Reading: DC Motor Applications in Industries
Inst Tools > Blog > Electrical Machines > DC Motor Applications in Industries
Last updated: April 24, 2016 6:14 pm
Electrical Machines
1 Min Read
In spite of wide use of ac supply, dc machines have some advantages compared to ac motors and are used in industries for some applications. Some of the applications where dc motors employed are listed below
DC Series Motor:
  • DC series motors are widely used for electrical traction applications, i.e, these motors are widely used in electric locomotives, rapid transit systems and trolley cars
  • DC series motors are employed in cranes, hoists and in conveyers because of high staring torque capability
DC Shunt motor:
  • DC shunt motors are employed in rolling mills because of good speed control characteristics
  • They are employed for driving constant speed lathes
  • Also employed for driving centrifugal pumps, fans, blowers, machine tools and reciprocating pumps
Cumulative Compound motors:
  • They are employed in applications such as: Elevators, conveyers, heavy planers, for shears and punches, for intermittent high torque loads and air compressors
Synchronous Generator Salient Pole vs Non Salient Pole
Losses in a DC Generator
Induction Motor Operating Characteristics
Differences Between AC and DC Motors
Synchronous Motor Working Principle
Difference between Induction motor and Synchronous motor
Advantages & Disadvantages Induction Motor
Why Damper windings used in synchronous motors
Losses of Transformer
What is a transformer tap changer?
Advantages of Hydrogen cooling in Synchronous Generators
Synchronous Motor Starting Methods
Difference between Permanent Magnet BLDC and DC Motor
Transformer Open and Short Circuit Tests
Faults in a Transformer
BLDC Motor Vs AC Induction Motor
Advantages and Disadvantages of Squirrel Cage Induction motor
Metering pumps
Metering Pumps
Alarm Trip for 24v DC Loop
Advantages & Disadvantages of Synchronous Motors
Why Starting Current of Induction Motor is High
VFD circuit
AC Motor Braking
AC Induction Motor Construction
Basics of AC Induction Motors
How to Install Thermowell on an Elbow?
Transistor Load Line Analysis
Surge Impedance Loading of Transmission Line
LVDT-Operation-Principle-Animation
LVDT Working Principle Animation
Redundant Power Supply
How Does Redundant Power Supply Work?
control of pneumatic systems
Control of Pneumatic Cylinder and Motor
Electric Motors Efficiency Classes
Floating Neutral - Electrical Engineering Basics
What is Floating Neutral? – Electrical Engineering Basics
