Reading: Instrument Technician Interview Questions and Answers
Inst Tools > Blog > Instrumentation Interview Questions > Instrument Technician Interview Questions and Answers
Last updated: May 2, 2019 4:55 pm
2 Comments
6 Min Read
This article provides the Instrument Technician Interview questions and answers.
Instrument Technician InterviewField InstrumentationWhat does ARRH and # refer to in valve specification?What does DN stand for in valve size?What is the full form of ASTM standard?What does BENCH RANGE refer to in an actuator?Why control mode specification is given in the data sheet of the transmitter?What is the use of the diode in series to the coil in a relay?Where and Why are “O” Rings used in DPT’?Why is earthing provided in the rack room if the power supplies present are floatingRelationship between AWG & mm2Advantages of Displacer type Level switch to float type switch?Construction of micro switchWhere should we use top mounted or side mounted level switch?Application of PCVDifference between PSV & PRVWhy PSV in Cooling water line at outlet of a heat exchanger is required?Comparison of PD meter, turbine meter & Coriolis meter in Custody transfer applications..(Accuracy wise)What is a thermal relief valve?
AARH refers to average roughness height and is a measure of roughness of sealing surface of a flange. The # refers to ANSI class of flange/valve and is indicative of its pressure rating.
DN stands for Diameter Nominal. It is a flange size of the valve.
ASTM stands for American Society for Testing of Materials.
The bench range/set of an actuator/control valve combination refers to the air pressure required to fully open/close the valve out of line when it is not subjected to process fluid forces.
Not mandatory. This is controller specification. Direct OR reverse.
A diode is often used in parallel with a relay coil to dissipate energy stored in coil inductance when the coil is disconnected from the electric circuit. It is also known as freewheeling diode.
For providing leak proof seal.
Earthing is provided in rack room for purpose of safety. Even if power supplies are kept floating.
A) AWG was used prior SI standards to specify the diameter of the core of the electrical wires.
B) Both awg and mm2 are used to specify size of cross section of a wire/conductor. The relationship is found in a standard table – westermann’s tables.
Displacer type switches involve very little movement whereas float type switches involve large movement of float and hence are more likely to get stuck-up. However float switches can be used over a much longer range than a displacer switch.
A micro switch is a small switch consisting of a tiny spring loaded  plunger which operates an electrical contact when actuated. This arrangement is encaged in a plastic housing. It is very commonly found in pressure switches.
The type of switch to use depends on size of the vessel and the location of actuating level. If the vessel is small or actuating level is near the top, top mounted switch can be used. In a large vessel with intermediate actuation points, side mounted switch is used. A top mounted switch needs a stilling well.
Application of PCV
A PCV is a self-actuated pressure control valve used to maintain upstream or downstream pressure at a set pressure using force from the process fluid if necessary.
A pressure safety valve is used to relieve over-pressure by releasing relatively small volumes of material and installed on smaller vessels.
A pressure relef valve is used to relieve over-pressure by releasing relatively large volumes of material and installed on large vessels/tanks.
The PSV in cooling water line at the outlet of a heat exchanger is actually a thermal safety valve and is used to relieve overpressure due to thermal expansion of water.
A PD meter, a turbine meter or a coriolis meter may all be used in custody transfer. A PD meter or a turbine meter typically deliver accuracy around 0.5% and contain moving parts and require more maintenance and indicate volumetric flow.
A good coriolis meter involves almost no wear and tear, needs less maintenance effort, delivers accuracy close to 0.1% and directly indicates mass flow.
For custody transfer of gas service ultrasonic multi-path flow meters are also used with accuracy up to 0.35%. They are maintenance free and having very good diagnostic features.
A thermal relief valve is typically used to relieve over pressure due to thermal expansion of liquid in pipelines.
Articles You May Like :
DCS Interview Questions
Differential Pressure Flow Transmitter Questions
PLC Ladder Logic Questions and Answers
Interview Questions on Pressure Measurement
Distributed Control System Interview Questions
Questions and Answers on Gas
Valve Technician Interview Questions
15 Loop Diagram Questions
Questions on Thermocouple and Pyrometer
2 Comments
  • SHOBHIK ARIWALA says:
    August 20, 2017 at 4:50 pm
    Please send me F& G q&a on my mail id
    • S Bharadwaj Reddy says:
      August 20, 2017 at 11:05 pm
      Hi, Print button available at the bottom of the article. You can generate a pdf file using the print button.
Thermocouple Questions and Answers
Oil and Gas Interview Questions Answers
Questions on Piping and Instrumentation Diagrams
14 Basic Control Systems Questions for Interview Preparation
OPC Communication Interview Questions and Answers
Siemens PLC Interview Questions and Answers
Automation Engineers Interview Questions
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
Electronics & Instrumentation Engineering Interview Questions For Freshers
Field Transmitter Installation
Cables and Cable Glands Questions and Answers
Top 30 Interview Questions on Pressure Measuring Devices
Instrumentation Inspection and Quality Control Questions
Interview Questions on Electronics and Instrumentation
Selection of Industrial Temperature Calibrator
Allen Bradley SLC 500 PLC Programming
Turbidity Sensor Calibration Procedure
Rotary Liquid Seal Ring Air Compressor
Rotary Compressors
Rolled & Seal Welded Tube to Tube sheet joints
Gas Cooler Re-tubing Done Successfully (Root Cause Analysis)
How Twisted Wire Cables Eliminates Noise Voltage
Inductive Coupling Effects
Worldwide Voltage & Frequency Values
