Reading: MCQ on Flow Measurement
Inst Tools > Blog > Instrumentation MCQ > MCQ on Flow Measurement
Last updated: June 21, 2025 10:05 am
Instrumentation MCQ Multiple Choice Questions
5 Comments
MCQ ON Flow Measurement
1.A differential pressure transmitter is calibrated 0 to 80 inches of water and transmits a 4 to 20 mA dc signal. This transmitter is placed across an orifice plate which is sized to create 80 inches of water differential 6 gallons per minute. What is the flow rate when the signal is 13 mA dc?
a. 4.5 gpm
b. 3.9 gpm
c. 3.4 gpm
d. 4.9 gpm
Answer: a
2. For the equipment described in the preceding question, what will the signal be if the flow rate is 4 gpm?
a. 13.3 mA dc
b.11.2mAdc
c. 8.9 mA dc
d.6.7mA dc
Answer: b
3. Assume the line used in Questions 1 and 2, is a 1/2-inch schedule 40 pipe (IV = 0.622 inches). find the orifice bore used to satisfy the conditions given if the measured fluid is water at 60 Deg F
a. 0.190 inches
b. 0.556 inches
c. 0.414 inches
d. 0.352 inches
Answer: d
4. The best choice of orifice taps in the preceding problem would be:
a. flange taps
b. vena contracta taps
c. pipe taps
d. corner taps
Answer: d
5. A 2-inch schedule 40 line (lD = 2.067) is used to carry gasoline (SP GR = 0.75). The flow rate is measured with an orifice plate (d = 1.034) and pipe taps are used. At full flow rate, a differential pressure of 50 inches of water is produced. What is the approximate full flow rate in gpm?
a. 30 gpm
b. 53 gpm
c. 250 gpm
d. 36 gpm
Answer: d
6. Assume an 8-inch schedule 160 pipes (ID = 6.813 inches) carries a full flow of 40,000 pounds per hour of dry saturated steam. The static pressure is 335 psi. Flange taps are used and the differential pressure across the orifice plate at the full-flow rate is 100 inches of water. What is the size of the bore in the orifice plate?
a. 4.357 inches
b. 3.645 inches
c. 2.271 inches
d. 5.109 inches
Answer: d
7. Fuel gas is carried in a 6-inch schedule 40 pipe (ID= 6.065 inches). The flow rate is measured with an orifice plate using flange taps and the bare in the orifice is 3.457 inches. The specific gravity is 0.88, the flowing temperature is 60 °F, and the static pressure is 25 psi. Maximum flow rate creates a differential of 20 inches of water. What is the approximate flow rate in cubic feet per day?
a. 1,500,000 SCFD
b. 2,000,000 SCFD
c. 2,500,000 SCFD
d. 3,000,000 SCFD
Answer: a
8. The output of a target flowmeter is:
a. Proportional to volumetric flow rate
b. Proportional to the square of volumetric flow rate
c. Proportional to the square root of volumetric flow rate
Answer: b
9. The output signal or reading of a magnetic flowmeter is:
d. Inversely proportional to volumetric flow rate
Answer: b
10. With suspended solids and/or entrapped gas in a flowing liquid, the magnetic flowmeter will:
a. Read high
b. Read low
c. Read the liquid flow only
d. Read the correct total volume of the mixture
Answer: a
11. A turbine flowmeter produces an output in the form of pulses. The total number of pulses is:
a. Inversely proportional to flow
b. Directly proportional to total flow
c. Proportional to the square root of flow
d. Proportional to the square of flow
Answer: d
12. Match the head meter primary devices with the application (select a single best answer for each):
a. Orifice Plate         1.High Pressure recovery
b. Flow Nozzle         2. Air ducts
c. Venturi Tube       3. Sediment in liquid
d. Pitot tube            4. Economy & Accuracy are important
e. Elbow taps          5. No straight run available
Answer :  43125
Analyzers Based on Gas Density Questions & Answers
Secondary Reference Electrodes Questions & Answers
Pumps Quiz
Actuators Questions and Answers
Displacement Transducers Objective Questions
Solenoid Valve Terminology Questions and Answers
5 Comments
  • Joe says:
    January 4, 2018 at 10:40 pm
    We think question 1 should be c. Can you explain the answer?
  • Julius says:
    February 25, 2019 at 10:00 pm
    Most of the answers are wrong
  • Shetty says:
    February 26, 2019 at 6:57 am
    Hi Julius, Please share your answers with explanation.
  • Maya says:
    March 8, 2019 at 12:08 am
    Can to discuss the answer
  • Sneha says:
    April 14, 2022 at 10:45 am
    In question 9 answer should be (a)
Fluorescent Spectrometer Questions & Answers
Active Electrical Filters Objective Questions
Fluidic Systems Objective Questions
Solution of State Equations
Inductive Transducers Objective Questions
250+ Electronic Measurements and Instrumentation MCQ Questions
Viscosity Measurement Objective Questions
Electrochemical Methods for Oxygen Analysis Questions & Answers
AC Circuits Multiple Choice Questions
Optimal Control Systems
The Infinite Time Regulator Problem
Temperature Measurement Multiple Choice Questions
Measurement and Instrumentation Objective Questions – Part 2
X-Ray Fluorescence Spectrometry Questions and Answers
Gas Chromatography Questions & Answers
Limit Switch Questions and Answers
Top 50 Limit Switch Questions and Answers
Ion Analyzers Questions and Answers
Ammonia and Fluoride Electrode Questions & Answers
SCADA Standards
SCADA for Substation Automation
Ionization of Gases Questions and Answers
PCB Making Machine
Beyond FR-4: Exploring Novel Materials for PCB Fabrication
Difference Between Squirrel Cage and Slip Ring Motors
Hydrogen sulfide gas
Hydrogen Sulfide Gas (H2S)
Use of Regions in SCL Language
Control Valve Failure Rate Calculation
Process Air Compressor Overhauls Eliminated
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
