Reading: Difference between Current Transformer and Potential Transformer
Inst Tools > Blog > Electrical Basics > Difference between Current Transformer and Potential Transformer
Last updated: September 19, 2016 1:51 am
Electrical Basics
2 Min Read
Current Transformers (CT) and Potential Transformers (PT) are used to measure the current and voltage in a circuit of the order of hundreds of amperes and volts respectively.
A CT has large number of turns on its secondary winding, but very few turns on its primary winding. The primary winding is connected in series with the load so that it carries full load current. A low voltage range ammeter (0-5A) is connected across the secondary winding terminals. Secondary of the CT is practically short circuited since the ammeter resistance is very low. It should be remembered that secondary of the CT should not be made open as it draws heavy current and damages the primary winding of the CT
A PT has large number of turns in the primary and fewer turns in the secondary and hence it steps down the voltage. The primary winding is connected across the supply voltage and low range voltmeter (0-110V) is connected across the secondary winding terminals
Some of the main difference between current transformers (CT) and potential transformers (PT) are given below:
  • The secondary of the CT is almost short circuit, whereas the secondary of the PT is practically a open circuit
  • The primary winding of the CT is connected in series with the load so that it carries the full line current, but there is only a small voltage across it. However the primary winding of the PT has the full supply voltage applied across it
  • In CT the excitation current I0 and flux density vary over a wide range whereas in PT, they vary over a limited range only
How to Test a Motor using Megger?
Difference between Servo Motor and DC Motor
Circuit Breaker Testing – Routine Tests of Circuit Breakers
Basics of Electricity Rates
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
Automatic Transfer Switch – Electrical Circuit, Operation, Video
Difference between AC and DC
What is Transformer Bushing? Working Principle
What is a Solid State Relay? – Working Principle, Types of Control
Types of Relays used in an Air Circuit Breaker (ACB)
Difference Between Circuit Breaker and Disconnector
Difference Between Earth and Neutral
Difference Between Short Circuit and Ground Fault
Types of Filters used in Air Compressors
How Do Air Compressor Filters Clean and Protect the System?
How do AC drives work
How do AC Drives Work? – Variable Frequency Drive (VFD)
Wave Trap in Power Line carrier Communication
What is a Wave Trap? – Power Line Carrier Communication
How to Read and Understand an Electrical Single Line Diagram?
What is Electrical Panel Door Earth Bonding? Explained
Lithium-ion Battery Charging System
Lithium-ion Battery Charging Systems
Typical Switchyard Layout
Electrical Substation – Busbar Arrangements and Layouts
Electrical Equipment Selection in Hazardous Area
Siemens PLC Organization Blocks used For Troubleshooting
Tia Portal – OB121 Programming Errors Interrupt Organization Block
Transformer Protection using fire water spray system
Fire Water Spray Systems Principle
Weir Diaphragm Valve
Diaphragm Valves Construction, Types, Stem & Bonnet Assembly
diodes-questions-answers
Diodes Questions & Answers
Analog Measurement using Ladder Logic
DCS System Cabinet
Yokogawa DCS System Maintenance Procedures
Lead Acid Battery Operation
How does a Lead Acid Battery Work?
Electrical Resistance Temperature Curves of RTD
Resistance Temperature Detectors (RTD) Construction
