Reading: Advantages of HVDC transmission
Inst Tools > Blog > Transmission & Distribution > Advantages of HVDC transmission
Last updated: September 19, 2016 2:21 am
3 Min Read
High voltage transmission is employed to transfer the bilk power from sending end to receiving end with lesser losses. Generally power is transferred in ac because of the feasibility in stepping up the voltage and stepping down. However with increase in voltage levels beyond 400kV ac EHV transmission has certain disadvantages such as corona loss, insulation requirement for conductor, radio interference and heavy supporting structures (clearance required between phase to phase and phase to ground increases with increase in voltage).
Therefore for transmission with EHV voltages HVDC transmission is economical. Some other advantages includes:
Advantages:
  • No Skin Effect: In HVDC transmission current distributes uniformly over the cross section of the conductor. Hence no loss due to skin effect is encountered. For the same current carrying capacity HVDC lines have lesser cross section compared to ac HV lines
  • Lower Transmission Losses: HVDC transmission requires only two conductors. Therefore the power loss in dc line will be lesser compared to ac line
  • Good voltage Regulation: In dc lines voltage drop does not exist due to inductive reactance. Voltage Regulation will be better in HVDC transmission
  • Surge Impedance Loading: Long EHV lines are loaded to less than 80% of natural load. No such condition is applicable in HVDC transmission
  • No Line Loading Limit: The permissible loading limit on EHV AC lines are limited by the transient stability limit and the line reactance to almost one third of the thermal rating of the conductors. No such limit exist in the case of HVDC line
  • Lesser Coronal Loss and Radio Interference: Corona Loss directly proportional to frequency. Therefore in DC line corona loss will be lesser compared to AC line
  • Higher Operating Voltages: Design of Insulation of the conductors for high voltage transmission lines depends on the switching surges but not on lightning surges (for voltages beyond 400kV switching surges are more severe than lightning surges). The level of switching surge will be lesser in dc line compared to ac line. Hence less insulation is required in dc line
  • Reactive Power Compensation: Unlike AC line DC line does not require any reactive power compensation devices. This is because of the absence of charging currents and power factor operation.
  • Short circuit currents during fault in dc line will be lesser compared to ac lines.
  • Absence of the charging currents and limitations on the cable lengths
  • Economical and greater reliability
Conductor Size Selection in Distribution Power System
Comparison of HVDC transmission and HVAC transmission
Electrical Power Distribution
Electrical Power Transmission And Distribution
Single Phase Earth Return System Advantages & Disadvantages
Advantages of Suspension Insulators and Pin type Insulators
Advantages of Bundled Conductors in Transmission Lines
Insulating Material for Cable Requirements
Current Limiting Reactors in Power System
Classification of Transmission Lines
Advantages & Disadvantages of AC and DC Power Transmission
Charging Currents in Transmission Lines
Surge Impedance Loading of Transmission Line
Electrical Contactor, Switch, Circuit Breaker
Difference between Solid Conductor and Stranded Conductor
Types of Flow Meters MCQ - Instrumentation and Control
Types of Flow Meters MCQ – Instrumentation and Control
Which instrument is at fault in this system
Which Instrument is at Fault in this System?
DP Transmitter Block and Bleed Valve
DP Transmitter Block and Bleed Valves
PLC Controls a Valve
PLC Controls a Valve Video
Biomedical Instrumentation Objective Questions
PLC Programming Examples using Timer
Basic PLC Ladder Programming Example
100 Instrumentation Projects for Final Year Engineering Students
Instrumentation in Industries
Why is Instrumentation used in Industries?
