  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Flame Ionization Detector (FID) Principle
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Analyzers > Flame Ionization Detector (FID) Principle
Last updated: November 15, 2018 9:37 am
Analyzers
2 Min Read
Several different detector designs exist for process gas chromatographs. The two most common are the flame ionization detector (FID) and the thermal conductivity detector (TCD). Other detector types include the flame photometric detector (FPD), photoionization detector (PID), nitrogenphosphorus detector (NPD), and electron capture detector (ECD). All chromatograph detectors exploit some physical difference between the solutes and the carrier gas itself which acts as a gaseous solvent, so that the detector may be able to detect the passage of solute molecules (sample gas components) among carrier molecules.
Also Read : GC Detectors Questions & Answers
Flame Ionization Detectors
Flame ionization detectors work on the principle of ions liberated in the combustion of the sample species. Here, the assumption is that sample compounds will ionize inside of a flame, whereas the carrier gas will not. A permanent flame (usually fueled by hydrogen gas which produces negligible ions in combustion) serves to ionize any gas molecules exiting the chromatograph column that are not carrier gas. Common carrier gases used with FID sensors are helium and nitrogen, which also produce negligible ions in a flame. Molecules of sample encountering the flame ionize, causing the flame to become more electrically conductive than it was with only hydrogen and carrier gas. This conductivity causes the detector circuit to respond with a measurable electrical signal.
A simplified diagram of an FID is shown here:
Hydrocarbon molecules happen to easily ionize during combustion, which makes the FID sensor well-suited for GC analysis in the petrochemical industries where hydrocarbon composition is the most common form of analytical measurement. It should be noted, however, that not all carboncontaining compounds significantly ionize in a flame. Examples of non-ionizing organic compounds include carbon monoxide, carbon dioxide, and carbon sulfide. Other gases of common industrial interest such as water, hydrogen sulfide, sulfur dioxide, and ammonia likewise fail to ionize in a flame and thus are undetectable using an FID.
Also Read : GC Principle
Recommended Articles
Dispersive Spectroscopy
Moisture Calculator
Multi Column Gas Chromatograph
Dew Point Meter Principle
NDIR Analyzer Filter Cells
Single-beam Non-dispersive Analyzer
208kSubscribersSubscribe
Recent Comments
Related Articles
gas chromatograph (GC)
Industrial Applications of Chromatographs
ORP Measurement
Basics of ORP Measurement
span gas cylinders
Analyzer Sample Systems
ORP-sensor-calibration
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
pH Analyzer Calibration and Troubleshooting
Troubleshooting pH Analyzer Common Problems
Free chlorine Analyzer Principle
NDIR gas analysis
Non-Dispersive Analyzers
Hair Hydrometer Principle
More Articles
How to Run Multiple Motors with a Single VFD
How to Run Multiple Motors with a Single VFD?
two-way communication between PLC systems
Transferring Data Across PLC Systems – TSEND_C and TRCV_C
Power Systems MCQ Series 2
Manual Call Point Testing Procedure
Inductive Transducers Objective Questions
Pressure Gauge Datasheet Preparation
How to Prepare Pressure Gauge Datasheet ?
Dissolved oxygen measurement using Optical Fiber Communication
Fiber Optic Sensors
How to Use Loop Calibrator
Troubleshooting with Loop Calibrator
