Reading: Electrical Cables Interview Questions & Answers
Inst Tools > Blog > Electrical Q & A > Electrical Cables Interview Questions & Answers
Last updated: September 11, 2016 6:56 am
Electrical Q & A
2 Min Read
What is the main reason for providing metallic sheath in underground cables?
The metallic sheath is provided around the insulation to protect it against the ingress of moisture, gas and other damaging liquids (acid or alkalies) from the soil and atmosphere.
What are the main requirements of the insulation materials used for underground cables?
Some the properties that insulation material require to possess are high insulation resistivity, high dielectric strength, good mechanical properties, non-hygroscopic, non inflammable, immune to attacks by acids and alkalies.
What are the advantages and disadvantages of oil filled cables?
Some of the advantages and disadvantages of oil filled cables are listed below:
Advantages:
  • Smaller overall size and smaller weight for given voltage and kVA rating due to reduction in the thickness of the dielectric required
  • No ionization, oxidation and formation of voids
  • More perfect impregnation
  • Smaller thermal resistance due to decrease in the dielectric thickness, so higher current rating
  • More maximum permissible stresses
  • Fault identification is easy
Disadvantages:
  • Greater cost
  • Complicated laying of cables and maintenance
Advantages of XLPE cables compared to PVC cables?
  •  XLPE cable can withstand higher temperature (900C) compared to PVC (700C)
  • XLPE cables can have higher over-load capacity
  • XLPE cables are lighter in weight and smaller bend radius hence lower installation cost
  • XLPE cable has high short circuit rating
  • It has lower dielectric and constant power factor which can result in saving of power
What are different insulation materials used in cables for high voltage and medium voltage?
Medium Voltage:
  • Polyethylene (PE)
  • Cross linked polyethylene (XLPE)
  • Tree retardant cross linked polyethylene (TR-XLPE)
  • Ethylene-Propylene Elastomers (EPR)
  • PILC
High Voltage:
  • Paper/Oil
  • Paper/Polypropylene
  • SF6 gas
Basic Power Electronics Interview Questions
Electrical Engineering Interview Questions
Generator Protection Interview Questions & Answers
Electrical Drives Questions & Answers
High Voltage and Power System Stability Interview Questions
  • amir kh says:
    September 23, 2021 at 11:58 am
    i am producer. I have a question for you. We are in the production of wires and cables. When we produce wires, our wires around the conductor are not uniformly covered. In fact, the covering of the wires is non-uniform and wavy. It can be whether the vibration of the wire can cause it
Industrial Automation and Control Interview Questions
Electrical Machines Short Answers
Power System Interview Question and Answers
Three Phase Induction Motor Interview Questions & Answers
Electrical Machines Interview Questions and Answers
Protection Relays Interview Questions & Answers
transformers-questions-answers-part-1
Transformers Questions & Answers Part-1
Instrumentation Engineering Standards Interview Questions & Answers
Electrical Machines Objective Questions & Answers
Top Electrical Engineering Interview Questions for Freshers
Latest Electrical Motors Questions and Answers
Transmission Lines Protection Questions Answers
Substation Interview Questions Answers
PLC Program for Temperature Control using Thermostat
input-output-relationships-of-transmitters
Input-Output Relationships of Transmitters
Random Access Memory Objective Questions – Part 4
PLC Programming Examples using Timer
Basic PLC Ladder Programming Example
Measurements & Instrumentation Quiz – Set 2
Lamp Counter Logic
Function Block (FB) for Motor Control Logic
Sample Schematic Template for Systems Architecture Diagram
What is an RTU - Remote Terminal Unit
What is an RTU? – Remote Terminal Unit
