Reading: How to Select Control Valve Failure Mode
Inst Tools > Blog > Control Valves > How to Select Control Valve Failure Mode
Last updated: March 21, 2019 11:06 pm
Control Valves
10 Min Read
Valve fail mode may be shown in instrument diagrams by either an arrow pointing in the direction of failure (assuming a direct-acting valve body where stem motion toward the body closes and stem motion away from the body opens the valve trim) and/or the abbreviations “FC” (fail closed) and “FO” (fail open).
Control Valve Failure ModeSelecting the Proper Failure Mode
Other failure modes are possible, as indicated by this set of valve symbols:
Control Valves Failure Modes
In order for a pneumatic or hydraulic valve to fail in the locked state, an external device must trap fluid pressure in the actuator’s diaphragm or piston chamber in the event of supply pressure loss.
Valves that fail in place and drift in a particular direction are usually actuated by double-acting pneumatic piston actuators. These actuators do not use a spring to provide a definite fail mode, but rather use air pressure both to open and to close the valve.
In the event of an air pressure loss, the actuator will neither be able to open nor close the valve, and so it will tend to remain in position. If the valve is of the globe design with unbalanced trim, forces exerted on the valve plug will move it in one direction (causing drift).
It is important to note how the failure mode of a valve is often linked to its control action (airto- open, air-to-close). That is, an air-to-open pneumatic control valve will fail closed on loss of air pressure, and vice-versa.
This is an important fact because good safety engineering demands that the risk factors of the process determine proper valve failure mode rather than control system convention or habit.
People may find it easier to understand the operation of an air-to-open control valve than an air-to-close valve (more signal = more process fluid flow), but this should not be a guiding principle in valve selection.
Air-to-open control valves naturally fail closed which means they are appropriate for a particular process control application only if that process is safer with a failed-closed valve than with a failed-open valve.
If the process is safer with a fail-open valve, then the pneumatically-actuated control valve specified for that application needs to be air-to-close.
In fact, this basic principle forms the basis – or at least it should form the basis – of decisions made for all instrument actions in critical control loops:
first determine the safest mode of valve failure, then select and/or configure instrument actions in such a way that the most probable modes of signal path failure will result in the control valve consistently moving to that (safest) position.
For example, consider this automated cooling system for a large power-generating engine:
Valve Failure Mode
Clearly, it is more hazardous to the engine for the valve to fail closed than it would be for the valve to fail open. If the valve fails closed, the engine will surely overheat from lack of cooling.
If it fails open, the engine will merely run cooler than designed, the only negative consequence being decreased efficiency. With this in mind, the only sensible choice for a control valve is one that fails open (air-to-close).
However, our choices in instrument action do not end with the control valve. How should the temperature transmitter, the controller, and the I/P transducer be configured to act?
In each case, the answer should be to act in such a way that the valve will default to its fail-safe position (wide open) in the event of the most likely input signal fault.
Stepping “backward” through the control system from the valve to the temperature sensor, the next instrument we encounter is the I/P transducer. Its job, of course, is to convert a 4-20 mA current signal into a corresponding pneumatic pressure that the valve actuator can use.
Since we know that the valve’s failure mode is based on a loss of actuating air pressure, we want the I/P to be configured in such a way that it outputs minimum pressure in the event of an electrical fault in its 4-20 mA input signal wiring.
Whether the wiring fails shorted or fails open, the result will be 0 milliamps at the I/P input terminals. Thus, the configuration of the I/P transducer should be direct, such that a 4 to 20 mA input signal produces a 3 to 15 PSI output pressure, respectively (i.e. minimum input current yields minimum output pressure).
The next instrument in the loop is the controller. Here, we want the most likely input signal failure to result in a minimum output signal, so the valve will (once again) default to its “fail safe” position.
Consequently, we should configure the controller for direct action just like we did with the I/P transducer (i.e. a decreasing PV signal from a broken wire or loose connection in the input circuit results in a decreasing output signal).
Finally, we come to the last instrument in the control loop: the temperature transmitter (TT). As with most instruments, we have the option of configuring it for direct or reverse action. Should we choose direct (i.e. hotter engine = more mA output) or reverse (hotter engine = less mA output)?
Here, our choice needs to be made in such a way that the overall effect of the control system is negative feedback. In other words, we need to configure the transmitter such that a hotter engine results in increased coolant flow (a wider-open control valve).
Since we know the rest of the system has been designed so a minimum signal anywhere tends to drive the valve to its fail-safe mode (wide open), we must choose a reverse-acting transmitter, so a hotter engine results in a decreased milliamp signal from the transmitter.
If the transmitter has a sensor “burnout” mode switch, we should flip this switch into the low-scale burnout position, so a burned-out sensor will result in 4 mA output (low end of the 4-20 mA scale), thus driving the valve into its safest (wide-open) position.
Such a configuration – with its air-to-close control valve and a reverse-acting transmitter – may seem strange and counter-intuitive, but it is the safest design for this engine cooling system.
We arrived at this “odd” configuration of instruments by first choosing the safest control valve failure mode, then choosing instrument actions in such a way that the most likely signal-path failures anywhere in the system would result in the same, consistent valve response.
Of course it should go without saying that accurate documentation in the form of a loop diagram with instrument actions clearly shown is an absolutely essential piece of the whole system.
If the safety of a control system depends on using any “non-standard” instrument configurations, those configurations had better be documented so those maintaining the system in the future will know what to expect!
Another important detail in this system is to configure the controller such that the operator display for the output signal still registers in an intuitive way: 0% should still represent a shut control valve, while 100% should still represent a wide-open valve.
With the valve being air-to-close (signal-to-close from the controller’s perspective), this means the controller should be configured for reverse indication on the output display, so that an output of 4 mA (wide-open valve) reads 100% open, and an output of 20 mA (fully shut valve) reads 0%.
As confusing as this might be for the technician who must service the controller, it is more important that the operator using this controller every working day sees something that makes intuitive sense.
“Minor” details such as this become critically important if an emergency ever occurs, and the operator must make split-second decisions based on the indications they see.
Articles You May Like :
Dampers and Louvres
Control Loop MCQ
Piping & Instrumentation
Valve Characteristics
Valves Mechanical Friction
What is Lift Check Valve ?
What is a Hydraulic Valve? and their Types
Common Terms Used in Control Valves
Solenoid Valve Troubleshooting Tips
Electronic Valve positioners
Control Valve Cavitation and Flashing
  • RVSARADHI says:
    June 13, 2017 at 3:44 pm
    All topics are more theory base hence there is practical approach to material
    Hence kindly provide more useful subject in instrumentation in steady of bookish
    there are standard books ISA
What is Control Valve Flashing ?
Pressure Relief Valve Terminology
Automated Block Valve (ABV)
Solenoid Valve’s Energized or De-energized State ?
Spring and Diaphragm Pneumatic Actuators
ESDV : How it Works ?
Solving Control Valve Hunting: Instrument Troubleshooting
What is Needle Valve ?
Valve Actuator Passing
Lessons Learned from Actuator Passing Incidents
PRESSURE VARIATION CONTROL VALVe - 2
Constant Flow Valve Principle
Malfunctioning Inlet Check Valves
Objective Questions on Valves
Hammer Handwheel
Valve Handwheel Types : Fixed, Hammer, Gear
The Control Valve Stroke Test Procedure
Shaft and Coupling Bore Tapers Repair Caused Frequent Shutdowns
Control Valves Chemical attack Problems
SCADA Engineer
SCADA Engineer Job Responsibilities and Skills
AC Generator Nameplate Ratings
Which instrument is faulty
Which Instrument is Faulty? Transmitter, Recorder, or Controller
deadweight tester principle
Pressure Standards
Capacitive Field Effects on Conductors-4
Capacitive Coupling Effects
Differential Pressure Gauge Principle
Piston Type Differential Pressure Gauge Principle
10 Questions on Reforming Furnace Control System
TON Timer in RSlogix
Why is RTO used in the Place of TON Timer?
