Reading: Industrial Drives Multiple Choice Questions and Answers
Inst Tools > Blog > Electrical MCQ > Industrial Drives Multiple Choice Questions and Answers
In this article, we shared the 70 industrial drives multiple-choice questions and answers (MCQ) to test your knowledge.
Last updated: January 9, 2022 10:25 am
Electrical MCQ
16 Min Read
In this article, we shared the 70 industrial drives MCQ questions and answers to test your knowledge.
Industrial Drives Questions and AnswersClick Here for Answers
The below list provides all the multiple-choice questions related to the industrial drives technical subject.
1. The cost of an induction motor will increase as
A)horsepower rating decreases but r.p.m. increases
B)horsepower rating and operating speed decreases
C)horsepower rating increases but r.p.m. decreases
D)horsepower rating and operating speed increases
2. Which of the following motors are preferred for overhead traveling cranes?
A)Slow speed motors
B)None of these answers
C)Continuous duty motors
D)Short time rated motors
3. Which of the following motors is preferred for the boom hoist of a traveling crane?
A)A.G. slip ring motor
B)Single-phase motor
C)Synchronous motor
D)Ward-Leonard controlled D.C. shunt motor
4. Flameproof motors are used in
A)paper mills
B)moist atmospheres
C)explosive atmospheres
D)steel mills
5. A pony motor is used for the starting of which of the following motors?
A)Synchronous motor
C)Schrage motor
D)Squirrel cage induction motor
6. ____ has the least range of speed control.
A)Schrage motor
B)Synchronous motor
C)D.C. shunt motor
D)Slip ring induction motor
7. Which of the following motors are best for the rolling mills?
A)Slip ring induction motors
B)D.C. motors
C)Squirrel cage induction motors
D)Single-phase motors
8. Which of the following motors is preferred when smooth and precise speed control over a wide range is desired?
A)Synchronous motor
B)Squirrel cage induction motor
C)D.C. motor
D)Wound rotor induction motor
9. For a motor-generator set which of the following motors will be preferred?
A)Slip ring induction motor,
B)Synchronous motor
C)Pole changing induction motor
10. Which feature, while selecting a motor for centrifugal pump, will be of least significance?
A)Speed control
B)Horse power
C)Starting characteristics
D)Operating speed
11. For which of the following applications motor has to start with high acceleration?
A)Lifts and hoists
B)Oil expeller
C)Floor mill
D)Centrifugal pump
12. The starting torque in the case of centrifugal pumps is generally
A)less than running torque
B)slightly more than running torque
C)double the running torque
D)same as running torque
13. Which of the following motors has series characteristics?
A)Capacitor start motor
B)Shaded pole motor
C)None of these answers
D)Repulsion motor
14. Heavy-duty cranes are used in
A)steel plants
B)heavy engineering workshops
C)all of these answers
D)ore handling plants
15. The traveling speed of cranes varies from
A)10 to 15 m/s
B)20 to 30 m/s
C)1 to 2.5 m/s
D)5 to 10 m/s
16. A reluctance motor ____
A)is provided with slip rings
B)is compact
C)requires starting gear
D)has high cost
17. For a particular application the type of electric and control gear are determined by which of the following considerations?
A)Starting torque
B)All of these answers
C)Conditions of environment
D)Limitation on starting current
E)Speed control range and its nature
18. The diameter of the rotor shaft for an electric motor depends on which of the following
A)r.p.m. only
B)Horse power, r.p.m. and power factor
C)Horse power and r.p.m.
D)Horse power only
19. Which part of a motor needs maximum attention for maintenance?
A)Frame
B)Bearing
C)Rotor winding
D)Stator winding
20. ____ motor is a constant speed motor.
A)Universal motor
B)Synchronous motor
C)Schrage motor
D)Induction motor
21. In ____ the speed can be varied by changing the position of brushes.
A)schrage motor
B)slip ring motor
C)induction motor
D)repulsion motor
22. ____ has the least value of starting torque to full load torque ratio.
A)Squirrel cage induction motor
B)D.C. shunt motor
C)D.C. series motor
23. In which of the following application the load on the motor change in cyclic order?
A)Cranes
C)Electric shovels
D)Rolling mills
24. Heat control switches are used in
A)transformers
B)cooling ranges
C)single phase
D)three phase induction motors
25. Rotor of a motor is usually supported on____ bearings.
A)bush
B)needle
C)ball or roller
D)thrust
26. Light duty cranes are used in which of the following ?
A)Pumping stations
C)Automobile workshops
D)Power houses
27. Reluctance motor is a ____
A)low noise, slow speed motor
B)self starting type synchronous motor
C)low torque variable speed motor
D)variable torque motor
28. Ward-Leonard controlled D.C. drives are generally used for ____ excavators.
A)Light duty
C)Medium duty
D)Heavy duty
29. Which of the following motors is preferred when quick speed reversal is the main consideration ?
A)Synchronous motor
B)Wound rotor induction motor
D)D.C. motor
30. The selection of an electric motor for any application depends on which of the following factors ?
A)All of these answers
B)Electrical characteristics
C)Mechanical characteristics
D)Size and rating of motors
E)Cost
31. When the load is above____ a synchronous motor is found to be more economical.
A)2 kW
B)20 kW
C)50 kW
D)100 kW
32. ____ is not a part of ball bearing ?
A)Outer race
B)Inner race
C)Cage
D)Bush
33. ____ has relatively wider range of speed control.
A)D.C. shunt motor
B)Synchronous motor
C)Ship ring induction motor
34. A wound rotor induction motor is preferred, as compared to squirrel cage induction motor, when major consideration is
A)all of these answers
B)low windage losses
C)slop speed operation
D)high starting torque
35. By the use of which of the following D.C. can be obtained from A.C. ?
A)Mercury arc rectifier
B)Silicon diodes
C)Any of these answers
D)Motor generator set
36. The load cycle for a motor driving a power press will be
A)continuous
B)intermittent and variable load
C)variable load
D)continuous but periodical
37. ____ method of starting a three phase induction motor needs six terminals
A)Auto-transformer
C)Star-delta
D)Resistance starting
38. Battery operated scooter for braking uses
A)rheostatic braking
B)mechanical braking
C)plugging
D)regenerative braking
39. Besides a constant speed a synchronous rotor possesses which of the following advantages
A)Better efficiency
C)High power factor
D)Lower cost
40. Which of the following alternatives will be cheaper ?
A)100 H.P. A.C. three phase motor
B)Ten motors of 10 H.P. each
C)Four motors of 25 H.P. each
D)Five motors of 20 H.P. each
41. Which of the following machines has heavy fluctuation of load ?
A)Printing machine
B)Planer
C)Punching machine
D)Lathe
42. For derries and winches which of the following drives can be used ?
A)Pole changing squirrel cage motors
B)Any of these answers
C)D.C. motors with Ward-leonard control
D)A.C. slip ring motors with variable resistance
43. ____ is preferred for synthetic fibre mills.
A)Series motor
B)Synchronous motor
C)Shunt motor
D)Reluctance motor
44. For crane travel which of the following motors is normally used ?
A)D.C. differentially compound motor
B)A.C. slip ring motor
C)Synchronous motor
45. The starting torque of a D.C. motor is independent of which of the following?
A)Flux
B)Speed
C)Armature current
D)Flux and armature current
46. Which of the following happens when star-delta starter is used ?
A)Starting current is reduced
B)Starting voltage is reduced
D)Both Starting voltage is reduced and Starting current is reduced
47. In which of the following applications variable speed operation is preferred ?
A)Ceiling fan
B)Refrigerator
C)Exhaust fan
D)Water pump
48. In ____ method of starting three-phase induction motors the starting voltage is not reduced.
A)star-delta
B)any of these answers
C)auto-transformer
D)slip ring
49. In squirrel cage induction motors which of the following methods of starting cannot be used ?
A)Resistance in stator circuit
B)Star Delta Starting
C)Resistance in rotor circuit
D)Auto-transformer starting
50. Which of the following types of the motor enclosure is safest?
A)Open type
B)Totally enclosed fan cooled
C)Semi closed
D)Totally enclosed
51. Which of the following motors is usually preferred for kiln drives?
A)Cascade controlled A.C. motor
B)Three phase shunt wound commutator motor
52. Which of the following motors always starts on load?
A)Floor mill motor
B)Conveyor motor
C)All of these answers
D)Fan motor
53. While selecting motor for an air conditioner which of the following characteristics is of great importance?
A)Arrangement for power transmission
B)Type of enclosure
C)Type of bearings
D)None of these answers
E)Noise
54. The capacity of a crane is expressed in terms of
A)type of drive
C)span
D)tonnes
55. While selecting an electric motor for a floor mill, which electrical characteristics will be of least significance?
A)Running characteristics
B)Braking
D)Efficiency
56. In a series motor which of the following methods can be used for changing the flux per pole?
A)Tapped field control
B)Series-parallel control
C)Diverter field control
D)Any of these answers
57. Which of the following is essentially needed while selecting a motor?
A)Foundation pedal
B)Pulley
C)Bearings
D)Starter
58. Which of the following motors is preferred for traction work?
A)Three-phase induction motor
B)Universal motor
C)Synchronous motor
D)D.C. series motor
59. For a D.C. shunt motor which of the following is incorrect?
A)Unsuitable for heavy-duty starting
B)Torque-armature current is a straight line
C)Torque is zero for zero armature current
D)Torque varies as armature current
60. For which of the following applications ‘D.C. motors are still preferred?
A)Variable speed drive
B)High starting torque
C)High-efficiency operation
D)Reversibility
61. For blowers which of the following motors is preferred?
A)D.C. shunt motor
C)D.C. series motor
62. In jaw crushers a motor has to often start against ____ load.
A)medium
B)heavy
C)low
D)normal
63. ____ is preferred for automatic drives.
A)Any of these answers
B)Ward-Leonard controlled D.C. motors
D)Synchronous motors
64. The characteristics of drive for crane hoisting and lowering are which of the following?
A)Precise control
C)Smooth movement
D)Fast speed control
65. Which of the following motors is used for elevators?
B)Capacitor start single phase motor
C)Synchronous motor
D)Induction motor
66. ____ need frequent starting and stopping of electric motors.
A)Grinding mills
B)Lifts and hoists
C)Paper mills
D)Air-conditioners
67. The size of an excavator is usually expressed in terms of
A)crowd motion
B)travel in metres
C)angle of swing
D)cubic metres
68. In the case of ____ speed control by injecting e.m.f. in the rotor circuit is possible.
A)d.c. shunt motor
B)slip ring induction motor
C)schrage motor
D)synchronous motor
69. In a paper mill where constant speed is required
A)synchronous motors are preferred
B)individual drive is preferred
C)A.C. motors are preferred
D)group drive is preferred
70. Belted slip ring induction motor is almost invariably used for
A)none of these answers
B)centrifugal blowers
C)water pumps
D)jaw crushers
Next Quiz:
  • Electrical Meters Quiz
  • Electrical Symbols Quiz
  • Transformers Quiz
  • Equipment Grounding Quiz
  • Circuit Breaker Quiz
DC Generators Objective Questions and Answers
Armature Winding Questions
Power Systems MCQ Series 10
Electrical Machines MCQ Series 18
200+ Polyphase Induction Motor Multiple Choice Questions and Answers
Synchronous Machines Excitation Quiz
Electromagnetic Field Theory Questions and Answers
Autotransformers
Synchronous Machine Multiple Choice Questions
Synchronous Motor Power Factor Correction Questions
Electric Circuits Objective Questions – Set 3
Power Systems MCQ Series 19
225+ Electrostatics Objective Questions and Answers
Electrical Welding Multiple Choice Questions and Answers
Electrical Welding Multiple Choice Questions and Answers (MCQ)
Illumination Objective Questions
Induction Motor as a Transformer
Energy Conversion Quiz
Electrical Machines MCQ Series 4
Electrical Machines MCQ Series 19
cut way synchronous motor
Synchronous Motors MCQ – Multiple Choice Questions
Basic Electricity Objective Questions and Answers
100+ Basic Electricity Objective Questions and Answers
Mechanical Torsion Meter Principle
Career Scope in Civil Engineering
Instrument System Architecture and Process Control Design
System Architecture and Process Control Systems Philosophy
Pressure Regulator with Flapper-Nozzle Principle
Calibration MCQ - Terminology and Glossary Questions
Calibration MCQ – Terminology and Glossary Questions
Closed Tank Level Measurement using DP Transmitter
Cat and Mouse type Level Indicator
Learn PLC Programming
Basics of Ladder Diagram in PLC Programming
Synchronous Machines Power Angle Characteristics Questions
