Reading: Functions of Pressure Detectors
Inst Tools > Blog > Pressure Measurement > Functions of Pressure Detectors
Last updated: May 23, 2018 11:45 am
3 Min Read
Pressure Detector Functions
Although the pressures that are monitored vary slightly depending on the details of facility design, all pressure detectors are used to provide up to three basic functions: indication, alarm, and control. Since the fluid system may operate at both saturation and subcooled conditions, accurate pressure indication must be available to maintain proper cooling. Some pressure detectors have audible and visual alarms associated with them when specified preset limits are exceeded. Some pressure detector applications are used as inputs to protective features and control functions.
Detector Failure
If a pressure instrument fails, spare detector elements may be utilized if installed. If spare detectors are not installed, the pressure may be read at an independent local mechanical gauge, if available, or a precision pressure gauge may be installed in the system at a convenient point. If the detector is functional, it may be possible to obtain pressure readings by measuring voltage or current values across the detector leads and comparing this reading with calibration curves.
Environmental Concerns
Pressure instruments are sensitive to variations in the atmospheric pressure surrounding the detector. This is especially apparent when the detector is located within an enclosed space. Variations in the pressure surrounding the detector will cause the indicated pressure from the detector to change. This will greatly reduce the accuracy of the pressure instrument and should be considered when installing and maintaining these instruments.
Ambient temperature variations will affect the accuracy and reliability of pressure detection instrumentation. Variations in ambient temperature can directly affect the resistance of components in the instrumentation circuitry, and, therefore, affect the calibration of electric/electronic equipment. The effects of temperature variations are reduced by the design of the circuitry and by maintaining the pressure detection instrumentation in the proper environment.
The presence of humidity will also affect most electrical equipment, especially electronic equipment. High humidity causes moisture to collect on the equipment. This moisture can cause short circuits, grounds, and corrosion, which, in turn, may damage components. The effects due to humidity are controlled by maintaining the equipment in the proper environment.
Summary
The three functions of pressure monitoring instrumentation and alternate methods of monitoring pressure are summarized below.
Pressure detectors perform the following basic functions:
  • Indication
  • Alarm
  • Control
If a pressure detector becomes inoperative:
  • A spare detector element may be used (if installed).
  • A local mechanical pressure gauge can be used (if available).
  • A precision pressure gauge may be installed in the system.
Environmental concerns:
  • Atmospheric pressure
  • Ambient temperature
  • Humidity
Inductance Type Pressure Transducers Principle
What is Sensor Trim and Output Trim in Smart Transmitter?
Pressure Gauge Installation at Pump Discharge
Capillary Tubing Pressure Sensor Temperature & Elevation Problems
Pressure Transmitters Purged impulse lines
Temperature Compensation for Pressure Measurement
Pressure Gauges with Bourdon Tube Principle
Top 30 Interview Questions on Pressure Measuring Devices
Diaphragm Pressure Sensors
Uncertainty Calculations of Pressure Calibration
What is Static Pressure Limit in DP Transmitter ?
How to Measure Pressure in Inches of Water Column
Identify the Pressure Gauge Error
Differential Pressure Flow Transmitter Interview Questions
Pressure Detection Circuit
Impulse Line Pressure Testing Procedure
Pressure Sensor Specifications
Magnehelic Gauge Calibration
Sample Raw DataSheet for Pressure Calibration
Capacitive Pressure Transducer
Capacitive Type Pressure Transducers Principle
5 Valve manifold
5 Valve Manifold Operation
4 TO 20 MA ANALOG CURRENT SIGNALS
Three-Phase Rectifier Quiz
HMI book
HMI Handbook
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Tank Gauging Measurement
Effect of Tank Design on Accuracy of Level Measurement
Why Do We Need to Connect Transformers in Parallel
Why Do We Need to Connect Transformers in Parallel?
overview-of-communication-protocols
Industrial Automation Communication Protocols
