c) 100 µ
d) 1000 µ
Answer: c
Explanation: The x-y resolution of ISS is 100 µ. It has poor x-y resolution.
12. Which of the following is the x-y resolution of SIMS?
a) 1 µ
b) 10 µ
c) 100 µ
d) 1000 µ
Answer: a
Explanation: The x-y resolution of SIMS is 1 µ. It has this resolution when used with ion microprobe.
Steady-state Errors & Error Constants
IR Instrumentation Questions & Answers
Differential Equations of Physical Systems & Dynamics of Robotic Mechanisms
DC Circuits Multiple Choice Questions
Liquid Chromatograph- Mass Spectrometer
Pneumatic Systems Objective Questions
Electron Spectroscopy for Chemical Analysis
Time Domain Analysis
Diagonalization
Magnetic Wind Instruments Questions & Answers
Gamma Camera Questions & Answers
Infrared Gas Analyzers Questions & Answers
Control of the Effects of Disturbance Signals by Use of Feedback
Paramagnetic Oxygen Analyzers Questions & Answers
Nonlinear Control Systems
Advances in Control System
Adaptive Control
Liquid Chromatography Questions & Answers
Control Systems Stability and Algebraic Criteria
Relative Stability Analysis
Frequency Response MCQ
Ion Analyzers Questions and Answers
Ion Analyzer Questions & Answers
Bipolar Junction Transistors Questions & Answers
Measurement and Instrumentation Objective Questions – Part 1
Sensors & Transducers Questions and Answers
Free PDF Downloads Learn Instrumentation & Control Systems
Free PDF Downloads: Learn Instrumentation & Control Systems
Basic Control Systems Questions
14 Basic Control Systems Questions for Interview Preparation
Introduction to Protective Systems
Infrastructure Monitoring in Your Business Operations
Pyrometer
Pyrometers Handbook
Displacement Level Transmitter in situ calibration
Displacer (buoyancy) Level Transmitter Principle, Limitations, Design, Installation & Calibration
