Reading: Fundamentals of Radiochemical Methods Questions
Inst Tools > Blog > Multiple Choice Questions > Fundamentals of Radiochemical Methods Questions
1. Which of the following are highly effective in producing ion pairs when they pass through the matter?
a) Alpha particles
b) Beta particles
c) Gamma particles
d) X-ray particles
Answer: a
Explanation: Alpha particles are highly effective in producing ion pairs when they pass through the matter. They have relatively large mass and charge.
2. Which of the following can liberate photo electrons when they fall on certain metals?
a) Alpha particles
b) Beta particles
c) Gamma particles
d) X-ray particles
Answer: d
Explanation: X-rays can liberate photo electrons when they fall on certain metals. They penetrate through certain substances that are opaque to ordinary light.
3. Which of these particles are highly penetrating?
a) Alpha particles
b) Beta particles
c) Gamma particles
d) X-ray particles
Answer: c
Explanation: Gamma particles are highly penetrating. Upon interaction with matter, they lose energy in three modes.
4. Alpha emission is characteristic of heavier radioactive elements such as thorium, uranium, etc.
a) True
b) False
Answer: a
Explanation: Alpha emission is characteristic of heavier radioactive elements such as thorium, uranium, etc. They are most harmful to the human tissue.
5. Which of the following is not a mode by which beta particles lose energy on interaction with matter?
a) Photoelectric effect
b) Compton effect
c) Pair production
d) Collision effect
Answer: d
Explanation: Upon interaction with matter, gamma rays lose energy in three modes. They are photoelectric effect, pair production and Compton Effect.
6. The stability of the nucleus can be predicted by which of the following?
a) Electron to neutron ratio
b) Neutron to proton ratio
c) Proton to electron ratio
d) Neutron to electron ratio
Answer: b
Explanation: The stability of the nucleus can be predicted by neutron to proton ratio. The number of protons will always be equal to the number of electrons.
7. Which of the following is true about radiochemical methods?
a) Eliminate the need for chemical preparation
b) Not sensitive
c) Not accurate
d) Not specific
Answer: a
Explanation: Radiochemical methods eliminate the need for chemical preparation. In other method, chemical preparation has to be done before the measurement.
8. Which of the following formulae gives the expression for half-life of a radioactive isotope when ‘λ’ is the decay constant?
a) 0.762/λ
b) 0.693/λ
c) 0.937/λ
d) 0.258/λ
Answer: b
Explanation: The formula to calculate half-life of a radioactive isotope is 0.693/λ. It is the time required for half the initial stock of atoms to decay.
9. Which of the following emissions have low ionizing power?
a) Alpha particles
b) Beta particles
c) Gamma particles
d) X-ray particles
Answer: c
Explanation: Gamma particle emissions have low ionizing power. They also have high penetrating power.
10. Which of the following effect occurs when a gamma ray and an electron make an elastic collision?
b) Compton effect
c) Pair production
d) Collision effect
Answer: d
Explanation: Upon interaction with matter, gamma rays lose energy in three modes. Compton effect occurs when a gamma ray and an electron make an elastic collision.
11. Which of the following effects transfers all the energy of the gamma ray to an electron in the inner orbit of the atom of the absorber?
b) Compton effect
c) Pair production
d) Collision effect
Answer: a
Explanation: Upon interaction with matter, gamma rays lose energy in three modes. Photoelectric effect transfers all the energy of the gamma ray to an electron in the inner orbit of the atom of the absorber.
12. The basic unit used to describe the energy of a radiation particle is curie.
a) True
b) False
Answer: b
Explanation: The basic unit used to describe the energy of a radiation particle is electron volt (eV). The unit of radioactivity is curie.
Preliminary Considerations of Classical Design
Radiation Detectors Questions & Answers
Inductively Coupled Plasma Mass Spectrometer
Online Analyzers Questions & Answers
Digital Control Systems Multiple Choice Questions
Diagonalization
Detection System of Gas Chromatography Questions and Answers
The State Regulator Problem
Output Regulator & the Tracking Problem
PID Controller Multiple Choice Questions
Tuning of PID Controllers
Parameter Optimization : Servomechanims
Stability of Nonlinear System
Stability in Frequency Domain
Assessment of Relative Stability Using Nyquist Criterion
Differential Equations of Physical Systems & Dynamics of Robotic Mechanisms
Pulse Height Analyzer Questions & Answers
Control Systems Stability and Algebraic Criteria
Routh-Hurwitz Stability Criterion
Time Response Analysis
Time Response of First Order Systems Objective Questions
Feedback Compensation
Surface Grinding Process using PLC Program
Difference between Feedback, Feedforward, and Cascade Control
Difference between Feedback, Feedforward, and Cascade Control?
Junction Box Wiring
4-20mA Junction Box versus Fieldbus (FF) Junction Box
Control System
The need for automatic controls
illumination Multiple Choice Questions and Answers
illumination Multiple Choice Questions and Answers (MCQ)
Types of Tripping Protection in MCCB
Sox Nox Analyzer
Sox Nox Analyzer
