In this article, we shared the 250 plus control system MCQ questions and answers to test your knowledge.
Control System MCQ Test Questions
The below list provides all the multiple-choice questions related to the control systems technical subject.
1. The temperature, under thermal and electrical system analogy, is considered analogous to
| A) | charge |
| B) | capacitance |
| C) | none of these answers |
| D) | voltage |
| E) | current |
2. As compared to electronic systems which of the following is not an advantage of pneumatic control system ?
| A) | More reliability |
| B) | All of these answers |
| C) | No fire hazards |
| D) | Less manitenance requirement |
3. Spring constant in force-voltage analogy is analogous to
| A) | capacitance |
| B) | resistance |
| C) | reciprocal of capacitance |
| D) | current |
4. The input to a controller is always ____ signal.
| A) | an error |
| B) | a sensed |
| C) | a servo |
| D) | any of these answers |
5. Which of the following is the specification of optimal control problems ?
| A) | All of these answers |
| B) | A starting time and state, end time and state |
| C) | System must be represented by a state equation |
| D) | A performance index to define the goal of the control system design |
| E) | Boundary conditions |
6. Which of the following statements is incorrect ?
| A) | If the output response to a bounded input signal result in constant amplitude or constant amplitude oscillation, then the system is limited stable |
| B) | If a system response is stable for a limited range of variations of its parameters, it is called conditionally stable system |
| C) | If a system output is an oscillatory signal for a sinusoidal signal, it is called relatively stable |
| D) | If a system response is stable for all variation of its parameters, it is called absolutely stable system |
7. ____ is a part of the human temperature control system.
| A) | Leg movement |
| B) | Ear |
| C) | Perspiration system |
| D) | Digestive system |
8. In a control system integral error compensation ____ steady state error
| A) | increases |
| B) | any of these answers |
| C) | minimizes |
| D) | does not have any effect on |
9. Which of the following happens as the type of a system increases ?
| A) | Steady state error for a particular function increases |
| B) | Steady state error for a particular function decreases |
| C) | Stability problem decreases |
| D) | Any of these answers |
| E) | None of these answers |
10. In order to convert the angular position of a shaft into an electric signal, which of the following electromagnetic transducers can be used ?
| A) | Rotary LVDT |
| B) | Thermocouple |
| C) | Synchros |
| D) | A.C. servometer |
11. The output of a feedback control system must be a function of
| A) | reference and input |
| B) | output and feedback signal |
| C) | input and feedback signal |
| D) | reference and output |
12. Which of the following forces resists motion ?
| A) | Spring force |
| B) | Inertia force |
| C) | All of these answers |
| D) | Damping force |
13. In a stable control system saturation can cause which of the following ?
| A) | Overdamping |
| B) | Low-level oscillations |
| C) | High-level oscillations |
| D) | Conditional stability |
14. In electrical-pneumatic system analogy the current is considered analogous to
| A) | air flow rate |
| B) | air flow |
| C) | pressure |
| D) | velocity |
15. With feed back ____ reduces.
| A) | none of these answers |
| B) | system stability |
| C) | system stability and gain |
| D) | system gain |
16. In pneumatic systems the medium used is
| A) | liquid |
| B) | oil |
| C) | air |
| D) | hydrogen |
17. Which of the following is an advantage of on line identification ?
| A) | For identification only the working input and output system signals are required for investigation |
| B) | The transfer characteristics are found in the form of transfer functions only |
| C) | Even in the presence of some nonlinearity the method will statistically linearize to give transfer characteristic at operating conditions |
| D) | Identification is carried out in real time and it may be accomplished easily and quickly |
| E) | All of these answers |
18. In case of type-1 system steady state acceleration is
| A) | zero |
| B) | 10 |
| C) | unity |
| D) | infinity |
19. When synchro transmitter shaft is disconnected from the driving shaft it will run as
| A) | receiver |
| B) | standstill component |
| C) | transmitter |
| D) | burnout machine |
20. By the use of which of the following the power amplification of a magnetic amplifier is increased ?
| A) | Negative feedback |
| B) | Direct current in control winding |
| D) | Resistive load circuit |
21. Regenerative feedback implies feedback with
| A) | positive sign |
| B) | step input |
| C) | negative sign |
| D) | oscillations |
22. The term confirmity is associated with which of the following ?
| A) | Transformer |
| B) | Potentiometer |
| C) | Selsyn |
| D) | Magnetic amplifier |
23. The value of a node in the signal flow graph is equal to the
| B) | difference of incoming and outgoing nodes |
| C) | sum of all the incoming nodes |
| D) | product of all the incoming nodes |
24. Which of the following is an example of intentional non-linear systems ?
| A) | Contractor servos |
| C) | Non-linear pitch or dampers in aircraft control |
| D) | On-off transducers |
25. The system response can be tested better with
| A) | ramp input signal |
| B) | exponentially decaying signal |
| C) | sinusoidal input signal |
| D) | unit impulse input signal |
26. As a result of introduction of negative feedback which of the following will not decrease ?
| A) | Band width |
| B) | Distortion |
| C) | Overall gain |
| D) | Instability |
27. The phase lag produced by transportation relays
| A) | is inversely proportional to frequency |
| B) | is independent of frequency |
| C) | decreases linearly with frequency |
| D) | increases linearly with frequency |
28. The gain margin is the factor by which the gain of the system can be increased to make it
| A) | damped |
| B) | stable |
| C) | oscillatory |
| D) | unstable |
29. Steep out off characteristics will have
| A) | all of these answers |
| B) | accurate cut-off |
| C) | small peak response |
| D) | low stability margin |
30. By which of the following the order of the system can be determined ?
| A) | Number of poles at the origin |
| B) | None of these answers |
| C) | The number of stable roots of the system |
31. Non-linearities can be
| A) | intentional |
| B) | incidental |
| C) | either incidental or intentional |
| D) | linearised |
32. Addition of zeros in transfer function causes which of the following ?
| A) | Lead-compensation. |
| B) | Lag-compensation |
| C) | None of these answers |
| D) | Lead-lag compensation |
33. The root locus plot is symmetrical about the real axis because
| A) | all roots occur in pairs |
| B) | complex roots occur is conjugate pairs |
| C) | all of these answers |
| D) | roots occur simultaneously in left hand and right hand plane |
34. The feedback of the tachometer reduces the system’s
| A) | both time constant only and gain only |
| B) | time constant only |
| D) | gain only |
35. Bi-metallic thermostat is a ____ controller.
| A) | one-term |
| B) | two-term |
| C) | zero-term |
| D) | on-off |
36. Zero percent proportional band means
| B) | any of the answers |
| C) | no change in control output |
| D) | no change in measured variable |
| E) | it is an on-off controller |
37. The capacitance, in force-current analogy, is analogous to
| A) | momentum |
| B) | displacement |
| C) | velocity |
| D) | mass |
38. ___ is not a form of non-linearity for a control system
| A) | Backlash |
| C) | Saturation |
| D) | Square-law transfer characteristics |
39. In order to increase the clamping of a badly underdamped system which of the following compensators may be used?
| A) | Phase-lead |
| B) | Either Phase-lead and Phase-lag |
| C) | Both Phase-lead and Phase-lag |
| D) | None of these answers |
| E) | Phase-lag |
40. Which of the following types of motor has printed windings?
| A) | Modular motor |
| C) | Motor with disc shaped rotor |
| D) | Motor with ferromagnetic rotor |
41. Due to which of the following reasons excessive bond width in control systems should be avoided?
| A) | It leads to slow speed of response |
| B) | It leads to low relative stability |
| C) | Noise is proportional to band width |
42. Which of the following is an open loop control system ?
| A) | Ward leonard control |
| B) | Metadyne |
| C) | Field controlled D.C. motor |
| D) | Stroboscope |
43. If the bandwidth of a system is increased the response will
| B) | become factor |
| C) | become slower |
| D) | remain unaffected |
44. Phase lag network does which of the following?
| A) | Decreases bandwidth |
| C) | Maintains velocity gain constant |
| D) | Increases system stability |
45. In a control system, noise can be reduced by ____
| B) | reducing bandwidth and attenuating frequencies at which external signal gets coupled to the system |
| C) | reducing bandwidth |
| D) | increasing bandwidth |
46. The maximum overshoot of a second order system can be increased by
| A) | any of these answers |
| B) | decreasing damping frequency |
| C) | increasing natural frequency |
| D) | increasing damping factor |
47. Any externally introduced signal affecting the controlled output is called a
| A) | signal |
| B) | stimulus |
| C) | feedback |
| D) | gain control |
48. In pneumetic systems a restriction volume combination is equivalent to
| A) | rectifier |
| B) | R.L. circuit |
| C) | R.C. circuit |
| D) | none of these answers |
| E) | resonant circuit |
49. If the complex poles of a system have greater real parts, their overshoot is
| A) | not effected |
| B) | less |
| D) | more |
50. The steady-state output of a unity feedback control system is ____ reference input.
| A) | equal to |
| B) | not related to |
| C) | very near to |
| D) | much more than |
51. In hydraulic system power is transmitted by
| A) | fluid under pressure |
| B) | pistons |
| C) | gears |
| E) | belts |
52. Which of the following methods may be used to minimize the loading in potentiometers ?
| A) | Non-linearity may be introduced |
| B) | Linearity may be introduced |
| C) | Reference voltage may be increased |
| D) | Length of wire may be increased |
53. The lead compensator in a feedback system
| A) | speeds up the transient response |
| B) | all of these answers |
| C) | increases the system error constant to some extent |
| D) | increases the margin of stability |
54. A signal other than the reference input that tends to affect the value of the controlled variable is known as ____
| A) | command |
| B) | control element |
| C) | disturbance |
| D) | reference input |
55. A.C. servomotor resembles ____
| A) | two-phase induction motor |
| B) | Three-phase induction motor |
| C) | universal motor. |
| D) | direct current series motor |
56. The first order control system, which is well designed, has a
| A) | small bandwidth |
| B) | negative time constant |
| D) | large negative transfer function pole |
57. In closed loop control system, with positive value of feedback gain the overall gain of the system will
| A) | decrease |
| B) | be unaffected |
| C) | any of these answers |
| D) | increase |
58. When the initial conditions of a system are specified to be zero it implies that the system is
| A) | at rest but stores energy |
| B) | working normally with reference input |
| C) | at rest without any energy stored in it |
| D) | working normally with zero reference input |
59. For open control system which of the following statements is incorrect?
| A) | Recalibration is not required for maintaining the required quality of the output |
| B) | Errors are caused by disturbances |
| C) | Construction is simple and maintenance easy |
| D) | Less expensive |
60. Velocity error constant of a system is measured when the input to the system is unit ____ function.
| A) | step |
| B) | impulse |
| C) | parabolic |
| D) | ramp |
61. An amplidyne can give which of the following characteristics?
| A) | Constant current |
| B) | Constant voltage |
| C) | Constant current, constant voltage, and constant power |
| D) | Constant current as well as constant voltage |
62. By which of the following is the order of the system determined?
| A) | None of these answers |
| B) | Number of stable roots of the system |
| C) | Number of multiplying terms in the denominator |
| D) | Number of poles at the original |
63. ___ directly converts temperature into voltage.
| A) | LVDT |
| C) | Thermocouple |
| D) | Potentiometer |
| E) | Gear train |
64. By which of the following methods viscous friction can be added to a servomechanism?
| A) | Increasing the temperature of the coil |
| B) | Reducing shaft r.p.m. |
| C) | Coupling a disc to the shaft which is immersed in a viscous medium |
| D) | Increasing shaft r.p.m. |
65. For which of the following reasons nonlinearities are introduced?
| A) | To achieve special characteristics |
| B) | Both To simplify the system and To achieve special characteristics |
| C) | To simplify the system |
66. In case of an on-off controller the proportional band is
| A) | 100 percent |
| B) | none of these answers |
| C) | infinity |
| D) | zero |
67. A control system working under unknown random actions is called ____
| A) | adaptive control system |
| B) | digital data system |
| C) | stochastic control system |
| D) | computer control system |
68. Regenerative feedback implies feedback with
| A) | negative sign |
| B) | positive sign |
| C) | step input |
| D) | oscillations |
69. In distributed systems the transportation delays are detrimental to stability due to which of the following reasons?
| A) | They produce transients |
| C) | They produce both attenuation and phase lag |
| D) | They produce a phase lag |
| E) | They produce attenuation |
70. Which of the following statements is incorrect?
| A) | The damping action of an electro hydro servo unit can be increased by closing the dashpot |
| B) | A simple lever device can be used as a mechanical position control equipment |
| C) | A synchro generator can be used as synchro motor and vice versa |
| D) | Box car generator is used in sampled data system for clamping |
71. In pneumatic instrumentation systems the pressure of compressed air used is around
| A) | 5.5 bar |
| B) | 1.4 bar |
| C) | 1 bar |
| D) | 2.5 bar |
72. By which of the following methods steady-state error can be minimized?
| A) | By increasing system gain constant |
| B) | By decreasing natural frequency |
| C) | By decreasing damped frequency |
| D) | By increasing damped frequency |
73. A stepper motor is a ____ device.
| A) | pneumatic |
| B) | electro-mechanical |
| C) | hydraulic |
74. A zero-order hold is used with sampled data system to
| A) | improve the stability of the system |
| B) | reconstruct the sampled signal |
| C) | make it critically damped |
| D) | convert it to a continuous system |
| E) | none of these answers |
75. Synchros’ are commonly used as transmitters of
| A) | angular data |
| C) | digital data |
| D) | computed data |
| E) | graphical data |
76. A signal flow graph is a
| A) | topological representation of a set of differential equations |
| B) | log graph |
| C) | special type of graph to analyse modern control systems |
| D) | polar graph |
77. Which of the following devices is used for conversion of coordinates?
| A) | Synchro-resolver |
| B) | Selsyn |
| C) | Microsyn |
| D) | Synchro-transformer |
78. A servo system will become absolutely unstable if
| A) | feedback path becomes zero |
| B) | there is zero feedback |
| C) | there is no feedback path |
| D) | there is no stable component |
79. For transistor amplifier circuits the common emitter configuration is used because it gives
| A) | high power gain |
| B) | both high power gain and high voltage gain |
| D) | high voltage gain |
80. A gyroscope works on which of the following principles?
| B) | Law of conservation of momentum |
| C) | First law of thermodynamics |
| D) | Law of conservation of energy |
| E) | Newton’s third law of motion |
81. The proportional error device has output as a function of
| A) | integral of error |
| B) | division of error |
| C) | error |
| D) | derivation of error |
82. For a linear transfer function of the variable the transfer function of the system
| A) | does not change |
| B) | changes |
| C) | has no relation at all |
| D) | depends on other factors also |
83. In an automatic control system which of the following elements is not used?
| A) | Final control element |
| B) | Error detector |
| C) | Sensor |
| D) | Oscillator |
84. When the gain margin is positive and the phase margin is negative, the system is
| A) | unstable |
| B) | stable |
| C) | probabilistic |
| D) | nondeterministic |
85. When derivative action is included in a proportional controller, the proportional band ____
| A) | increases |
| B) | remains unaffected |
| D) | decreases |
86. As compared to a potentiometer which of the following is high for a LVDT?
| B) | Both Voltage sensitivity and Resolution |
| C) | Voltage sensitivity |
| D) | Resolution |
87. Which of the following can be measured by LVDT?
| A) | Displacement |
| B) | Any of these answers |
| C) | Velocity |
| D) | Acceleration |
88. In signal flow graph function points are called
| A) | nodes |
| B) | joints |
| D) | functional points |
89. ___ can be extended to systems which are time-varying ?
| A) | Bode-Nyquist stability methods |
| B) | State model representatives |
| C) | Root locus design |
| D) | Transfer functions |
90. The Bode plot is used to analyze which of the following?
| A) | All phase network |
| B) | Maximum phase network |
| C) | Lag lead network |
| D) | Minimum phase network |
91. The on-off controller is a ____ system.
| A) | non-linear |
| B) | discontinuous |
| C) | digital |
| D) | linear |
92. For root loci which of the following are the starting points?
| A) | Open-loop zeros |
| B) | Closed-loop zeros |
| C) | Open-loop poles |
| D) | Closed-loop poles |
93. Which of the following is the non-linear system?
| A) | Servomotors working in saturation |
| B) | Temperature controlled smelting furnace |
| C) | Automatic voltage stabilizers |
| D) | All of these answers |
94. ____ signal will become zero when the feedback signal and reference signs are equal.
| A) | Input |
| B) | Reference |
| C) | Feedback |
| D) | Actuating |
95. Backlash, in a stable control system, can cause which of the following?
| A) | Underdamping |
| B) | Overdamping |
| D) | Low-level oscillations |
96. If a step function is applied to the input of a system and the output remains below a certain level for all the time, the system is
| A) | stable |
| C) | not necessarily stable |
| D) | unstable |
| E) | always unstable |
97. Which of the following statements is incorrect for root locus technique?
| A) | It provides the pattern of movement of closed loop holes when open loop gain varies |
| B) | It is used to obtain closed-loop pole configuration from open-loop poles and zeros |
| D) | It is most useful for single-input single-output systems |
98. In the case of a second order differential equation when the damping ratio is 1,
| A) | poles will be positive |
| B) | poles will be complex conjugate |
| C) | poles will be equal, negative and real |
| D) | poles will be unequal |
99. A conditionally stable system exhibits poor stability at
| B) | reduced values of open loop gain |
| C) | low frequencies |
| D) | increased values of open loop gain |
100. Which of the following statements is incorrect?
| A) | For type-1 system, with unit ramp input, the steady state velocity constant is finite |
| B) | For type-1 system the unit step input, the steady state error is zero |
| C) | Derivative output compensation will increase settling time |
| D) | The integral error compensation changes a second order system into a third order system |
101. The type 2 system has which of the following ?
| A) | Constant position error as well as velocity error |
| B) | Zero position error as well as velocity error |
| C) | Constant position error and zero velocity error |
| D) | Zero position error and constant velocity error |
102. The transient response, with a feedback system
| A) | rises slowly |
| B) | decays slowly |
| C) | rises quickly |
| D) | decays quickly |
103. Which of the following devices is used to indicate angular position of an aircraft?
| A) | Rotating capacitor |
| C) | Rotatory differential transformer |
| D) | Rotating transformer |
104. By which of the following the control action is determined when a man walks along a path?
| A) | Eyes |
| B) | Hands |
| C) | Legs |
| D) | Brain |
105. In a system of controlling oil flow to burner which of the following elements is not required?
| A) | Proportional controller |
| B) | Turbine flowmeter |
| C) | D.C. shunt motor |
| D) | Tachometer |
106. For a two-phase servomotor which of the following statements is incorrect?
| A) | Torque-speed characteristics are linear |
| B) | The applied voltages are seldom balanced |
| C) | The rotor diameter is small |
| D) | The resistance of the rotor is low |
107. The servomotor differs from other motors in the sense that it has
| A) | low inertia and low torque |
| B) | entirely different construction |
| C) | low inertia and high torque |
| D) | high inertia and high torque |
108. In open-loop system
| A) | the control action depends on the input signal |
| B) | the control action is independent of the output |
| C) | the control action depends on system variables |
| D) | the control action depends on the size of the system |
109. Type 1 system under parabolic input will have which of the following?
| A) | Parabolic output |
| D) | Actuating signal which will increase with time |
| E) | Actuating signal which will decrease with time |
110. The transfer function of a system can be used to evaluate
| A) | type of system |
| B) | output for a given input |
| C) | time constant |
| E) | feedback |
111. The type 1 system has ____ at the origin.
| A) | net pole |
| B) | no pole |
| C) | two poles |
| D) | simple pole |
112. In aircraft, the use of hydraulic motor is preferred over the electric motor because they are
| A) | not electrically driven |
| B) | light and have high torque to inertia ratio |
| C) | cheap |
| D) | flexible |
113. A transfer function may be best defined as
| A) | ratio of system response to the system input function |
| B) | ratio of system input function to system response |
| C) | Laplace transform of system response minus the Laplace transform of the system input function |
| E) | ratio of the Laplace transform of the system response to the Laplace transform of the system input function |
114. In a control application, the choice of error detector depends on
| A) | the accuracy desired |
| C) | the nature of controlled variable |
| D) | the type of control system |
115. In a system low friction co-efficient facilitates
| A) | reduced time constant of the system |
| B) | increased velocity lag error |
| C) | increased speed of response |
| D) | reduced velocity lag error |
116. There is a ____ between the two nodes of the signal flow graph.
| A) | link |
| B) | tree |
| C) | branch |
117. Selsyn’ is the trade name given to
| A) | spinning top |
| B) | rotating capacitor |
| C) | synchros |
| D) | rotating transformer |
118. A servomotor entails which of the following disadvantages?
| A) | Can handle only light loads |
| B) | Low starting torque |
| C) | Low reliability |
| D) | Develops commutation problems |
119. Static error coefficients are used as a measure of the effectiveness of closed-loop systems for specified ____ input signal.
| B) | position |
| C) | acceleration |
| D) | velocity |
120. In a non-linear control system limit cycle is self-sustained oscillations of
| A) | variable amplitude |
| B) | fixed frequency and amplitude |
| C) | variable frequency |
| D) | fixed frequency |
121. The gain of the amplidyne is related to the gain of D.C. generator of equivalent rating as ____ that of D.C. generator.
| B) | equal to |
| C) | less than |
| D) | more than |
122. ___ is the input which is established or varied by some means external to and independent of the feed back control system
| A) | Modulated signal |
| B) | Command |
| C) | Signal |
| D) | Disturbance |
123. The effect of error damping is to
| A) | provide larger settling lime |
| C) | reduce steady state error |
| D) | delay the response |
124. For servomechanisms which of the following statements is incorrect?
| A) | a motor may be added to convert a regulator into a servo |
| B) | some servo need not be stable since they are intended for use with steady signal |
| C) | a servo with better frequency response need not be stable |
| D) | steady-state accuracy of a servo is better than that of a regulator |
125. Phase margin is the amount of angle to make the system
| A) | unstable |
| B) | stable |
| C) | exponential |
| D) | oscillatory |
126. In pneumatic control systems compensation is provided by which of the following?
| A) | Flapper-nozzle mechanism |
| B) | Restriction-volume combinations |
| C) | Bimetal strips |
| D) | Extension tubes |
127. ___ has infinite resolution.
| B) | Deposited field potentiometer |
| C) | Gall Tensley potentiometer |
| D) | Kelvin’s double arm potentiometer |
128. The frequency range specification required to satisfactorily describe the system response is
| A) | attenuation |
| B) | cut off range |
| C) | bandwidth |
| D) | resonance |
129. Electrical capacitance in pneumatic systems is analogous to
| A) | restriction to flow |
| B) | filled helical tube |
| D) | volume of air |
130. The operational amplifier used in servo amplification should have gain as
| A) | low |
| B) | zero |
| C) | very high |
| D) | very low |
131. The transfer function of a system is used calculate which of the following ?
| B) | Type of the system |
| C) | The output for a given input, |
| D) | Time constant |
132. Proportional band of a controller is expressed as
| A) | ratio |
| B) | gain |
| C) | percentage |
| E) | range of the control variable |
133. Through which of the following the frequency domain analysis can be related to time doniain analysis ?
| B) | Laplace transformation |
| C) | Both Laplace transformation and Fourier transformation |
| D) | Fourier transformation |
134. Zero initial condition for a system means ____
| A) | zero stored energy |
| B) | input reference signal is zero |
| C) | no initial movement of moving parts |
| D) | system is at rest and no energy is stored in any of its components |
135. Pressure error can be measured by which of the following ?
| A) | Strain gauge |
| B) | Differential bellows and strain gauge |
| C) | Selsyn |
| D) | Strain gauge and potentiometer |
136. LVDT is preferred over the potentiometer as an error detector because former
| A) | uses capacitance to minimize loading error |
| C) | has high voltage sensitivity, low friction level and infinite resolution |
| D) | produces a stronger actuating signal |
137. In amplidyne the compensating winding is used to
| A) | increase the value of control voltage |
| B) | compensate the effect of magnetic field set up by the load current |
| C) | increase the control current |
| D) | compensate for the power loss due to amplification |
138. For a D.C. generator input could be in the form of
| A) | d.c. current |
| B) | d.c. voltage induced |
| D) | rotational speed |
139. Microsy’ is a component based on the principle of
| A) | saturable reactor |
| B) | resolver |
| D) | d.c. motor |
| E) | rotary differential transformer |
140. The break away points of the root locus occur at
| A) | real axis |
| B) | multiple roots of characteristic equation |
| D) | imaginary axis |
141. The phase difference between the two windings of A.C. servomotor is
| A) | 120° |
| C) | 90° |
| D) | 30° |
| E) | 60° |
142. Which of the following materials is used for making a stator of a synchro ?
| A) | Cast iron |
| B) | Cadmium alloy |
| C) | Copper |
| D) | Laminated silicon steel |
143. ____ is an open loop control system.
| A) | Stroboscope |
| B) | Ward Leonard control |
| D) | Metadyne |
144. Type 0 system has ____
| A) | both high gain constant and small steady state error |
| B) | high gain constant |
| C) | either high gain constant or small steady state error |
| D) | small steady state error |
145. Which of the following is the input to a controller ?
| A) | Error signal |
| B) | Servo signal |
| C) | Sensed signal |
| D) | Desired variable value |
146. In a pneumatic control valve the function of valve positioner is to eliminate
| A) | error in value-stem position |
| B) | excessive hysteresis |
| C) | the effects of air being compressible |
| D) | all of these answers |
147. The type 2 system has ____ at the origin.
| A) | net pole |
| B) | simple pole |
| C) | two poles |
| D) | no net pole |
148. Transfer function of a system is used to calculate which of the following ?
| A) | The steady state gain |
| B) | The output for any given input |
| C) | The time constant |
| D) | The order of the system |
149. In type-1 system a constant output velocity at steady state will be possible when there is
| A) | fluctuating error |
| B) | constant steady state error |
| C) | no error |
| D) | variable steady state error |
150. Mass, in force-voltage analogy, is analogous to
| A) | resistance |
| B) | charge |
| C) | current |
| D) | inductance |
151. With feedback ____ increases.
| A) | effects of disturbing signals |
| C) | gain |
| D) | sensitivity |
152. ___ use hydraulic control devices ?
| A) | Automobiles |
| B) | Machine tools |
| C) | Ships |
153. An automatic toaster is a ____ loop control system.
| B) | closed |
| C) | partially closed |
| D) | open |
154. A phase lag lead network introduces in the output
| A) | lag at all frequencies |
| B) | lag at high frequencies and lead at low frequencies |
| C) | lag at low frequencies and lead at high frequencies |
155. In pneumatic-electrical analogy, the electrical resistance is analogous to
| A) | volume of air |
| B) | restriction to flow |
| D) | filled helical tube |
156. The frequency range is specified by which of the following ?
| A) | Modulation index |
| B) | Band width |
| C) | Resonance |
| D) | Peak value |
157. LVDT is an ____
| A) | electrostatic device |
| B) | electromagnetic device |
| C) | electro-mechanical device |
| D) | electrodynamic device |
158. In a control system noise can be avoided by which of the following methods ?
| A) | Reducing the bandwidth |
| B) | Attenuating those frequencies at which external signals get coupled into the system |
| D) | Both Reducing the bandwidth and Attenuating those frequencies at which external signals get coupled into the system |
159. Which of the following statements is incorrect in respect of closed loop control system ?
| A) | Use of feedback minimizes the effects of disturbing signal |
| B) | A D.C. closed loop control system has modulated wave forms |
| C) | The source power of the feedback system is modulated by error signal |
| D) | With feedback system the transient response decays more quickly |
160. The operational amplifier is used for which of the following ?
| A) | Integration only |
| B) | All common mathematical operations |
| C) | Amplification only |
| D) | Addition only |
161. The magnitude of system output, for damping zero factor, will be
| A) | exponentially decaying |
| B) | infinite |
| C) | unity |
| D) | zero |
162. Which of the following is exhibited by Root locus diagrams ?
| A) | The response of a system to a step input |
| C) | The frequency response of a system |
| D) | The poles of the transfer function for a set of parameter values |
| E) | The bandwidth of the system |
163. In root locus plot different roots have the same
| A) | gain |
| B) | phase |
| C) | gain margin and phase margin |
| D) | both phase and gain |
164. An ideal transformer should have
| A) | a fine wire |
| B) | an infinite resolution |
| C) | zero resolution |
| D) | resolution proportional to the reference voltage |
165. In an open loop control system
| A) | Output is independent of control input |
| B) | Output is dependent on control input |
| D) | Only system parameters have effect on the control output |
166. In thermal-electrical analogy charge is considered analogous to
| A) | reciprocal of heat flow |
| B) | reciprocal of temperature |
| D) | heat flow |
| E) | temperature |
167. If the clamping factor of a control system is unity it will give
| A) | critically damped response |
| B) | undamped response |
| C) | no response |
| D) | oscillatoiy response |
168. The effect of second derivative input control is to
| B) | control time constant of the system |
| C) | both control time constant of the system and suppress oscillations |
| D) | suppress oscillations |
169. When damping factor decreases the per unit overshoot
| A) | remains unaffected |
| C) | decreases |
| D) | increases |
170. The root loci of a system has three asymptotes the system can have
| A) | five poles and two zeros |
| C) | three poles |
| D) | four poles and one zero |
171. Which of the following is an electromechanical device ?
| A) | Thermocouple |
| C) | Induction relay |
| D) | LVDT |
| E) | Any of the answers |
172. Which of the following is the output of a synchor error detector ?
| A) | Suppressed-carrier modulated signal |
| B) | Angular displacement of control transformer rotor |
| C) | Voltage signal of the receiver |
| D) | Voltage signal of constant amplitude |
173. The input to a stepper motor is in the form of
| A) | electric pulses |
| B) | frictional force |
| C) | viscous damping force |
| D) | mechanical interia |
174. The value of the resonant peak, in second order control system, will be unity when the damping ratio has a value of
| A) | unity |
| B) | √2 |
| D) | zero |
| E) | 1/√2 |
175. The time required for the response to reach half the final value for the first time is
| A) | decay time |
| B) | pick-up time |
| C) | delay time |
| D) | rise time |
176. In a magnetic amplifier the purpose of bias winding is
| A) | to produce initial saturation in core for high amplification |
| C) | to weaken A.C. flux in the core |
| D) | to weaken D.C. flux in the core |
177. Gain margin is the factor by which the gain of the system is increased to make it
| A) | damped |
| B) | stable |
| C) | unstable |
| D) | oscillatory |
178. The position and velocity errors of a type-2 system are
| A) | zero, constant |
| B) | constant, constant |
| C) | zero, zero |
| D) | constant, infinity |
179. The type 0 system has ____ at the origin.
| A) | two poles |
| B) | net pole |
| C) | no pole |
| D) | simple pole |
180. Which of the following is the output of a thermocouple ?
| A) | Alternating current |
| B) | Direct current |
| C) | A.C. voltage |
| E) | D.C. voltage |
181. A servomechanism with unit step input can be categorised as ____ system
| A) | type 0 |
| B) | type 2 |
| D) | type 1 |
| E) | type 3 |
182. A pneumatic amplifier ____
| A) | amplifies flow |
| C) | amplifies & differential pressure |
| D) | amplifies change in air volume |
183. ____ technique gives quick transient and stability response
| A) | Nichols |
| B) | Root locus |
| C) | Bode |
| D) | Nyquist |
184. High power amplification is achieved by the use of
| A) | silicon controlled rectifier |
| B) | A.C. amplifier |
| D) | amplidyne |
| E) | magnetic amplifier |
185. Frequency domain analysis is preferred when dealing with systems having input as
| A) | ramp and parabolic |
| B) | sinusoidal with variable frequency and amplitude |
| C) | sinusoidal with fixed frequency |
| D) | non-sinusoidal with lagging power factor |
186. Synchros’ are popularly used as transmitter of
| A) | angular data |
| B) | digital data |
| C) | mathematical data |
187. Nyquist criterion is used to find which of the following ?
| A) | Both Absolute stability and Relative stability |
| C) | Absolute stability |
| D) | Relative stability |
188. A reduction gear is used to increase the
| A) | torque developed |
| B) | viscous friction |
| C) | moment of inertia |
| D) | driven shaft speed |
189. The initial response when the output is not equal to input is called
| A) | Dynamic response |
| B) | Error response |
| C) | Transient response |
| D) | Either of these answers |
190. The loading effect-on the potentiometer can be avoided by the use of
| A) | battery |
| B) | constant current source |
| D) | trimmer |
| E) | alternator |
191. A system which has some roots with real parts equal to zero but none with positive real parts is
| A) | relatively stable |
| B) | absolutely unstable |
| C) | marginally stable |
| D) | absolutely stable |
192. In order to decrease the time constant of the control system its ____ should be decreased.
| A) | steady state error |
| B) | inertia |
| C) | damping constant |
| D) | viscous damping |
193. A servomechanism is a feedback control system required to control
| A) | either position or some derivative of position |
| B) | servoamplifiers and drives |
| C) | position |
| D) | some derivative of position |
194. In a compressed air plant which of the following is not a function of the reservoir ?
| A) | Filtration of air |
| B) | Cooling of air |
| C) | Removal of pressure ripples |
| D) | Storage of air |
195. Which of the following is an advantage of Laplace transform method ?
| B) | Initial conditions are incorporated in the very first step |
| C) | It gives solution in frequency domain only |
| D) | Both It gives total solution more systematically and Initial conditions are incorporated in the very first step |
| E) | It gives total solution more systematically |
196. In pneumatic systems time lags are obtained by
| B) | making the air to fill a volume after passing through a restriction |
| C) | elongating the path of air |
| D) | pneumatic-electric elements |
197. On which of the following factors does the resolution of a potentiometer depend ?
| A) | Shape of wire cross-section |
| B) | Type of contact |
| C) | Size of wire |
| D) | Composition of wire material |
198. A servomechanism with step displacement input will form ____ system.
| A) | type-1 |
| B) | type-3 |
| C) | type-2 |
| D) | type-0 |
199. Which of the following is an assumption made in Laplace technique in sampled data control ?
| A) | Sampler is ideal having make and break contacts operating instantly |
| B) | Sampler is having sampled information fed to a linearily relaxed system |
| C) | Sampler is working on periodic duty cycle |
| E) | Sampler is having small pulse duration |
200. ____ is preferred when a control signal is required to have a power level higher than the capability of linear electronic amplifiers.
| A) | Amplidyne |
| B) | A.C. servomotor |
| D) | A.C. tachometer |
201. ___ is not a final control element
| A) | Control valve |
| C) | Electro-pneumatic convertor |
| D) | Servomotor |
202. Which of the following is the best method for determining the stability and transient response ?
| A) | Root locus |
| B) | Nyquist plot |
| D) | Bode plot |
203. Hydraulic torque transmission system is analog of
| A) | resistance-capacitance parallel circuit |
| B) | motor-generator set |
| C) | amplidyne set |
204. In a system the friction co-efficient is decreased to decrease
| A) | velocity lag error |
| B) | system time constant |
| D) | velocity lead |
205. By which of the following the system response can be tested better ?
| A) | Exponentially decaying signal |
| B) | Sinusoidal input signal |
| C) | Unit impulse input signal |
| D) | Ramp input signal |
206. The effect of adding poles and zeros can be determined quickly by which of the following?
| A) | Bode plot |
| B) | Nicholar chart |
| D) | Nyquist plot |
| E) | Root locus |
207. The output of a stepper motor is in the form of
| B) | either linear movements or angular movements |
| C) | angular movements |
| D) | linear movements |
208. Which of the following is the setting time in the second order linear system ?
| A) | 4 times the time constant |
| B) | 1/4 of time constant |
| C) | 1/2 of time constant |
| D) | 2 times the time constant |
209. A.C. servomotor, as compared to a standard induction motor has ____ inertia and ____ starting torque.
| A) | low, low |
| B) | high, low |
| C) | low, high |
| D) | high, high |
210. A system which has some roots with real parts equal to zero but none with positive real parts is
| B) | marginally stable |
| C) | absolutely unstable |
211. The overshoot (an indication of the largest error between the actual and desired output) is the ratio of
| B) | dynamic error to peak error |
| C) | maximum overshoot to final desired value |
| D) | transient error to peak error |
212. ___ is used for Nyquist plot.
| A) | Open loop function |
| B) | Characteristic equation |
| C) | Closed loop function |
213. The transfer function technique is considered as inadequate under which of the following conditions ?
| B) | Systems having stability problems |
| C) | Systems having complexities and non-linearities |
| D) | Systems having multiple input disturbances |
214. Regulator can be categorized as ____ system.
| A) | type-3 |
| B) | type-1 |
| C) | type-0 |
| D) | type-2 |
215. ___ is the serious disadvantage of electronic control systems.
| A) | Temperature sensitivenes |
| B) | Low reliability |
| D) | Operational difficulty |
216. Which of the foaming is the main advantage of hydraulic system over electrical system ?
| A) | Easy balancing |
| B) | No cooling problems |
| C) | No danger of electric shock |
| D) | Smaller size |
217. By the used of which of the following high power amplification is achieved ?
| A) | D.C. amplifier |
| B) | Amplidyne |
| C) | A.C. amplifier |
| D) | Silicon controlled rectifier |
218. In a system zero initial condition means that
| A) | The system is at rest and no energy is stored in any of its components |
| C) | The system is working with zero reference signal |
| D) | The system is working with zero stored energy |
219. In a stable control system backlash can cause which of the following ?
| A) | Low-level oscillations |
| B) | Poor stability at reduced values of open loop gain |
| C) | Underdamping |
| D) | Overdamping |
220. An increase in gain, in most systems, leads to
| B) | constant damping ratio |
| C) | larger damping ratio |
| D) | smaller damping ratio |
221. Which of the following statements is correct for any closed loop system ?
| A) | Only one of the static error co-efficients has a finite non-zero value |
| C) | All the co-efficients can have zero value |
| D) | All the co-efficients are always nonzero |
222. Differential used in synchro differential unit indicates which of the following ?
| A) | Difference of rotation angle of two synchro generators |
| B) | Rate of change of linear motion |
| C) | Differential of analog signal to be transmitted |
223. A car is running at a constant speed of 50 km/h, which of the following is the feedback element for the driver ?
| A) | Steering wheel |
| B) | Eyes |
| D) | Needle of the speedometer |
| E) | Clutch |
224. ____ will increase the steady state accuracy ?
| A) | Differentiator |
| B) | Phase lag compensator |
| C) | Phase lead compensator |
| D) | Integrator |
225. The compressed air in pneumatic control systems is not
| A) | filtered |
| B) | regulated |
| D) | lubricated |
226. By which of the following methods the steady state error of a control system can be reduced ?
| A) | by increasing both time constant and gain constant |
| B) | by increasing time constant of the system |
| D) | by increasing gain constant of the system |
227. A servomechanism usually consist of
| A) | error actuated signal |
| B) | power amplifier |
| C) | mechanical output |
228. The steady state acceleration error for a type 1 system is
| B) | unity |
| C) | zero |
| D) | infinite |
| E) | between zero and unity |
229. By use of which of the following the system damping factor can be reduced ?
| A) | Positive feedback |
| B) | Rate feedback |
| C) | Negative feedback |
| D) | Integral feedback |
230. Sampled data systems final application in which of the following ?
| B) | High speed in plate rolling drives by using quantized data |
| C) | Control mechanisms of automatic metal cutting lathes |
| D) | Pulse controlled electric drives |
231. In radars the control system used is
| A) | discrete data control system |
| C) | continuous control system |
| D) | relay control system |
232. The viscous friction co-efficient, in force-voltage analogy, is analogous to
| A) | reciprocal of conductance |
| B) | reciprocal of inductance |
| C) | charge |
| E) | resistance |
233. At which of the following root loci will end ?
| A) | Closed loop zeros |
| B) | Closed loop poles |
| C) | Open loop poles |
| D) | Open loop zeros |
234. A closed loop system is distinguished from open loop system by which of the following ?
| A) | Servomechanism |
| B) | Output pattern |
| C) | Input pattern |
| D) | Feedback |
235. Which of the following is an essential feature of servomechanism ?
| A) | A closed loop system |
| B) | Ability to control position, velocity or acceleration of the system |
| C) | A power amplifying stage |
236. Which of the following statements is not nedessarily correct for open control system ?
| A) | Less expensive |
| B) | Input command is the sole factor responsible for providing the control action |
| C) | Presence of non-linearities causes mal-functioning |
| D) | Generally free from problems of non-linearities |
237. For root locus technique which of the following statements is incorrect?
| A) | It provides the pattern of movement of closed-loop poles when open loop gain varies |
| C) | It is most useful for single-input single output systems |
| D) | It is used to obtain closed loop pole configuration from open loop poles and zeros |
238. The Bode plot is applicable to ____ network.
| A) | minimum phase |
| B) | all phase |
| D) | maximum phase |
239. Which of the following is the definition of proportional band of a controller ?
| B) | The range of measured variables through which the air output changes from maximum to minimum |
| C) | The range of air output as measured variable varies from maximum to minimum |
| D) | The range of measured variables from set value |
240. System damping can be increased by using compensator having pair of complex roots as
| A) | phase lag |
| B) | phase lead |
| C) | phase lag lead |
241. Which of the following statements is correct for a system with gain margin close to unity or a phase margin close to zero ?
| A) | The system is highly oscillatory |
| B) | The system is highly stable |
| D) | The system is relatively stable |
242. A synchro is employed
| A) | to convert linear motion into angular motion |
| B) | to accelerate a rotating shaft |
| C) | to amplify low frequency signals |
| D) | to convert an angular position of a shaft into an electrical signal |
243. A controller essentially is a
| A) | comparator |
| B) | amplifier |
| C) | sensor |
| D) | clipper |
244. Phase margin of a system is used to specify which of the following ?
| A) | Frequency response |
| B) | Relative stability |
| D) | Time response |
245. The transfer function is applicable to which of the following ?
| A) | Linear and time-in variant systems |
| B) | Linear and time-variant systems |
| C) | Non-linear systems |
246. ___ cannot be the final control element.
| A) | Potentiometer |
| B) | Electro-pneumatic converter |
| D) | Servomotor |
247. Which of the following is the basic property of signal flaw graph ?
| A) | Signals travel along branches only in the marked direction and is multiplied by the gain of the branch |
| B) | It is applicable to linear system only |
| D) | The algebraic equations must be in the form of cause and effect relationship |
| E) | Nodes are arranged from left to right in a sequence |
248. In a hybrid feedback control system carrier signals are
| A) | only A.C. |
| B) | both only A.C. and only D.C. |
| C) | only D.C. |
249. If the gain of the critical damped system is increased it will behave as
| A) | overdamped |
| B) | critically damped |
| D) | oscillatory |
| E) | underdamped |
250. Regenerative feedback means the output is feedback with
| B) | regenerator |
| C) | positive sign |
| D) | oscillation |
251. In pneumatic control systems the control valve used as final control element converts ____
| B) | pressure signal to position change |
| C) | pressure signal to electric signal |
| D) | position change to pressure signal |
| E) | electric signal to pressure signal |
252. ____ technique is not applicable to nonlinear system ?
| A) | Quasi linearization |
| B) | Functional analysis |
| C) | Nyquist Criterion |
| D) | Phase-plane representation |
253. The servomechanisms with step displacement input is
| A) | type 3 system |
| B) | type 0 system |
| C) | type 2 system |
| D) | type 1 system |
254. In pneumatic control system the output of a flapper-nozzle mechanism corresponds to
| A) | flow-range |
| B) | voltage-range |
| D) | pressure-range |
| E) | mechanical measurement |
255. Which of the following is a disadvantage of a series D.C. motor ?
| A) | its speed regulation is poor |
| B) | It requires high starting torque |
| C) | It draws large currents |
256. ___ is a closed loop system.
| A) | Electric switch |
| B) | Direct current generator |
| C) | Car starter |
| D) | Auto-pilot for an aircraft |
257. Bandwidth is used as a means of specifying performance of a control system related to
| A) | the speed of response |
| C) | relative stability of the system |
| D) | the constant gain |
258. A limit switch is used to
| A) | limit the value of a signal |
| C) | convert mechanical motion to electrical signal |
| D) | convert electrical signal to mechanical signal |
| E) | limit the motion of a drive |
259. Because of which of the following the use of deposited film type potentiometer is limited.
| A) | Either Resistance varying with temperature or Infinite resolution |
| C) | Resistance varying with temperature |
| D) | Infinite resolution |
260. The damping ratio of the system having only two poles, each having a negative real part, will be
| A) | infinitely high |
| B) | non-zero |
| C) | any of these answerss |
| D) | zero |
261. In a system nonlinearity may be introduced by which of the following ?
| A) | Saturation effects in amplifiers |
| C) | Backlash in gears |
| D) | End positions in detectors |
262. A control system with excessive noise, is likely to suffer from
| A) | vibrations |
| B) | loss of gain |
| C) | saturation in amplifying stages |
| D) | oscillations |
263. Which of the following should be done to make an unstable system stable ?
| A) | The gain of the system should be decreased |
| B) | The number of zeros to the loop transfer function should be increased |
| C) | The gain of the system should be increased |
| D) | The number of poles to the loop transfer function should be increased |
264. A minor loop feedback compensation increases the steady state error by a factor which is ____
| A) | constant |
| B) | inversely proportional to rate feedback |
| C) | decaying exponentially |
| D) | directly proportional to rate feedback |
265. Which of the following devices are commonly used as error detectors in instruments ?
| A) | Resolvers |
| B) | Vernistats |
| C) | Any of these answers |
| D) | Microsyns |
266. The resolution of potentiometer should be
| A) | low |
| B) | infinity |
| C) | zero |
| D) | very high |
267. A control system in which the control action is somehow dependent on the output is known as
| A) | Closed loop system |
| C) | Open system |
| D) | Semiclosed loop system |
268. A good control system has all the following features except
| A) | sufficient power handling capacity |
| B) | slow response |
| C) | good accuracy |
| D) | good stability |
269. A differentiator is usually not a part of a control system because it ____
| A) | increases error |
| B) | reduces the gain margin |
| C) | increases input noise |
| D) | reduces damping |
270. Which of the following is the nonlinearity caused by servomotor ?
| A) | Saturation |
| B) | Backlash |
| D) | Static friction. |
271. A.C. servomotor is basically a ____
| A) | single phase induction ‘actor |
| B) | three phase induction motor |
| C) | two phase induction motor |
| D) | universal motor |
272. ___ increases the steady state accuracy.
| A) | Phase lead compensator |
| B) | Integrator |
| C) | Phase lag compensator |
| D) | Differentiator |
273. In system design which of the following is the disadvantage of differentiators ?
| A) | Large resistances and inductances in the circuit |
| B) | Noise production and amplifier saturation |
| D) | High cost |
274. ___ system provides excellent transient as well as steady-state response
| A) | Proportional action |
| B) | Proportional + integral action |
| C) | Proportional + differential action |
| D) | Proportional + integral + differential action |
275. The transient response of a system is mainly due to
| A) | internal forces |
| B) | inertia forces |
| C) | stored energy |
| D) | friction |
276. With the knowledge of state space representation the transfer function of the system
| A) | can be determined partly |
| C) | cannot be determined |
| D) | can be determined completely |
277. Which of the following is incorrect ?
| B) | Nyquist criterion is in time domain |
| C) | Routh’s criterion is in time domain |
| D) | Bode plot is in frequency domain |
278. ____ can measure pressure error.
| B) | SeIsyn |
| C) | Strain gauge |
279. The second derivative input signals modify which of the following ?
| A) | The gain of the system |
| C) | Damping of the system |
| D) | The time constant of the system |
| E) | The time constant and suppress the oscillations |
280. ___ is the reference input minus the primary feedback.
| A) | Zero sequence |
| B) | Manipulated variable |
| C) | Primary feedback |
| D) | Actuating signal |
281. Diodes are connected in series with A.C. source of the magnetic amplifier mainly to
| A) | act as filter |
| C) | avoid desaturation of core due to negative half cycle |
| D) | act as rectifier |
282. A unit step function on integration results in a
| A) | unit ramp function |
| B) | unit doublet |
| C) | unit parabolic function |
| D) | unit step function |
283. The velocity lag error in the type-1 system is
| A) | inversely proportional to band width of the system |
| B) | independent of gain constant |
| C) | directly proportional to gain constant |
| D) | inversely proprotional to gain constant |
284. To maximize or minimize a set of criteria is called ____
| A) | optimal control policy |
| B) | maximization control |
| C) | limit differential function zero |
| D) | minimization control |
285. For system gain to be zero, the roots will move towards
| A) | poles |
| B) | zeros |
| C) | origin |
286. The servosystem with step acceleration input is a ____ system.
| A) | type 1 |
| B) | type 2 |
| C) | type 0 |
| D) | type 3 |
287. In liquid level and electrical system analogy, voltage is considered analogous to
| A) | head |
| C) | liquid flow |
| D) | liquid flow rate |
288. The overshoot is an indication of
| A) | largest error between the actual and desired output |
| B) | least error between the actual and desired output |
| C) | resonance between output and input |
| D) | no error between the actual and desired output |
289. On which of the following factors does the sensitivity of a closed loop system to gain changes and load disturbances depend ?
| B) | Loop gain |
| C) | Forward gain |
| D) | Frequency |
290. Which of the following can be measured by the use of a tacho generator?
| A) | Acceleration |
| B) | Speed and acceleration |
| C) | Displacement |
| D) | Speed |
291. The effect of error rate damping is
| A) | to reduce steady state error |
| C) | faster response |
| D) | faster response and reduction in steady state error |
| E) | faster response and larger settling time |
292. For frequency domain analysis sinusoidal signals considered have ____ frequency.
| B) | differential |
| C) | same |
| D) | logarithmic |
293. ____ has tendency to oscillate.
| A) | Both Open loop system and Closed loop system |
| B) | Closed loop system |
| C) | Open loop system |
| D) | Either Open loop system nor Closed loop system |
294. A ‘drag cup’ type motor has which of the following ?
| A) | Low inertia |
| B) | Low power rating |
| C) | Low starting torque |
| E) | Low damping |
295. The eigen values of a linear system are the locations of
| B) | poles of the system |
| C) | finite poles |
| D) | zeros of the system |
Click Here for Answers
Next Quiz:
- Control System Test – 1
- Control System Test – 2
- Control System Test – 3
- Control System Test – 4
- Control System Test – 5
- Control System Test – 6
- Control System Test – 7
- Control System Test – 8
great great
