Reading: What is a Buchholz Relay? Working Principle
Inst Tools > Blog > Electrical Basics > What is a Buchholz Relay? Working Principle
The Buchholz relay is used to detect internal faults in an oil-filled transformer and it works on the theory of gas detection.
Last updated: April 18, 2023 12:22 pm
Electrical Basics
6 Min Read
A transformer is a very important component in electrical applications. It is used to step up or step down a voltage. It can come in both lower and higher voltages. For higher voltages (more than 500 kVA), mostly oil-filled transformers are used.
What is a Buchholz Relay?Working Principle of Buchholz RelaySchematic Diagram of a Power Transformer
As they work in higher voltages, there are bound to occur many internal faults like insulation failure, oil failure, windings failure, partial discharge, short circuits, arcing, etc.
If these failures are not detected, then they will result in damage to the transformer. For this, a special type of relay called the Buchholz relay is used.
In this post, we will learn the concept of a Buchholz relay.
The Buchholz relay is used to detect internal faults in an oil-filled transformer. Remember that oil is used as insulation for the transformer body. Buchholz Relay works on the theory of gas detection.
The Buchholz relay is also termed as safety device used in the oil-filled transformers.
Refer to the below image for understanding.
When internal faults occur inside, the current shoots up to a very high abnormal range. This high current automatically increases the operating temperature inside. As oil is filled inside, due to the excess heat generated, it starts to evaporate. As it starts to turn into gaseous form, moves upwards towards the oil conservator.
The relay is placed between the conservator and transformer tank (body). It detects this gas and immediately trips the circuit. This means the transformer is shut off for operation, which prevents any untoward incident.
As discussed earlier, the Buchholz relay works on gas detection. Refer to the below image for understanding. It majorly consists of two float switches (one upper and one lower). It is arranged exactly between the transformer tank output and the conservator input.
Now, the formula is simple – the less the trip current, the less the heat generated, and the less will be gas generated; the more the trip current, the more will be heat generated and more will be gas generated.
So, in a normal working conditions without any trip, there will no gas from the tank into the transformer. But, in an abnormal condition with any failure, the oil will start to evaporate and gas will be generated. This gas will then start flowing through the relay to the conservator reservoir.
Now, you can see that the gas first enters from the lower entry and goes out from the relay through the upper entry. The lower entry has a lower float (blue color circle) and the upper entry to has an upper float (blue color circle).
The float’s mechanical design is such that the upper float can be displaced by a small amount of gas, while the lower float requires a rapid and substantial gas displacement. In case of minimal gas presence, the upper part will be affected while the lower part will remain unaffected.
After some time, the gas will slowly start moving the upper float, and once moved, it will switch the contact of an alarm circuit to generate an alarm. This will indicate that a failure has started to generate in the transformer tank.
If the gas suddenly moves swiftly and in a large quantity from the bottom entry, then its force will move the lower float. This will immediately switch the contact of the trip circuit and trip the transformer connection.  Thus, this relay will prevent the transformer from being damaged.
The mechanical lock is provided in that relay so that one can lock the movement of mercury switches (float) when oil is topping up in the transformer. This mechanical locking also helps to prevent unnecessary movement of breakable glass bulbs of mercury switches during transportation of the Buchholz relays.
Schematic diagram of a Power Transformer
Image Attribution: Fluppe37 at nl.wikipedia
The part numbers are mentioned below.
  1. Tank
  2. Lid
  3. Conservator tank
  4. The oil level indicator (end of conservator tank)
  5. Buchholz relay for detecting gas bubbles after an internal fault
  6. Piping to conservator tank and Buchholz relay
  7. Tap changer to change output voltage
  8. The motor drive of the tap changer (can be controlled by an automatic voltage regulator)
  9. Drive shaft for tap changer
  10. High voltage (HV) bushing connects the internal HV coil with the external HV grid
  11. High voltage bushing current transformers for measurement and protection
  12. Low voltage (LV) bushing connects LV coil to LV grid
  13. Low voltage current transformers .
  14. Bushing voltage-transformer for metering the current through the passing bushing
  15. Core
  16. Yoke of the core
  17. Limbs connect the yokes and hold them up
  18. Coils
  19. Internal wiring between coils and tapchanger
  20. Oil release valve
  21. Vacuum valve
In this way, we saw the working of the Buchholz relay.
  • Industrial Circuit Breakers
  • Electrical Motor Concepts
  • Relays in Air Circuit Breaker
  • Induction Motor Over Voltage
  • Purpose of Electrical Substation
Variable Motor Speed Control
What is Power Cable? Types of Power Cables
What is Switchgear and Electrical Substation?
Difference Between Single Core and Multi-Core Cables
One Nation One Grid One Frequency – Electrical Engineering
Motor Maintenance, Troubles, Regular Checks, Performance
How to Test a Motor using Megger?
Types of Relays used in an Air Circuit Breaker (ACB)
Basic Electrical Engineering Questions & Answers
What is a Lightning Arrester? How does it work?
What is a Time Delay Relay? Principle, Advantages, Disadvantages
Formula of AMP, KW, KVA, HP for AC and DC Voltages
Difference Between RCCB and MCCB
simple latching motor control circuit
Motor Control Circuit Wiring
What are Switchgear Interlocks?
Advantages of Star and Delta Systems
What is a Power Transformer
What is a Power Transformer? – Components and Types
Fence grounding specifications
All About Electric Fence Gates
Why Are Charcoal and Salt Added to an Earthing Pit
Why Are Charcoal and Salt Added to an Earthing Pit?
What are HP and LP Switches in HVAC
Motor Disconnector Switch
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Why Restriction Orifice is some distance from Blowdown valve
Why Restriction Orifice is some distance from Blowdown valve ?
What is a Tachometer
What is a Tachometer? – Types, Working Principle
Control Valves Chemical attack Problems
Difference Between PLC and CNC Machine
Types of Industrial Storage Batteries
Electric Motor Actuator Parts
Level-Measuring-Instruments-Velocities-of-Propagation
Level Measuring Instruments Velocities of Propagation
How to Test Diodes Using Multimeter
