Reading: Fieldbus Device Capability
Inst Tools > Blog > Communication > Fieldbus Device Capability
Last updated: May 18, 2019 3:32 pm
Communication
2 Min Read
Not all FF devices are equally capable in terms of Data Link (layer 2) functions. The FF standard divides data link device functionality into three distinct groups, shown here in order of increasing capability:
  • Basic devices
  • Link Master devices
  • Bridge devices
A Basic device is one capable of receiving and responding to tokens issued by the Link Active Scheduler (LAS) device. As discussed previously, these tokens may take the form of Compel Data (CD) messages which command immediate response from the Basic device, or Pass Token (PT) messages which grant the Basic device time-limited access to the segment for use in broadcasting data of lesser importance.
A Link Master device is one with the ability to be configured as the LAS for a segment. Not all FF devices have this ability, due to limited processing capability, memory, or both.
Some FF devices capable of performing advanced function block algorithms for certain process control schemes may have the raw computational power to be an LAS, but the manufacturer has decided not to make them Link Master capable simply to allow their computational power to be devoted to the function block processing rather than split between function block tasks and LAS tasks.
A Bridge device links multiple H1 segments together to form a larger network. Field instruments are never Bridge devices – a Bridge is a special-purpose device built for the express purpose of joining two or more H1 network segments.
Foundation Fieldbus Installation and Best Practices
Advantages and Disadvantages of Network Topologies
H1 FF Device Configuration and Commissioning
Why Fiber Optic Cable is Spliced rather than Termination?
Different Fieldbus Network Topologies
Foundation Fieldbus (FF) Segment Topology
Basics for CAN Bus Protocol – Controller Area Network
What is Timeout in Communication Protocols?
CANOpen Network Topology
What is Rapid Spanning Tree Protocol? – RSTP Network
Ethernet Communication Interview Questions & Answers
Foundation Fieldbus Interview Questions and Answers
Difference Between Ethernet IP and EtherCAT
How to Use Modbus Poll and Modbus Slave Software?
Types of Cable Lengths in Ethernet Network
Industrial Networking Interview Questions
Industrial Networking and Wireless Interview Questions
What is Profibus
All About Fieldbus Protocols
Transmission Control Protocol
Fieldbus Segment Design
Foundation Fieldbus Segment Design
Input function blocks
FF Function Blocks
Dissolved oxygen measurement using Optical Fiber Communication
Fiber Optic Sensors
OPC-OLE-for-Process-Control
What is OPC ?
Fiber Optic Cable Construction
Burnout Function in Temperature Transmitter
As-Found and As-Left data during Calibration
Why it is important to note As-Found and As-Left data during Calibration?
Boiler Feed Water Treatment
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
Temperature Sensor Failure
steam heat exchanger
Practical Process Control System Questions & Answers – 9
Difference Between Squirrel Cage and Slip Ring Motors
