Reading: Advantages and Disadvantages of Slip Ring Induction Motor
Inst Tools > Blog > Electrical Machines > Advantages and Disadvantages of Slip Ring Induction Motor
Last updated: April 28, 2016 3:49 pm
Electrical Machines
2 Min Read
Advantages:
  • High Starting torque with low starting current. Maximum starting can be attained in the slip ring motor compared to squirrel cage motor by inserting an external resistance in each phase of the rotor circuit and cutting the resistance during starting
  • Speeds can be adjusted in the case of slip ring (wound rotor) induction motor by inserting an resistance. Hence slip ring motors are considered as variable speed motors.
  • Slip ring motors have high over loading capacity, smooth acceleration under heavy loads, and no abnormal heating during starting
Disadvantages:
  • Initial and maintenance cost is more compared to squirrel cage motor because presence of slip rings, brushes, short circuiting devices etc.
  • Speed regulation is poor when operated with external resistances in rotor circuit
  • Efficiency and power factor of slip ring motor is lower compared to squirrel cage induction motor
  • Lower power factor at the light loads
  • Sensitivity to fluctuations in supply voltage
Applications:
Induction motors generally will have low starting torque compared to dc series motor. Slip ring induction motor have big advantage of having high starting torque compared to squirrel cage motor. Therefore slip ring induction motors are generally employed where load requires high starting torque or good speed control. They are employed in hoists, elevators, compressors, printing presses, large ventilating fans, loads requiring speed control such as for driving lifts and pumps.
Why rating of Synchronous Generators and Alternators in MVA or KVA
Use of line reactors
DC Motor Applications in Industries
Advantages & Disadvantages Induction Motor
Induction Motors Faults and Protection
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Transformer Open and Short Circuit Tests
Difference between Induction motor and Synchronous motor
Star to Delta and Delta to Star Conversion Formula
Losses in a DC Generator
Advantages & Disadvantages of Synchronous Motors
Basics of AC Induction Motors
What happen When Synchronous Generator loss Excitation
Importance of Hysteresis Loop
Difference between Permanent Magnet BLDC and DC Motor
Why Armature is placed on Stator for Synchronous machines
Metering pumps
Metering Pumps
VFD circuit
AC Motor Braking
Questions and Answers on Motors and Generators
100+ Questions and Answers on Motors and Generators
Stepper Motor Construction
Stepper Motor Basics, Types, Modes, Wiring, Questions
Temperature Balance System Objective Questions
Types of Failures in Control Valves
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
Cell Constant in Conductivity Analyzer
What is Cell Constant in Conductivity Analyzer? and its Importance
PLC Programming Examples using Timer
Basic PLC Ladder Programming Example
Industrial Star Delta Starter for 3-Phase Induction Motor
Star Delta Starter – Working, Circuit, Advantages, Disadvantages
Electrical Ladder Diagram Control using Timers Example
Components of PLC
