Reading: Digital Control Systems Multiple Choice Questions
Inst Tools > Blog > Instrumentation MCQ > Digital Control Systems Multiple Choice Questions
Last updated: June 21, 2025 10:09 am
Instrumentation MCQ Multiple Choice Questions
Question 1
The acronym DCS stands for:
(A) DeltaV Console Services
(B) Distributed Control System
(C) Direct Cascade Sequencing
(D) Differential Concentration Switch
(E) Digital Control System
Answer : B
Question 2
Many digital control systems utilize Ethernet as a communications network, because . . .
(A) no terminating resistors are necessary
(B) speed is not affected by traffic
(C) it is a wireless network standard
(D) it is fully deterministic
(E) it is robust and inexpensive
Answer : E
Question 3
Resolution refers to in the analog-to-digital conversion portion of a digital control system.
(A) the analog signal range
(B) how determined the designer was
(C) the number of active bits
(D) the speed of analog signal sampling
(E) the probability of hardware failure.
Answer : C
Question 4
Parity bits are used for the purpose of in digital systems.
(A) power monitoring
(B) error detection
(C) symmetry generation
(D) diagnostic monitoring
(E) time-stamping data
Answer : B
Question 5
A typical use for an integer variable in a digital control system is:
(A) Representing single switch status
(B) Representing power supply voltage
(C) Counting discrete events
(D) Trigonometric math operations
(E) Exponential math operations
Answer : C
Question 6
TIA/EIA-485 (formerly known as RS-485) is a digital communication standard with the following traits:
(A) Single-ended voltage signaling, multidrop
(B) Frequency Shift Key (FSK) signaling, superimposed on analog 4-20 mA
(C) Manchester encoding, multidrop
(D) Mark-and-space signaling, point-to-point
(E) Differential voltage signaling, multipoint
Answer : E
Question 7
FOUNDATION Fieldbus is unique in that:
(A) It has always been the leading fieldbus standard
(B) Data communication is entirely deterministic
(C) Power and data share the same wires
(D) Diagnostic data is communicated as well as process data
(E) Control algorithms may reside in the field devices
Answer : E
Question 8
A watchdog timer is a device or a programmed routine used for what purpose in a digital control system?
(A) To interrupt normal program flow and address an immediate need
(B) To check for errors in data communications
(C) To provide time delays for critical functions
(D) To monitor the operation of the microprocessor
(E) To signal the start of a new program cycle
Answer : D
Question 9
Digital control systems are generally superior to analog control systems, but they are always worse with regard to:
(A) Speed
(B) Diagnostics
(C) User-friendliness
(D) Flexibility
(E) Noise immunity
Answer : A
Question 10
A triple modular redundant (TMR) digital control system would be typically used for what purpose?
(A) To save energy (compared to other control systems)
(B) To control a potentially dangerous process
(C) To increase response speed for fast processes
(D) To save money (compared to other control systems)
(E) To minimize routine maintenance requirements
Answer : B
Credits : by Tony R. Kuphaldt
Direct Method & Constructing of Liapunov for the Linear & Non-Linear System
Sodium Analyzer Questions & Answers
GATE Instrumentation Questions and Answers
Ionization Transducers Objective Questions
  • Sowmya S says:
    June 27, 2019 at 7:09 pm
    It is distributed control system multiple choice right. But in the beginning y did u mention digital control system multiple choice??
Analog Modulators Objective Questions
Top 1000 Analytical Instrumentation Questions & Answers
Mathematical Preliminaries
Actuators Questions and Answers
Liapunov’s Stability Criterion – Part II
Effect of Adding a Zero to a System
Fuzzy Logic Control
Adaptive Control
Control Systems Stability and Algebraic Criteria
Routh-Hurwitz Stability Criterion
Electron Spin Resonance Questions & Answers
Measurement of Resistance Objective Questions
Flow Measurement Questions
MCQ on Flow Measurement
Frequency Measurement Objective Questions
Process Control & Instrumentation Objective Questions – Set 4
Fluorescent Spectrometer Questions & Answers
PLC IO Examples
Quiz: Identifying I/O Examples in PLC Systems
Process vessel for measuring water level
Level Measurement Lab Exercise
How to Install Thermowell on an Elbow?
Sugar Plant - Automatic Control of Massecuite Feed
Sugar Plant – Automatic Control of Massecuite Feed
Batch Mixing with PLC Ladder Logic Program
Four Wire RTD Principle
How a 4 Wire RTD Works ?
Instrument Calibration Questions
PLC Problems Troubleshooting
Industrial Internet of Things Projects
Top 100 Industrial Internet of Things Projects (IIoT)
