Reading: Advantages of Hydrogen cooling in Synchronous Generators
Inst Tools > Blog > Electrical Machines > Advantages of Hydrogen cooling in Synchronous Generators
Last updated: December 22, 2018 1:15 am
Electrical Machines
2 Min Read
Cooling system should be provided in the generator or alternator to remove the heat generated in the windings (I2R loss) of the generator. Inability to remove the heat results in damage to the winding insulation of the generator and can lead to reduction in the life span of the generator. Natural air cooling and forced air cooling is provided for the small rating generators.
However for the generators rated above 60MW the amount heat generated will be enormous and air cooling is insufficient to cool the generator. Therefore hydrogen cooling is employed to remove the heat generated. Hydrogen cooling is chosen because of few characteristics of the hydrogen gas. Along with hydrogen cooling water cooling is provided in the stator winding circuit for large generators
Advantages of Hydrogen cooling:
  • The density of the hydrogen is 1/14th that of the air, the power required to circulate hydrogen (pumping capacity)  is about 1/14th of the power required for an equivalent quantity of air. Hence the losses are reduced and the efficiency of the machine is improved by about 1% of the full load power of the machine. For example consider 500MW generator, the amount of energy saving constitutes almost 5MW which is a much more power
  • Hydrogen has specific heat 14 times,  heat transfer coefficient 1.5 times and thermal conductivity 7 times that of the air. So it has excellent heat carrying capacity compared to air. A generator using hydrogen as a coolant may be rated about 20% higher than the same physical size using the air
  • The life of the generator is decided by the life of the winding insulation. By using hydrogen cooling which has better heat transfer coefficient, life of winding insulation increases resulting in the more life of the generator
  • Smaller size of heat exchanger/cooler is required to cool the heated hydrogen
Difference between Star and Delta Connections
Difference between Induction motor and Synchronous motor
DC Motor Applications in Industries
Advantages & Disadvantages Induction Motor
Induction Motor Operating Characteristics
Types of Transfomer Cooling Methods
Faults in a Transformer
Why Starting Current of Induction Motor is High
Importance of Hysteresis Loop
BLDC Motor Vs AC Induction Motor
What is a transformer tap changer?
Applications of Synchronous Motors
Zigzag Transformers Theory
AC Induction Motor Construction
Basics of AC Induction Motors
Motor Star Delta Connections
Distribution transformer
Types of Transformers
Metering pumps
Metering Pumps
What happen When Synchronous Generator loss Excitation
Transformer Energy Losses & Efficiency
Difference Between Squirrel Cage and Slip Ring Motors
Synchronous Motor Is Not Self Starting?
Difference between RTJ and T&G Flanges
Difference between RTJ and T&G Flange Facings
Questions on Resistive Tape Level Sensor
What is a Network Switch?
Gauge Cock
Pressure Gauge Cocks
Chromatographic Behaviour of Solutes Questions & Answers
pH Monitoring System Triggers an Alarm
Control Valve Parts
Basic Parts of Control Valves
Types of Diodes Quiz
