Reading: Induction Motor Operating Characteristics
Inst Tools > Blog > Electrical Machines > Induction Motor Operating Characteristics
Last updated: December 22, 2018 1:16 am
Electrical Machines
3 Min Read
  • All torques of an induction motor, at a given slip, vary approximately as the square of the voltage applied to its terminals
  • Low rotor resistance results in high full load speed (low slip), high efficiency (low rotor losses), and slightly higher starting current.
  • High rotor resistance results in high starting torque for line current drawn and slightly lower current during starting, but results in lower full load speed and lower efÞciency (high rotor losses).
  • The slip at which maximum torque occurs is proportional to rotor resistance
  • Rotor frequency and voltage are proportional to slip. Thus, both are zero at synchronous speed, but increase to a maximum at zero speed (for slip range of 0 to 100%).
  • Rotor I2R losses are proportional to slip and are in the rotor winding of a squirrel cage motor. On a wound rotor motor, the secondary losses divide in proportion to the inherent rotor winding resistance and any connected external resistance.
For a pure inertia load (no load torque), the heat energy added to the rotor winding during acceleration (starting) is equal to the kinetic energy of the rotating mass at full speed. The total kinetic energy added to the rotating mass during acceleration to full speed is always the same for a particular value of motor and load inertia regardless of load torque.
The effect of load torque is to increase the heat energy added to the stator and rotor windings during acceleration to full speed due to longer accelerating time. The kinetic energy is added to the rotating mass at a rate determined by the accelerating torque (motor developed torque less load torque), and the heat added to the rotor winding is determined by the rotor current and the accelerating time.
The accelerating time (and the time the high starting current exists) is inversely proportional to the accelerating torque. Under low-voltage starting conditions, the ratio of heat added to the rotor compared to the kinetic energy at full speed is even greater because the accelerating torque is reduced (developed torque varies approximately as the square of the voltage), the load torque is unchanged, and the ratio of accelerating torque to load torque is reduced
Losses of Transformer
DC Motor Applications in Industries
Advantages & Disadvantages Induction Motor
What is Auto Reclosing?
Electrical Motor Starter Circuits
Use of line reactors
Parallel Operation of Alternators
Types of AC Motors and DC Motors
Difference between Permanent Magnet BLDC and DC Motor
Types of Generators
AC Motor Speed Control
Induction Motors Faults and Protection
Differences Between AC and DC Motors
BLDC Motor Vs AC Induction Motor
Why Armature is placed on Stator for Synchronous machines
Electrical-Switches-Working-Animation
Difference between Star and Delta Connections
Types of Transfomer Cooling Methods
Thermowell-Insertion-and-Immersion-Length
What is a Transformer Tap Changer
Transformer Energy Losses & Efficiency
Why Damper windings used in synchronous motors
Star to Delta Conversion
Star to Delta and Delta to Star Conversion Formula
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Types of Can Open network topologies
CANOpen Network Topology
What is an Actuator - Different Types of Actuators
What is an Actuator? – Different Types of Actuators
Differential Pressure Measurement
Demister Pads Problem
Problems with Demister Pads – Root Cause Analysis (RCA)
MOS Digital Integrated Circuits Objective Questions
Formula of 2 Wire RTD, 3 Wire RTD & 4 Wire RTD
car parking example logic
Up Down Counter Instruction in PLC
full-wave-bridge-rectifier-with-voltage-regulator
Basics of Voltage Regulators
